Question about Universal Remote Control Televison & Video
Jumbo universal remote code for t.v seiki
SOURCE: Sharper Image Jumbo Universal Remote
i just pirchased a Sharper Image Jumbo universal Remote but i can't find a code for the Pioneer DVR 541H is DVD recorder. Does anyone have this code or  a suggestion?
Posted on Oct 26, 2008
SOURCE: INSTRUCTIONS NEEDED FOR THE SHARPER IMAGE - JUMBO UNIVERSAL REMOTE
The "auto" mode isn't quite presented correctly in the documentation or posts I've seen...after MUCH trial and error (and about 3 hous) I've been able to set-up ANY infrared device, either by "auto" or learn. (Although maybe not "fully".)
AUTO Method
1. Press & Hold (about 3 sec.) the [DEVICE] button on the JUMBO Remote....llight will stay solid.
2. Now just press the [POWER] button (only) ONCE while pointing at the device...it will start sending codes approximately every second. (Don't keep pressing the power button as instructions indicate.)
3. TIMING IS EVERYTHING HERE. (It may take 5 minutes to find your devices code.)
4. AS SOON AS the power goes off...press the [ENTER] button on the JUNBO Remote.
5. Now pressing the [POWER] button should power up/down the device.
---- any buttons not programmed will have to be handled using the LEARN method ---
LEARN Method
1. Press & Hold (about 3 sec.) the [DEVICE] button on the JUMBO Remote....it'll stay solid.
2. Press the [LEARN] button on the JUMBO Remote. (light will immediately blink rapidly.)
3. Now Press the {NEEDED} button to program. (light will stay solid)
4. Now (1 to 2 inches away) have the ORIGINAL Remote pointed at the JUMBO Remote and press the {DESIRED} button on the ORIGINAL Remote.
5. It blinks rapidly while sending...then a slower steady blink once "LEARNED" correctly.
*** Not all buttons work properly with the "LEARN method". Some you will need to "associate" with an alternate button on the JUMBO Remote. ***
I sincerely hopes this helps anyone & everyone.
Posted on Dec 16, 2008
  • 4 Answers
Hello kls1996... programming your remote is rather easy. The easiest way (thanks to The Sharper Image Jumbo Remote being a LEARNING SMART remote) is to do the following:
1 - Point the head of your Sharper Image remote at the head of your Sanyo TV remote (nose to nose so the clear bulbs on each remote are facing each other).
2 - Press the "TV" button on your Sharper Image remote (located in the upper left-hand corner).
3 - Hold the "LEARN" button on your Sharper Image remote (located in the left edge under the volume buttons) until the red light flashes.
4 - Press the key on your Sharper Image remote (e.g. Volume Up or +VOL)... the red light will go solid (indicating that it is waiting for a signal from the other (in your case Sanyo) remote.
5 - Press the key on your other remote (in your case the Sanyo remote) that you want programmed in your new Sharper Image remote... the red light will flash rapidly again.
6 - Repeat step #4 until you have programmed each key.
7 - When done... press the "LEARN" key on your Sharper Image remote. Your Sharper Image remote should be programmed to operate your device (in this case, your Sanyo TV).
NOTE: You can program other devices such as your VCR, DVD, VHS, SAT, CABLE, etc. and not just one device.
Posted on Jan 16, 2009
SOURCE: lost codes for jumbo universal remote
press code search when it lights up press devise u want till light stays red then keep pressing power button slowley till it turns off the hold down enter for a sec and its set.
Posted on Apr 09, 2009
  • 788 Answers
SOURCE: codes for jumbo universal remote
Codes for jumbo universal remote
Sorry to here about your emerson remote problems.
The best thing to do is go to emerson.com and search for your device by number.
You will be able to find and print all the codes you need for whatever devices.
Hope this information has been of some help.
Please rate your technician, as they take the time to answer your questions. !!
Even if you disagree, it shows us that you have taken the time to answer.
Thanks,
John Ray
john@johnrraycomputer.com
Posted on Jun 29, 2009
Broksonic sdtv owner manual model #ctgv-3249 trying to set up jumbo universal remote
Use code search on your jumbo to find a code that works. If a search through all codes stored in the jumbo fails, you may have to use a different universal remote. All universal remotes do not store all possible codes.
I did not find code(s) for Broksonic in my jumbo list.
Jan 30, 2017 | Televison & Video
I want to know the code for a seiki television for a illumibeam jumbo universal remote
An applicable code would be in the remote. If code search doesn't work, you may have to try a different universal remote. All universal remotes do not contain all possible codes.
Jan 09, 2017 | Universal Televison & Video
One for all universal remote i am trying to program my seiki television. I lost the original remote and the power button on the television is broken so I cant turn the television on
Always better to buy a genuine replacement. The problem is that if I remember correctly, Seiki don't actually make the television, which is why it never features in the Remote Code Lists. I have just checked three sites.
http://codesforuniversalremotes.com/3-digit-universal-remote-codes-for-tv/
http://removeandreplace.com/2013/11/10/universal-remote-control-codes-list/
Brand new original SEIKI seiki TV Remote control work for almost all ...
https://www.amazon.ca/original-SEIKI-Remote-control-almost/dp/B00BJ2MC0E
I gave my mother a sieki television for Christmas my two little girls are always using the remote and letting it drop so I needed to find a replacement remote asap.
SEIKI TV Remote Controls ' SEIKI Replacement Remotes for TV, DVD ...
https://www.replacementremotes.com/SEIKI/Remote-Controls/ ReplacementRemotes.com offers SEIKI remote controls for sale online including remote controls for TV and many more.
Google seiki remote control codes
Jan 09, 2017 | One For All Televison & Video
Lost manuel how do I program it
Jumbo Universal Remote Control
Danny, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Innovage Jumbo Universal Remote
http://www.jumboremotecontrol.com/innovage_jumbo_remote_manual.PDF
How To Program The Innovage Jumbo Universal Remote Control
JUMBO Universal Remote Codes Codes For Universal Remotes
May 03, 2016 | Innovage Jumbo Universal Remote Control
How do i program the innovage jumbo universal remote
Jumbo universal remotes are essentially the same regardless of the name at the top. If you have a device you want to control, start by turning on that device. Press and hold CODE SEARCH until the red indicator stays on, then release the CODE SEARCH button. Press and quickly release the device button, e.g, TV. Point the remote directly at the device. Press the power button (in the upper right corner) repeatedly until the device responds, e.g., changes channel. Press ENTER and release to install the code. If no result, your Innovage jumbo remote may not have a suitable code available.
Oct 23, 2014 | Innovage Jumbo Universal Remote Control
Seiki tv codes
If you wish to get more, try the following links. Both the sites linked have set-up code list & set-up procedure to many popular brand remote controls.
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Jan 22, 2014 | Innovage Jumbo Remote Control
LG codes for a jumbo remote
Check these codes. 0004 0050 0009 0005 0227 0338 0012 0057 0080 0156
Oct 22, 2012 | Jumbo Universal Remote TV DVD VHS...
Bigmatters universal jumbo remote ero4307j
manual de codigos del control bigmatters jumbo universal mod ero4307j
Jul 05, 2008 | Televison & Video
Televison & Video Logo
87 people viewed this question
Top Universal Remote Control Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
