Question about Kalatel DSR-2000e Single-Channel Digital Video Recorder
How do i reset password on d9108bh dvr to factory
How to reset my pass word on my Samsung Security Video System SDH-B74041
For nearly all Samsung Security DVRs, the default password is 4321. If it hasn't been changed since setup, then you can just use that to access the DVR. The default password is included in the reset procedures for completeness. If you have changed your password or access code for your Samsung Security DVR since it was setup, or if you changed it during the initial setup, use that password in place of the default password. The password will be the latest password that was set on the DVR. If no password has ever been set, then it will be the default.
Samsung Security DVR Reset Procedure #1
  1. Reset the unit to factory by pressing both [MODE] and [PTZ] button for 5 seconds
  2. Then enter the 4321.
Samsung Security DVR Reset Procedure #2
  1. Reset the unit to factory by pressing both [MODE] and [CH2] button for 5 seconds
Samsung Security DVR Reset Procedure #3 This reset will work on Android based DVRs only. All steps are performed on the device itself.
  1. Turn the device Off
    Wait 2 minutes
    Press and hold the following buttons
    • POWER,
    • HOME
    • VOLUME UP
  2. The unit should power on. Once it does, you can release power.
  3. Use the volume UP and Down buttons to select "Wipe/Factory Reset" from the recovery menu.
  4. Activate the reset using the HOME button.
    When the DVR goes through it's setup again, it will be at factory defaults. The password will be 4321.
Samsung Security DVR Reset Procedure #4 This reset will work on SDR models. It may also work on other models.
  1. With just the cameras showing, press the following in quick succession using the remote:
    • Freeze
    • Alarm
    • Freeze
    • Alarm
    • Freeze
    • Menu
    • Enter
  2. Make sure you press them quickly, one after the other. If it doesn't work the first time, try doing it several times. It can take many tries to get the timing right. If/when it works, you should get a screen that gives you the option to reset.
Samsung Security DVR Reset Procedure #5 This reset will work on SDR models where procedure #4 failed. It may also work on other models.
  1. Press the DVR Button to place the system in DVR Mode
  2. Press:
    • Freeze
    • View
    • Return
As with Procedure #4, you may need to press Freeze, View, and Return in in quick succession a few times to get it to work. The timing can be tricky.
These reset procedures cover many Samsung Security DVRs, but not all. I will add reset procedures to this article as they become available to me. By design, Security DVRs are made to be secure, and not all of them can be reset by the consumer. If you have an urgent need related to your Samsung Security DVR, you should contact Samsung directly at their support page Samsung Support, or by calling: 877-349-3149. For less urgent matters, you can email them directly at Email Samsung Support. Support is available 7 days a week, 9:00 am - 9:00 pm EST.
Jan 08, 2017 | Samsung Home Security
How to reset password on DVR 8024
Here is a link to the manual if you need it: http://www.safeware.ca/download/DVR/SGD-860A_UserManual.pdf
Recommend use the user name 'admin' and password 123456 to see if it still works. Do not see a factory reset discussion.
Apr 19, 2015 | Televison & Video
How to reset the password or the H264 DVR to factory settings for Digital ID view?
Will need a model number. H264 is the compression format.
Dec 11, 2014 | Home Security
How do i reset password for h264 dvr
Hello, There are two things you can try, the default password for the system should be 000000. If that is not the password if you go into the System Menu under the "General" tab there will be an option that says Factory Defaults, this will reset the settings to the default and should remove any password that is in place, but be warned that this will possibly wipe the dvr.
May 08, 2014 | Digimerge H264 16 CHANNEL DVR WITH USB CMS...
Cnb dvr password reset
Welcome To CNB Technology.
www.cnbtec.com/en/html/support/faq.php?classify=B
Ex-factory ID and Password. Ex-factory ID and ... When running DVR program, an error message comes up and the program stops. Check if the driver is installed ...
CNB DVR hard drive failure/password reset - • CCTV Forum
www.cctvforum.com/viewtopic.php?f=3&t=45061
Mar 2, 2015 - 11 posts
Hello all, I purchased/had installed for my home a camera security system using theCNB HDE2424DV and Nuvico dome cameras. It has 8 ... CNM Secure Primus (8ch) password
Feb 13, 2013
Is Q-See Equipment any good?
May 1, 2012
CnM Secure 4 Channel H.264 DVR
May 5, 2011
I need help selecting a DVR
Jan 18, 2010
More results from www.cctvforum.com
Feb 14, 2014 | Home Security
Pacom pdrh-420 4ch digital video recorder forgot password how to reset again
To reset the unit, you will need a straightened paperclip:
  1. Turn the DVR off.
  2. Poke the straightened paperclip in the unlabeled hole to the right of the Alarm Output connector, and turn the DVR on.
  3. Hold the paperclip in place until the DVR turns on and live monitoring screen appears.
  4. Remove the paperclip. All of the DVR's settings are now at the original settings it had when it left the factory. There is no default password.
Sep 11, 2013 | Cameras
Samsung dvr 7162 need to reset password
please help me to reset password Samsung DVR SHR7162
Dec 24, 2012 | Samsung Shr-7162-15t Dvr Shr7162 Techwin...
Menu pasword
The manual says:
You cannot enter MENU by forgotten password.
- If you forget the password, you shall reset SHR-2160/2162/2080/2082 DVR to
the values set at the factory. Keep pressing both the "MODE" button and the
"PTZ" button on the left for 5 seconds, Keep pressing both the "MODE" button
and the "PTZ" button on the left for 5 seconds. The password default is "4321".
Jul 23, 2008 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
Samsung SHR-1040 DVR
try resetting the system and reprogramming if that does not work you may nee to find a factory authorized repair facility in your area.
•Factory Reset Hidden Key :
Mode Key + CH 2
•The Password and all setting
value will return to the initial
default value.
•Default Password is ‘4321’ .
mj
Feb 10, 2008 | Samsung 4 Channel Dvr
Televison & Video Logo
401 people viewed this question
Top Kalatel Televison & Video Experts
Electro Med Services...
Are you a Kalatel Televison and Video Expert? Answer questions, earn points and help others
