Question about Dryers
DRYER GAS VALVE NOT OPENING - Dryers
  • Mark Nichols May 11, 2010
    what is it doing? did you change the gas coils on the valve... let me know what you have found ....
  • 38 Answers
Listen for a distictive click at the valve assembly. if you hear a buzzing it is the coils. if you here nothing, it may be something as simple as a door switch. need more info for a more difinative help.
good luck.....jay
Posted on Apr 24, 2009
Gas smell in maytag dryer
You have a gas leak from the gas valve being faulty. DO NOT use the dryer until you have replaced the valve! I have been doing appliance repair for 15 years and I have seen 7 homes that have burned down due to this very same problem. Please don't use the dryer! Here is the new gas valve to order.
Keep me posted!
Nov 05, 2012 | Maytag Neptune MDG5500AW Gas Dryer
Why does my kenmore 700 dryer smell gas
check the gas valve for leaking seals in the body of the valve,if o.k , then check the manifold tube at the opening just above the gas valve for correct air throttle opening,if not enough air mixture the gas wont burn completely and you will have a smell of gas too
Mar 08, 2012 | Kenmore 700 6972 Dryer
When coin put into machine dryer started spark
Make sure someone hasnt shut off you gas supply. Check inlet gas pressure to valve. Check to see if you have voltage to the gas valve . If you have all that then the valve has bound up or burned out the opening coil . It will need to be replaced. Has this been happening to this dryer often. Do you have problems with other dryers? It sounds as though you are in a laundro-mat as the use of coins to operate.
Jul 16, 2011 | Speed Queen KGS18AWF Gas Dryer
Gas valve solenoids not opening valve
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 28, 2010 | Maytag MDG2706A Gas Dryer
Stopped heating. Had service repair yesterday and he replaced the ignitor. Does not heat again, even though it warmed up briefly after the repairman completed the job. What else could the problem be?
Hello- Have him come back out (AT NO CHARGE) and check the gas valve coils these are probably not opening the valve, thus letting the gas out. It is a common issue and sometimes we, the Techs, need to sit there and watch the ignitor light the gas for a whole cycle. Often it will heat for 30 minutes and then the coils will stop opening the valve when told to by the timer. It is possible that there is a thermostat issue but less likely. Hope this helps, best regards.
Sep 27, 2010 | Amana ALG331RAW Gas Dryer
Igniter heats but gas valve does not open. should the flame sensor close or open to enable valve. could the drum over heat sensor (clickson?) keep it from opening.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 27, 2010 | Amana ALG230RAW Gas Dryer
Smelled mild gas odor after moving dryer. Replaced gas line connection. Still smell gas. Tried to tighten gas line have strong gas odor after running dryer. Does not seem to be heating
The gas valve should not be opening unless the glow igniter glows and sends a signal to the gas valve. I suspect a small leak in either the gas pipe or at the gas valve. You will have to get to the gas valve to perform a leak test. While the dryer is open, replace the igniter.
Jan 26, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Gas dryer heats for couple minutes then goes cold
sounds like gas valve is not opening. your ignitor has to pull 3.2 to 3.6 amps to open gas valve. check amps
Jun 22, 2009 | Kenmore 63942 Dryer
I have a Whirlpool Gas Dryer LGV6848AWO.
the ignitor bar that lights the gas might not be coming on, the coils that open the gas valve in the dryer might not be opening the valve, or the flame sensor might be bad which would not allow power to the ignitor. these are the most common problems with whirlpool gas dryers
Nov 28, 2007 | Whirlpool LGR3624JQ Gas Dryer
Dryers Logo
69 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
