Question about Water Heaters
Manual for Richmond 6g40pvw-40f water heater - Water Heaters
5 Suggested Answers
SOURCE: Richmond power vent water heater won't stay lit.
I have a 40 gal richmond water heater with power vent and had a similar roblem. I call to talk to a tech and he suggested the vacuum switch. I ordered on line. It was $43 plus shipping and I installed it and it did the job. I happy.
Posted on Nov 05, 2010
SOURCE: hi i have a power
Hello Mike,
Check gas pressure, burner parts need to be cleaned, check electrical outlet, hot surface igniter is bad
White Rodgers intellivent error code:
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html#Intellivent
http://waterheatertimer.org/pdf/Intelli-vent-gas-valve2.pdf
Error code says: system in lockout, but you know that.
1) Low gas pressure, no gas to water heater: call gas company to check pressure
2) Hot surface igniter not positioned correctly: inspect and clean burner parts.
http://waterheatertimer.org/images/Reliance-hot-surface-ignite.jpg
3) Low voltage to water heater/ outlet has wrong polarity: Use circuit analyzer on electrical outlet to make sure polarity is correct
Typical power vent manual:
http://waterheatertimer.org/pdf/Reliance-40-50-power-vent.pdf
Cleaning water heater:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#clean
http://waterheatertimer.org/pdf/How-to-clean-combustion-chamber.pdf
Posted on Jun 20, 2011
heatman101
  • 43501 Answers
SOURCE: Have a Richmond Hot Water
If you are getting the lockout code then there are a few things that need to be checked out before changing the control....
Gas supply and pressure...
The ignitor and it's positioning...
Electrical voltage and polarity....
These controls have been giving a ton of trouble, so it may or may not have been the water that caused the trouble...if the above things are not the problem, then you have no choice but to replace the control...check with your supplier as you may be able to get it replaced under warranty..
heatman101
Posted on Jul 11, 2011
  • 5245 Answers
SOURCE: Richmond powervent model 6G40PV-40F Lockout 4-2 blink. What's wrong. What do I replace to fix?
1) Rheem-Richmond does not post service manuals:
Copy following link to identify service manual by type of gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
2) For lockout, the air intake might be clogged or combustion parts dirty, causing overheating which will break TRD glass vial. Gas control may need to be replaced. Reset gas control by rotating knob to lowest temp for at least 6 seconds.
3) Call Rheem or local service tech.
Posted on Mar 10, 2013
Mar 10, 2013 | Water Heaters
I have a Richmond 40 gal water heater model# 6G40PVW-40PF manufactured 5/2010 and it wont't stay lit. I don't have the owners manual as we purchased our home in 12/2011 and it was a foreclosu
Well I you have the problem resolved by now, but I will answer anyhow. This just happened to me yesterday with the same water heater that you have. My problem was that the flame sensor was dirty and not picking up that the burner was lit, so it shuts everything down and goes into lockout mode. I had a similar problem with my furnace lighting system. It is called flame rectification. What actually happens is the flame itself allows a small current to flow through it, so the flame sensor actuall makes electrical contact with the burner. The control senses this connection and knows then, that the flame is on. If it doesn't sense this connection, it thinks the flame is out, so it must shut off the gas valve to prevent a possible explosion. Take your burner out and clean up everything in there, being careful not to break the small glass bulb inside, which is another safety device. Fine emery cloth of a wire brush will clean up the flame sensor good. Also wire brush the burner itself, since this is the other end of the rectification circuit.
Apr 01, 2012 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
I have a richmond power vent water heater model number 6G40POW-40F.It will run for 2 min then shut itself off then restart and do the same thing all over.Then 2 lights come on and it wont run. Any help...
Fastest way to solve water heater problem is call plumber or service technician.
Open following link for typical error codes for intellivent gas valve found on newer Richmond/Rhemm power-vent gas water heaters:
http://waterheatertimer.org/pdf/Intellivent-service-manual.pdf
There is no 100% sure way for novice to repair gas water heater.
This is because electrical parts have to ohm-tested using information from service manual that is typically not sent with new water heater.
Also parts have to be cleaned. The gas pressure checked, air in gas line removed, burner tubes and pilot tube and combustion chamber cleaned, burner parts inspected for problems, air intake cleaned, exhaust vent tested.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Best way for do-it-yourselfer to solve water heater problems is to learn as much as possible about specific model by reading product manual that comes with new heater.
The manual will show error codes.
Then keep up with yearly service recommendations shown in manual.
Aug 03, 2011 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
I have a model 6G40PVW-40F water heater and we have no hot water... the thermostat light on warm/vacation is on and so are 2 other lights...If I diconnect it and re-connect it then it will start..the gas...
Most gas water heater problems today can be solved with yearly maintenance that includes cleaning burner parts, clean air intake, check venting, check electrical connections, bleed gas line, and check gas pressure.
Gas water heater manuals recommend yearly maintenance by service technician.
In past years, gas water heaters required less maintenance, but they were less energy efficient and more dangerous to operate.
Sounds like you have Intellivent gas control valve thermostat.
Open following link to identify gas valve and see error codes:
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html#intelli
Error light on vacation + 2 other lights = 3 possible conditions:
1) Wiring error: check outlet with circuit analyzer:
http://waterheatertimer.org/images/Typical-circuit-analyzer-15.jpg
2) Pressure switch tubing not connected, air intake obstructed (clean intake), or vent exhaust obstructed (check for proper venting).
http://waterheatertimer.org/images/Test-water-heater-vent-400.jpg
3) System in lockout: Low gas pressure, hot surface igniter not positioned correctly.
You can do some of this yourself.
Jun 30, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Hi i have a power vent water heater model #-6g40pvw-40f. It go's into lock down mowed one light lit on vaction two more on A-and B is it the heating element or lighter mechanison thank you mike from...
Hello Mike,
Jun 19, 2011 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Richmond power vent will not stay lit, the bunrer will lit than after about 5-10 min. it goes and tries to relite and than goes into lock down. after it about 5 min. you can reset it and it will do the...
Richmond-Ruud-Rheem
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
It sounds like you've read the manual.
And cleaned the burner parts according to manual.
You replaced thermal reset, but system is still tripping, so either the gas valve and tubing are bad, the thermocouple is bad, or there is a problem with gas pressure, or gas line.
Post question on pro water heater forum:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Apr 08, 2011 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Richmond power vent water heater won't stay lit. I've reset the unit several times and the unit will run for about 10-15 minuets then shuts down (into lock down). Then I have to shut it off unplug it and...
Mar 29, 2010 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Water Heaters Logo
166 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
