Question about Drills
Size of belts for craftsman drill press model #55-5919-6
rowdy45176
  • 2176 Answers
SOURCE: how to remove chuck from drill press
I just looked at a breakdown for this tool and it is not that clear. But to get an owners manual you can go to Searspartsdirect.com and type in your model number and look at the same schematici I did and also order a manual for about 7.50. Usually though on a drill press like that it would be a morse taper. Do you see a slot cut thru the spindle on both sides, if so there should be a tapered key that came with the unit. In that case what you would need to do it put the key in the slot and tap it with a hammer to remove the adaptor and chuck. Let me know if I can help further
Posted on Jan 03, 2009
  • 10865 Answers
SOURCE: Replace drill chuck on 23 year old Craftsman 8" drill press
Yes it does have a Morse taper and you can remove it by gently hitting it with a rubber or nylon mallet.
Posted on Feb 08, 2009
rowdy45176
  • 2176 Answers
SOURCE: Craftsman Drill Press chuck problem
It is unless there is a tang on the end. What you need to do is thoroughly clean the parts with something like brake clean to remove all the oil and then wipe with a clean paper towel. What I do it put the arbor into the drill press or the chuck onto the arbor and then put a 2x4 on the table and press the parts together or if you have enough room fully retract the jaws and use the block of wood to "tap" the parts to seat them. Let me know if you need more assistance
Posted on Aug 25, 2009
Testimonial: "Thanks rowdy45176. Your solution was spot-on. I cleaned both sides and them , with the chuck jaws fully retracted, tapped it with a plastic mallet"
  • 10865 Answers
SOURCE: I need a manual for a Craftsman Drill Press model
hello. go to sears.com and you can download what you need.
Posted on Sep 14, 2009
rowdy45176
  • 2176 Answers
SOURCE: Craftsman 10" bench drill press chuck wobbles
If this is a new tool I would take it back and get it replaced. The only other way to eliminate this problem is to determine if it is the spindle or the chuck and replace the defective unit. Warranty works better.
Posted on Oct 08, 2009
Where can I get the users manual for a Craftsman drill press 113.24520
Search the internet for:
Make + Model + the word "Manual"
or contact manufacturer support.
Apr 26, 2016 | Craftsman Drills
What is the Chuck Taper Size? MasterForce model # 240-0064 12" Drill press
Masterforce is no longer supplier of power tools, they are a cheaper line of Makita, and maybe craftsman.
Jan 08, 2016 | Drills
Hi I have a peerless pedestal drill press model #1516f. I cannot find the replacement belt sizes for the 2 belts? Can anyone help? Cheers Jason
hi jason try going to a car fan belt specialist ,, one that stocks many sizes..take your old ones in to match them with.. as an example search on line as i don't know where you are i can not give more specific info on location.. as an example this web site http://www.totalrubber.com.au/
or try repco car spare parts
Rubber Hose PVC Hose Rubber Matting
i assume your belt is an "A" size
regards pete
Feb 26, 2015 | Drills
GLENTANNER MODEL ZQ116 DRILL PRESS. how do Iknow what size belts are as they are old, cracked and frayed.
Your best bet is to take the old belt with you when you shop for a new one. The sales clerk should be able to match it up.
Nov 26, 2014 | Drills
I want to put a taping head on my drill press. What is the spindle size of a craftsman 12" drill press?
without the model number I am going to guess that as a general rule most smaller drill presses are a #2 morse taper socket and a #2 jacobs taper arbor (where the chuck presses on) you should have been supplied a knockout pin to remove the chuck assembly from the internal socket.
Apr 15, 2011 | Craftsman 12" Drill Press (21914)
There isn't a manual for our craftsman 21914 drill press. We need to know how to put it together.
Use this link to get to the Sear page showing exploded parts diagrams for your drill press.
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Drill-Parts/Model-315219140/0247/0713080?searchedModel=21914&blt=
If you click on the tab to "search by part description" you can enter "manual", then you can order it for $2.16, it you still need it.
Good luck, Al K
Feb 02, 2011 | Craftsman 12" Drill Press (21914)
Trying to find out what size chuck key for the 11324540 drill press.
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Planer-Parts/Model-35123378/0247/0734000/10052373/00002?blt=06&prst=&shdMod=
Check out the web site, type in the numbers you have here and you should find the part or the number, size, whatever. Check it out. If the web site doesn't work, just take the first part of it and dump the rest.
Nov 12, 2010 | Craftsman 11324540 11324560 Drill Press...
I need a manual for a craftsman drill press model # 11321371
Manual....Chuck drill bit, select a drill speed, drill!
Aug 28, 2009 | Craftsman Drills
CaN'T REMOVE A 1/2'' CHUCK FROM A 13'' FLOOR MODEL CRAFTSMAN DRILL
Try heating it up with a torch and tapping it off with a punch
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 24, 2009 | Craftsman Drills
Drills Logo
53 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
