Question about Refrigerators
How big is the whirlpool gold refrigerator gx5shdxtq00?
SOURCE: WHIRLPOOL REFRIGERATOR
my refrigerator gold is running but not cooling I have the model number and serial numbers if that is helpful please help
Posted on Sep 15, 2008
EllaWatson25
  • 725 Answers
SOURCE: Whirlpool Gold refrigerator water leaking
If it's flooding, it's NOT the drain pan. It's probably the water valve has gotten stuck in the open position. Hope this helps!
Posted on Aug 21, 2009
woodchuck789
  • 4070 Answers
SOURCE: whirlpool gold side by side is thawing out and won't stay cold
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Posted on Oct 27, 2009
  • 105 Answers
SOURCE: my whirlpool gold side by side refrigerator forms
the drain in the back of freezer is blocked
dismantle front of evaporator and deice drain
maybe so hot water over this should fix problem
whendrain is clear water should run donwn hole and collect in evaporator tray under fridge
you may need to mop up after you finish
Posted on Nov 21, 2009
aasc
  • 1606 Answers
SOURCE: whirlpool side by side refrigerator laeking form
It sounds as though your filter which screws into the front at the bottom kick plate is bad . The rubber seals on them tend to go bad causing them to leak into the drip pan and causing it to overflow . This will appear to be a leak when in actuality , all you need to do is replace the filter .
Posted on May 29, 2010
Whirlpool Botton Freezer GX5SHDXV Care Manual My new refrigerator did not come with a Care Manual. I have an "Install Manual", however I need a Care Manual. I need to see how to adjust the...
Hello Barbarabee,
The proper thing to do ...
Contact your customer support, register & allow them to help you... (improve their service)...!!
However...
Generic model instructions are available FREE
with the logical variation of line voltage (USA values)
Take a look:
Whirlpool GX5SHDXTQ00 Use Care Manual
(should cover drawers & shelves... just fine)
Hope this helps
Carnac the Magnificent
Oct 04, 2017 | Refrigerators
Need help removing the ice bin
It is not a big deal. All that is needed is a hard pull if it is packed with ice.
Apr 21, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
My whirlpool gold side by side refrigerator forms a big peice of ice at the very bottom then the ice ends up melting and goes all over the floor whats wrong?
Nov 11, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
I have a whirlpool gold refrigerator. The ice
I just want to know if you solved your problem because I have the same problem.
Thanks
Oct 26, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Aug 19, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Apr 07, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
112 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
