Question about JVC NXD2 Mini Audio System
Locked jvc nxd2 - JVC NXD2 Mini Audio System
Ctr jvc tv reset lock
Contact the authorized service center for JVC. No other way.
Jan 24, 2014 | Televison & Video
How to turn off clock on jvc tv
Press the "Menu" button to set the lock code for your JVC TV. A padlock icon will appear on the menu display.
Press "Zero" to access the lock code function then use the left and right arrows to select the four-digit number for your code. Use the up and down arrows to move to the next area of the display.
Select the up or down arrow to finish your lock code then use the left or right arrow to save your lock code settings and exit the menu. You can return to this display if you forget your four-digit lock code and set another code.
Write your four-digit lock code down and keep it in a safe, private area.
Select the locked TV channel you desire to watch or want to unlock. A message will appear on the display requesting you to enter your lock code to unlock the channel.
Unlock your JVC TV by entering your lock code on the 10-key pad. The message "Invalid Lock Code!" will appear on the screen if you enter the wrong lock code.
Sep 06, 2012 | JVC Televison & Video
Sep 06, 2012 | JVC AV-32260 32" TV
My daughter has locked my jvc DVD digital theatre system and when I go to eject the DVD tells me it's locked how do I unlock it
You haven't given the exact model number ot your JVC DVD player here. Just download the user manual to your JVC model set, from net. It will have details about how to unlock the child lock to your set.
May 15, 2012 | JVC Televison & Video
Remove the prerental block on a jvc tv
Apr 03, 2012 | JVC Televison & Video
Jvc DVD is locked
Basic unlock for a JVC DVD player is to turn off the power, hold the stop button for 5 seconds, then press the eject button. It should say 'unlock'. Do the same to lock it.
Feb 21, 2012 | JVC Televison & Video
Reset lock
go into menu select channels and unlock them. or phone JVC tech helpline. better instructions or JVC e-mail them.
Mar 25, 2009 | JVC AV-32D305 32" TV
Locked jvc dvd cinema system th-s55
With the machine turned off (not off at the mains mind you) press and hold the stop button and then while still holding the stop button, press the eject button. Turn it back on and hey presto! This method will unlock it when its locked and vice versa. p.s its in the manual
Nov 05, 2008 | JVC DR-M1 DVD Recorder
JVC TV Control
enter your menu and turn off parental control to un lock front panel controls.
Jul 14, 2008 | JVC AV-27D302 27" TV
Jvc player wont open door its saying locked
I cannot unlock my JVC DVD player the work lock appears in the window
Nov 11, 2007 | JVC TH-M505 System
JVC NXD2 Mini Audio System Logo
13 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
