Question about Sanyo Televison & Video
Remote codes tvremote
Cannot program my Telus slimline remote to a sanyo tv
SOURCE: Sky Remote code for Sanyo LCD TV
I HAVE FOUND THE CODE AND SKY NEVER HELPED THE CODE IS AS FOLLOWS DEPENDING ON HOW OLD YOURE REMOTE IS 0065 IF YOU HAVE AN OLD REMOTE TAKE THE FIRST ZERO AWAY
Posted on May 01, 2009
SOURCE: programming my directv remote to operate this tv, codes dont work
I just programmed mine by using my direct tv remote...
Go to MENU on the direct tv remote
Then highlight HELP & SETTING and press SELECT.
Press SELECT on Remote in the left menu.
Simply follow the onscreen instructions to program your remote. IT IS IMPORTANT TO MAKE SURE YOU HOLD ON AND SEE THE GREEN LIGHT ON THE DIRECT TV REMOTE FLASH TWICE, otherwise it won't work....which is what I think is happening in your case. Good luck.
Posted on May 10, 2009
SOURCE: Just bought Sanyo DP32649 and can't locate code to
called cable company. problem solved.
Posted on Jun 14, 2009
fixya-bna
  • 9 Answers
SOURCE: Bought a new Sanyo tv and have dish network,
You need to call DishNetwork and program the remote. The remote does not know your TV code. Easy fix.
Posted on Dec 13, 2009
SOURCE: i need to program my telus remote to turn my 46"
Press and hold TV, then OK at the same time. Let go of TV and OK, top buttons should quickly blink red then stop press the code 1019 then hit the bottom right button marked ENTER or OPTIONS
Remote should now work with tv.
To control volume and power at the same time... Press and hold STB and OK at the same time, let go, red blinking up top enter the code 977 STB should blink red a few times.
Hit STB, see if TV volume adjusts Hit POWER. see if both STB (Set Top Box) turns off and TV turns off.
All should be good.
If both TV and STB do not turn on/off, repeat the process for the code where you enter 977
Posted on Feb 18, 2011
Tip
Samsung DVD-HD850, DVD-HD841 region free code
1. HDCP-Free: Requires only DVD Remote.
a. Power On DVD player, no disk inserted
b. Press "Angle"
c. Press "4", "3", "2", "7"
d. Press "Angle"
e. TV Screen displays HDCP Free
2. Region Free Hack: Requires AIWA/Universal Remote or PDA
The following instructions are for a Pocket PC
a. Download and install TvRemote
http://www.pdawin.com/tvremote.html
b. Download AIWA Mini Audio CCF file
http://www.remotecentral.com/ftp/ccf_templates/mini_systems/aiwa-mini-nsx999.zip
c. Copy the unzipped CCF file to your PPC
d. Run TvRemote on your PPC.
e. Switch to CCF mode on TvRemote
f. Open the copied CCF file. Screen changes to display
the remote.
g. With DVD switched on but tray closed:
i) Press "Repeat"
ii) Press "Program"
iii) Change remote screen and Press "Clock"
DVD display shows "ADJUST"
iv) Press "9" on DVD remote. I also pressed "9" on the
PPC remote so I'm not sure which one did it.
v) No visual indicators occur on DVD.
vi) Power off DVD.
h. DVD is now region free!
on Mar 07, 2010 | Televison & Video
I need the code to program a sanyo tv using the one for all untiveral remote URC-2060
If you do not have the code for you Sanyo TV then you can use the remote itself to get the code. It is a bit painful as you have to count the number of blinks it makes.
Follow the steps under getting your code.
Also it would help if you provide the model number of your sanyo TV in the comments section.
How to Program your One For All remote
Aug 17, 2014 | Televison & Video
Looking for a RCA TV Code to programe my Telus Remote
Use code search. We do not have code lists, just to many and they change constandly.
Feb 06, 2012 | Televison & Video
Does anyone know the remote code for a sanyo tv model dp42647 on a dishnetwork remote
Remote Codes ' MyDISH ' DISH Customer Support
https://www.mydish.com/support/remotecodes
Remote Control Manuals · Program Remote to TV/Other .... remote, product type, and manufacturer below to see the current known remote codes you should try.
My Dish remote needs programming for Sanyo TV ... - Directly
https://www.directly.com/.../dish-network-my-dish-remote-needs-progra...
My Dish remote needs programming for Sanyo TV, Model DP226649. My Dish ... Needcode. Alta asked this ... Dish Network • 16808 answers • 95% helpful. Code is ... Test volume control, if it works you're set ... try 590 it should work. tivosat.
How do I program my dish remote to work for my Sanyo TV.
https://www.directly.com/.../dish-network-how-do-i-program-my-dish-re...
Dish Network. How do I program my dish remote to work for my Sanyo TV. ... entercode 590 press pound then sat Then try to turn tv on and off then try volume.
How do you program a dish network remote to my sanyo tv? ' Ya
Jan 09, 2012 | Sanyo 42 in. LCD TV
I need the code to program my sunflwer remote with my sanyo tv
try these 014 / 032 / 045 / 075 / 120 / 121 / 122 /123 / 124 / 163 / 168 / 171 / 183 / 196 / 206 / 305 these are for all diffant sanyo tv and if your remote needs more than a 3 number code sorry can not help
Nov 28, 2009 | Sanyo Televison & Video
Programmin my remote
Direct TV Remote Codes 506 or 127 Direct TV (Remote Model RC-64RB) Remote Codes 11144, 11240, 11331, or 11610 Direct TV Remote Codes 506 or 127 Direct TV (Remote Model RC-64RB) Remote Codes 11144, 11240, 11331, or 11610 Direct TV Remote Codes 506 or 127 Direct TV (Remote Model RC-64RB) Remote Codes 11144, 11240, 11331, or 11610 You could try the one below..
I know the new HD boxes and DVR HD Boxes have the new remotes and they included Olevia on it and it works with the new models of Olevia's
Jul 15, 2009 | Olevia LT32HVM 32 in. LCD Television
I have a rca 311 w to program into a sanyo tv
Code For Model RCR311W
Code 1004 for Sanyo TV Code 1048 for Sanyo TV Code 1049 for Sanyo TV Code 1073 for Sanyo TV Code 1080 for Sanyo TV Code 1162 for Sanyo TV Code 1169 for Sanyo TV Code 1180 for Sanyo TV
Jun 05, 2009 | RCA RCR311B Remote Control
Sanyo tv codes
The codes listed by Sanyo for my TV won't work in my star Choice remote.
I tried 017 021 039 056 057 058 and 140 as listed by Sanyo.
Any ideas?
Dec 18, 2007 | GE JASRM24912 Remote Control
Televison & Video Logo
26 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
