Question about Hitachi 65F59 65" HDTV
Picture Hitachi 65 inch. Picture will intermitantantly go black, or green, or you can see the picture but everything is red, or go to what looks like a thermal image, or the tv will shut off. In each case, it returns to normal about a minute later. Model of tv is 65F59A
  • 23 Answers
Some things are better to have an in-home TV repair man come and look at. This is defiantly one of those occasions. Check to make sure all your cables are secure. Trade inputs with your devices such as your DVD player, cable box, ect. If you are still having a problem call a repair man.
Posted on Apr 24, 2009
I have a 65" hitachi rear projection. I installed
This sounds like it is due to the lamp on the projector going bad. Replacing the lamp should fix the problem. Contact Hitachi to find a suitable replacement lamp.
Mar 08, 2011 | Hitachi Televison & Video
My 65'' Has a red double screen.
These sets have several common problems which are listed below.
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find the fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 31, 2010 | Hitachi 65F59 65" HDTV
No picture, siren type noise as restarting
My Toshiba dlp 62hm116 was used for 3 months then stored for 2 years, I turned it on yesterday and it makes a loud grinding noise which I think is probably from the exhaust fan area and the picture is black except white at both vertical sides. It worked fine the last time I used it 2 years ago. Any ideas?
Jan 13, 2010 | Toshiba 62HM95 62" DLP HDTV
53 inch projection tv...seems like the color red and color blue have shifted giving me a picture with red and blue shadows
For CRT projection TV's, this indicates that the Green picture tube is burned (warn out). The less green that strikes the screen, the more redish the image will look. You will need to find an old school TV repair shop that knows how to replace picture tubes.
In the case of a DLP style TV, the color wheel needs replacing.
Dec 29, 2009 | Hitachi Televison & Video
Hitachi 65F59 65-Inch CRT Projection HDTV picture skewed.
The convergence output IC's have failed and need to be replaced. Sometimes when they go biasing resistors burn open also. These are large amplifiers mounted to heat sinks and have as many as 18 pins soldered into the circuit board. Better be handy at desoldering even if it's only the IC's that are bad.
Jul 10, 2009 | Hitachi Televison & Video
Hooked up a hdmi/dvi cable
try using the red- blue- green high def connections
Dec 08, 2008 | Hitachi 57F500 57" Rear Projection...
Toshiba 65H80 has yellow hue.
Check you HD inputs or source. Sounds like the red stream is missing; maybe a loose cable.
Nov 17, 2008 | Toshiba 65H80 65" Rear Projection...
Double focused, red and green, bow in picture top and bottom
hi
You have a convergence problem
If the set has auto focus and will not complete its cycle.
The Auto focus module is bad, (expensive)
If it completes and the problem is still there.
Then check for bad conv. drivers (stk****) or cold solder joint on one or more of the 3 drivers pins.
Guy9
Jul 08, 2008 | Hitachi 65S700 65" Rear Projection HDTV
Pictue is dark as hell
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Oct 27, 2007 | Hitachi 65F59 65" HDTV
Hitachi 50UX57B 50 inch Rear Projection smearing...
try this
Sep 18, 2007 | Hitachi 50UX57B 50" Rear Projection...
Hitachi 65F59 65" HDTV Logo
193 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
