Question about Samsung Maxima Zoom AF Fuzzy Logic 35mm Film Camera zoom lens 35-70mm Auto Macro Camera
What are the batteries for the camera af fuzzy logic
CAN NOT FOCUS THE CAMERA WITH OR WITHOUT MEMORY CARD
The memory card has nothing to do with the focus system. Not knowing what camera you have, I have to guess.
Check the camera is on Automatic. When it is a DSLR or system camera, check the AF / MF switches, both on the camera and on the lens.
Eventually check in the menu if you can switch from AF to MF and in any case, switch to AF.
Check if you can focus manual, or perhaps he camera can't focus at all. Then check if you did connect the lens correct.
Jan 23, 2015 | Cameras
How much does a replacement battery cost for the panasonic af x ccd omni movie vhs video camera
The PV-BP18 batteries can be bought on-line for $32 to $45 with free shipping. Search eBay or Amazon for PV-BP18 Battery.
Jun 17, 2014 | Panasonic AF X8 CCD Omni Movie VHS Video...
I have a LG 15.0kg top loading fuzzy logic washing machine. Machine does not empty water out. What could the problem be?
i have a lg fuzzy logic 15.0kg and on fuzzy mode , it continue to supply water and do not wash clothes
please can anyone help me what can i do .
Oct 26, 2012 | LG Washing Machines
My canon lens 28-135 produces focused pictures but looks fuzzy in the viewfinder...is there something that has to be cleaned?
If your camera has a viewfinder diopter adjustment (small wheel a the side of the viewfinder) try moving this up and down to see if that corrects the problem
Sep 03, 2010 | Canon 28-135mm f/3.5-5.6 EF IS USM AF Lens
I bought digital Canon EOS Rebel XT two years ago, and I have really big problem with AF. I got one half of the pictures fuzzy. Sometimes the green light is on, I took the picture and it is fuzzy. Next...
Is the lens on AF mode?
Have you tried more than one lens to determine whether it's the lens or the camera itself?
You may want to have lens calibrated. Send in for service?
May 27, 2008 | Canon Cameras
AF won't autofocus
I had a similar problem with my XTi. I swapped between two lenses and the issue stayed with the camera most likely because the AF logic is in the camera, and not the lens. What fixed my issue was when I took the lens off, and tried taking a picture to see how the mirror reacted. Sure enough, something was blocking my mirror from activating during the shot. I didn't see anything blocking, so I assumed it was "stuck". I moved the mirror, and after that, the AF worked fine when I put the lens back on. Not sure if this will help.
May 02, 2008 | Canon Cameras
Fuzzy pictures from my Panasonic DMC-FZ5
Fuzzie picture -meaning out of focus? Check that you have not got 1- macro setting on [setting symbol looks like a tiny plant] or that you have a low light setting which menas it is taking long exposures. Aslso the Auto foxus may not be function as it should - one possibility is that the way you hold the camera covers the 'window' make sure your fingers are aware from any of the front top panel 'windows' When you depress the shutter part way down- does the lens 'motor' to focus Or indeed are you doing part way or are snapping off shot and giving the camera time to focus? Lots of thing for you to check out, before we start getting worried. The difficult ones are if the camera has taken a knock and the lens mount has become dislodged But do all the check first and do consult the manual
Jun 14, 2007 | Panasonic Lumix DMC-FZ5 Digital Camera
Camera doesn’t start
The only solution that I found is to take off the battery from camera. After I reconnect the battery, the camera starts without any problem (lens are moving, LCD is on, AF is also on). The battery status is full.
Sep 12, 2005 | Samsung Digimax V5 Digital Camera
AF mode
Full-time AF keeps the image on the LCD monitor focused at all times without having to press the shutter release button. Note the following: Using full-time AF will drain the battery more quickly Full-time AF is not available when the LCD monitor is turned off For "Card set-up" or "Card cover alarm", the AF operation of the camera does not halt. Once resumed, the camera always puts the AF in action for immediate focusing
Sep 01, 2005 | Olympus Camedia C-3030 Zoom Digital Camera
AF mode
Sep 01, 2005 | Olympus C-3000 Zoom Digital Camera
Samsung Maxima Zoom AF Fuzzy Logic 35mm Film Camera zoom lens 35-70mm Auto Macro Camera Logo
27 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
