Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
Craftsman GT5000 W/22hp B+S surges and dies when warm
I have a 2002 GT5000 that was running well after winter. It started surging after several hours use and the problem got progressively worse till the engine died. Cleaned out carb, fuel solenoid is clicking, replaced fuel/oil filter and plugs, gas is flowing to the carb and it has a good spark on both sides. It starts great but after 10 minutes or so starts suging and eventually engine cuts out. When warm I can restart but then it dies immediately. Choke made a difference before carb cleaning now has little if any effect. Any help is appreciated.
  • Anonymous Mar 20, 2014
    350 Husqvarna chainsaw with replaced hose between priming bulb &carb,new spark plug,is hard starting,then runs good for minute,dies and is hard to start again.Tried choke on and off(checking sp. plug for signs of flooding,etc).Carb diaphrams maybe?
    President:
  • 957 Answers
Replace the spark-plug, check the quality of the fuel(gas that is mixed or was stored more then three months is stale and wont fire correctly) make sure the fuel and air filter not clogged. If there is no change then your problem may be more technical, a nest may be restricting the govenor or you missed something with the carb and there still is debre causing it to stall.
Posted on Apr 24, 2009
I have a 24" snowblower that surges after 1 minute of running, after 3-4 minutes stops and will not restart until several hours later, does the same thing over and over
This sounds like a choke issue. Do you have a choke on that engine?
The purpose of a choke is to allow for a varying air:fuel ratio depending on how hot the engine is. A cool engine needs a more rich mixture of fuel to air. Once the engine warms up, it runs best with more air. The Choke is a mechanism that allows the operator to manually adjust this mixture. Generally, the choke is closed to start a cold engine, then is opened in 2 or 3 stages as the engine warms up. As the operator, as the engine starts to run smoothly, you would actuate the choke to the next notch, changing the fuel:air ratio so more air is mixed in with the fuel. It's probably best to give the engine a few minutes to warm up while you progress through the choke stages until it's fully open providing the best mixture for operation prior to beginning to clear the snow.
If you follow that process and the engine stalls when the choke is opened, then you need to clean your carburetor.
Oct 18, 2012 | Garden
Car Surges then dies at a stop only in hot or warm weather
Think about what you just said. Only does this in times of higher temps out BUT never in winters cold. Doesn't that seem strange to you. Well I guess it does, huh. Anyway, know these systems helps. When engine is started, the temp sensor tells the computer it needs to place the engine to cold start mode. It does this and extra fuel is put into the cylinders to keep it running like a choke on the carbureted engines. But those you can turn the choke off or it does this automatically from the warmer engine. If in fact the temp sensor is not telling the computer it's warm enough to be taken out of cold start mode, it keeps dumping excessive fuel into the cylinders an flooding the engine causing it to surge and then die, because it's flooded. Therefore, the temperature sensor is faulty and needs replaced. Do that and drive on.
Aug 17, 2017 | Acura Integra Cars & Trucks
I have a John Deere Hydro 175. It will run for 10mins then starts surging and dies. It appears to be overheating. What would cause this?
during the winter a mouse nest might have formed under the tin cover that would stop air flow to the cooling fins
Apr 29, 2012 | John Deere Garden
2002 ford explorer surges and dies
Clean the throttle body bore and plate of any carbon and the Idle Air Control may be going bad .
Oct 03, 2017 | 2002 Ford Explorer
Mower surges its a 5.5hp craftsman mower
Carburetor possibly needs cleaning. Initially, remove air filter, start mower and while it is running, spray some aerosol carb/choke cleaner into the carb thru air intake area. Continue doing this several times but not too fast or heavy to make it stall and then spray it heavily until engine dies. Let it sit for several minutes and then try a restart. If no difference in performance is noticed, carb may have to be removed and cleaned in bath-type cleaner and governor settings will need to be checked also.
Please vote on this solution.
Sep 13, 2010 | Craftsman Garden
Engine is surging when in idle
clean out the carburetor jets re-assemble then adjust fuel mixture screw until it runs correctly
Apr 05, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Seems like bike is running rich
The idle problem sounds like an idle adjustment. The surge may be the throttle cable, try spraying a lubricant from the top of the cable and work it back and forth to loosen and release any debris.
Jan 22, 2009 | 1999 Triumph Daytona 955i
1987 F 150 Problem: engine idle stalling and then surges
I had the same symptoms on my 1993 F-150. A friend of mine commented that he could smell gas in the exhaust. Eventually, it got to where it would start, then die after a few minutes and wouldn't restart after that (at least for several hours). It turned out to be a bad fuel pressure regulator that was causing it to flood. It was about a $25 part and an hour labor to replace (not difficult, just awkward getting to the hex head bolts).
Dec 14, 2008 | 1987 Ford F 150
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
1,058 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
