Question about Dell 1470 (W9284) 802.11a/g/b Wireless Adapter
My broadband wireless adapter isn't connecting
I ve enabled the radio, but whenever i connect to the internet thru my local network,it keep telling me that that the radio on my 802.11 network adapter is still disable.Use the hardware radio control switch to enable it.;when i check the radio,it stays enabled.ican't connect.what mut i do?
  • 4 Answers
Re: my broadband wireless adapter isn't connecting
Hmmmm... this is quite hard endyananna... Is your computer have its own third party Wireless Software? Sometyms Built in adapters on laptops come with their own wireless software that manages the wireless connection. First thing is to locate that program by going to network connections and checking the name of the adapter. Once you found the name, go to the all programs and look for that software there. Try to connect using that software first. In case that it wont work then you have no choice but to use Wireless Zero of Windows. go to run, type services.msc, enable it , start the service, go to network connections, go to wireless cx properties, put a check on use windows to configure my wireless network settings, click ok, right click on wireless network cx, open up view available networks, you should be able to connect after that. In case that it didnt work. Then I have a hunch that youre computer have another software that configures your wireless network connection and that prgram must be used. Good Luck then. If you have any problems, you can always call your OEM for support.
Posted on Sep 27, 2007
0 characters
3 Points
Hello My WNA3100 Wireless adapter keeps dropping my connection about every 4-10 minutes and the solution is to unplug the adapter and plug it back in. This has become more than a slight annoyance and
desktop or laptop computer ?
try moving your computer to a different area to gain maximum frequency / range
Click start control panel network and internet look for wireless
"Allow the wireless LAN radio to be turned off when inactive" might be ticked untick it
Right-click the wireless icon in the lower right corner of the desktop.
From the pop-up menu select "Enable."
This activates the wireless Internet options but it does not turn on the wireless receiver.
Push down on the wireless button or wireless switch on the top of the keyboard.
After a moments time the switch or button lights up, signifying the computer is ready for an Internet connection.
click start Control Panel - Network Connections - right click on 'Wireless connection'
(or similar) and click 'enable'.
if this fails to fix the problem
try unplugging the usb wireless device
uninstall the netgear software in the add/remove programs in the control panel reboot and then reinstall the software then plug in the usb wireless adapter
hope this helps
Oct 04, 2012 | NetGear WirelessN 300 USB Adapter WNA3100
Compaq presario v3000
Unless you are purchasing an old desktop PC, I am pretty sure any system you purchase these days (whether it's from Dell or whatever) have atleast an integrated LAN Rj45 connection on the motherboard.
The cheapest computer on (the Inspiron) has an integrated LAN connection for example.
Hope this helps,
Sep 04, 2009 | Compaq Network adapter
I have 2 PC in local network via LAN. One of this PC1 use D-link DWL-G122 wireless g usb adapter connected to other wireless network. Can i get funcional internet on PC2, using this other wireless...
yes, from the network connections page right click on the network card that you use to connect to the internet. select properties. go to the advanced tab and enable network connection sharing. (it will say something similar to "share my internet connection with other computers on the network" varies slightly with diferent versions of windows)
Aug 18, 2009 | D-Link AirPlus G DWL-G122 802.11g/b...
Broadband connection
You should find the manual that comes with the Router. It will have good instructions on the details to configure this.
Basically you will use your browser on your desktop to connect to a web page within your nb504 router.
You will turn on wireless connections and enable security plus give your wireless network a name.
Once that is done you will configure security on your laptop to connect to your wireless network.
Don't skip the security bit or your neighbors will be able to use your internet connection for free.
The default settings in modem devices are really good these days so follow the recommendations in your router manual and you should be able to figure it out.
If you can't find your router manual you should be able to download it from Netcomm.
Hope this helps
Jul 11, 2009 | Sabrent USB 2.0 NT-USB20 Ethernet Adapter
USB Broadband to wireless router through desktop PC
If I get you right you are useing a 3g Internet connection and have a router wich conets the 2 computers together, the problem is that you can't share the internet connection.
Without any information about the operateing systems I can tell you the idea:
First you need to disable DHCP server on the router and use static IP addresses on both PC, the IP address should be something like
Network mask:
Network mask:
Default gateway:
In this IP configuration above PC1 has the 3g modem connected.
This was the easy part, hard part is to share the internet connection on the network, that's a little different ritual on every operateing system, try to use google to get your specific one.
However there's a much more easier way to solve all your problems if you can't make it work, but it costs money. All you need to buy is a 3G router and that will do the same thing for you what your old router did.
I did a little search for you on Australian Ebay to see what you can get.
But I'm sure you have your own cheapbfavourite source of computer hardware as well.
Hope this will help you sorting out your porblem.
Nov 26, 2008 | Sabrent USB 2.0 NT-USB20 Ethernet Adapter
General Networking question
lets see here, your NVIDIA thing is for your ethernet port in your computer.
the wireless PCI adapter, is well, a wireless adapter, its used to connect your wireless, and a 1394 Net Adaptor Connection is basically Win2k/XP's way of telling you that you have a Firewire interface installed in your system.
so, if your going wireless, you dont need NVIDIA, and as your device manager shows that it has a red x on it, it shows that its disabled. as for everything else, i wouldent worry about it.
May 08, 2008 | Network & Wireless Adapters
My laptop cannot connect to my local network (LAN)
Assuming you initially set up the router using the wired lan adapter and lead, enabled DHCP in the settings. First stand right next to your router; Dells wireless is a little tempremental, go to control panel and in there should be Dell wireless monitor, open this up refresh it and see if it finds any wireless networks, if so try to connect. Dissable your wired network lan adapter. Go to the properties of your wireless card and on the TCP/IP line click properties again and ensure that obtain an ip address automatically is selected, press ok and restart the pc.
Sep 20, 2007 | Dell 1470 (W9284) 802.11a/g/b Wireless...
Dell 1470 (W9284) 802.11a/g/b Wireless Adapter Logo
473 people viewed this question
Top Dell Network & Wireless Adapters Experts
john smith
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Dell Network and Wireless Adapter Expert? Answer questions, earn points and help others
