Question about TP-LINK ACCESSORY TL-PS310U SINGLE USB2.0PORT MFP PRINT AND STORAGE SERVER RTL - TL-PS310U T... (6935364031060) Print Server
Lpr queue name - TP-LINK ACCESSORY TL-PS310U SINGLE USB2.0PORT MFP PRINT AND STORAGE SERVER RTL - TL-PS310U T... (6935364031060) Print Server
How do I configger the driver on OSX10 to auto remove the file when printing is finished?
Ensure you use TCP/IP to print NOT AppleTalk and you should not have an issue.
The LPD/LPR queue name is PR1
Feb 13, 2013 | TallyGenicom 8008 Laser Printer
Troy 8150 Printer
Yes I beleive you do need the -P
I use this on a HP 8150 I think it is Aust.version of you machine from the look of it
lpr -S 100.100.10.111 -P raw -o c:\temp\output.ps
Getting print q name
Press Menu until INFORMATION MENU appears on the printer display.
2. Press Item until PRINT CONFIGURATION appears on the panel.
3. Press Select to print out a configuration page
2nd page should be listed your print que name
or maybe just type the ip address of printer in browser and look in printers webpage.
Sorry for sketchy answer just trying to help!!
Oct 31, 2007 | Office Equipment & Supplies
Explorer cannot find d link, was working for a long time then quit, then working, now not working
Improve the Fixya.com experience for everyone by voting!
Unfortunately, you haven't provided any details as to the steps you've thus far taken. So lets start at the beginning and solve your problem step-by-step.
Step 1 Locate the Queue name, or Port name, of your printer.
Click here for instructions on locating the Queue name since you are using a DPR-1260.
Step 2 After you locate the Queue or Port name, you will want to write it down. (You can also highlight it with your cursor, and copy the info. This will allow you to paste it in to the wizard later on.)
Step 3 Click Start and then Control Panel. Locate the Printers icon. Click the Add A Printer icon.
Step 4 Click Add a Local Printer. Use this option only if you don't have a USB printer. (Windows automatically installs USB printers when you plug them in).
Step 5 Select Create New Port. For the port type, select standard TCP/IP Port. Click Next.
Step 6 Click the drop down menu for Device Type and choose TCP/IP Device.
In the Hostname or IP Address field, input the ip address of your print server. (The default address for most of D-Link's print servers is 192.168.0.10).
The PORT NAME field is purely for identification purposes. This allows you to discern the port you've created later on for configuration.
Step 7 Windows will attempt to detect the printer. Please allow a few moments for the operating system to do this.
Step 8 Highlight the radio button labeled Custom and press the Settings button.
Step 9 Click the radio button labeled LPR.
The LPR Queue Name field will now become available. Here you will need to enter the Queue or Port name that you acquired in Step 1.
Check the box labeled LPR Byte Counting Enabled. Click OK.
Step 10 At this point, you'll be brought back to the previous window. Click Next.
Step 11 Windows will now attempt to detect and install the printer driver. If Windows is unable to detect the printer and find a matching driver, you will be given the option of selecting a printer from a list of available printer drivers.
Step 12 In the left window you have a list of manufacturers, and on the right side you have the various models. Select the model that pertains to your printer. Click Next.
Step 13 Next you will be prompted to give the printer a name. You can leave the default Windows name, or you can create your own if you wish. Click Next.
Step 14 Once the printer successfully installs you will be given the option to print a test page. If the test prints then the print server is configured properly. Click Finish.
You should be linked up now.
All the best
Ben
Jul 11, 2011 | D-Link RangeBooster G DPR-1260 (DPR1260)...
I can't install my printer I have a mac What can I do?
Hi Good day!!
Here are the step to install printer in your Mac:
Open up System Preferences. Select Print & Fax.
Click on the + button to add a printer.
Go to http://lpr.byu.edu/printers/.
Click the desired printer.
Click the Properties link on the left of the page.
Select and copy the last half of the Network Name (everything after http://lpr.byu.edu/).
In this example, you would copy printers/N362ESCD/.printer.
Go back to the Printer Browser.
Select the IP printing tab at the top of the window.
From the Protocol: drop-down menu, choose Internet Printing Protocol - IPP.
In the Address: box type lpr.byu.edu:80.
In the Queue: box enter what you copied from the previous step.
Type the name you want the printer to have in the Name: box.
Choose Generic PostScript Printer from the Print Using: drop down.
Click Add.
The printer should be added to the printer list and is now ready to be printed to.
Oct 16, 2010 | Lexmark X4270 All-In-One InkJet Printer
Epson 10000 Doesn't print full image.
Hi, Go in the printer section under Control panel. Right click Epson 10000 icon, than Properties. Go to Ports. Click the port it is using. Configure port. Protocol must be LPR Queue name under LPR settings: type: print (small letters) Check LPR counting enabled box.
Try. It should work.
Jun 30, 2009 | Epson Stylus Pro 10000 InkJet Printer
Konica Minolta C450 status is offline. We have reinstalled the drivers, changed servers, changed network cord. We cannot print from our network computers to it, however, we can scan from the printer/copier...
Change the status to "Online". Sounds crazy, but most likely you print driver is set to enable "SNMP" on the port settings. Disbale this setting in the print driver, also set print Queue to "LPR" and name the LPR queue as "printer". Make sure there are no jobs int he queue when you change the port settings.
Jun 08, 2009 | Konica Minolta bizhub C450P Laser Printer
PSC 2175 wont work with print server
Please make sure that the printer is working okay if directlysd connected to the MAC computer. You may try this as well. hope this helps
Description
LPR (line printer remote) is a platform independent printing protocol that is associate with TCP/IP. It works by using LPR client software that communicates to a server running LPR services.
In terms of PSU, LPR printing will become the basis for all network printing while Novell print queues are phased out. Therefore, all Macintosh, Windows, and Unix computers will be configured to print through LPR.
Requirements
· The name of LPR print queue. This can be found by searching the LPR printer database.
· LaserWriter print drivers version 8.5.1 or newer
· The Macintosh must have a working TCP/IP networking configuration. (If the Mac can browse the web then it's working.)
· a server running LPR services or a printer that supports LPR printing. Most HP LaserJet printers support LPR. However, only the following LaserWriters support LPR printing:
- LaserWriter 8500
- LaserWriter 16/600 PS
- LaserWriter 12/640 PS
- Color LaserWriter 12/600 PS
- Color LaserWriter 12/660 PS Procedure
1.Open up the Applications folder from the OS X menu.
2.Open up the Utilities folder
3.Now open up the Print Center
4.If you have no printers installed you will see the following screen. Click on Add.
5.On the following screen, select LPR printing.
6.Now enter printhost.oit.pdx.edu for the LPR Printer's address.
7.Uncheck Use Default Queue on Server option and enter the queue name of the printer.
8.Select the printer model.
9.The completed settings should be similar to the following:
(LPR Printer’s address is the ip of our PRINTSERVER)
10.Click on Add
11.Your printer has successfully been installed. Test the printer by printing something to it.
Mar 29, 2009 | HP PSC 2175 All-In-One InkJet Printer
DEVICE STATUS OFFLINE
To solve this problem you'll need setup the printer up with LPR Protocol. Go to Devices and Printers. Right-click on the printer in question select Printer Properties. Go to the Ports tab. Find the port you've setup then click on Configure Port. In the block titled Port Name you'll need to enter the name of the Gigafast Print Server. It's normally 1P_PrintServ??????. The ?s are the last six entries of the print server's MAC address. Next, in the Printer Name or IP Address enter the assigned IP address, example (192.168.5.3). For the Protocol select LPR. LPR Settings: Queue Name: same as 1P_PrintServ??????. Lastly, check the box that says LPR Byte Counting Enabled. Now when you shutdown and restart the printer will remain online.
Apr 15, 2007 | GigaFast Ethernet EE171-PR Print Server
Configure to print
You may print without the D-Link Printer software in Windows 2000/XP. HereĀ“s how: Step 1 Go to Start>Settings>Printers>Add New Printer (WinXP - Start>Printers and Faxes>Add a Printer). Step 2 Select Local Printer. Make sure to uncheck Automatically detect and install my plug and play printer. Click Next. Step 3 Select Create a New Port and select Standard TCP/IP port. Click Next. Step 4 Enter the IP address of the router (192.168.0.1). Leave the port name with the default name. Click Next. Step 5 You will get a message saying that additional port information required. Step 6 Select Custom and then click Settings. Step 7 Set Protocol to LPR. Step 8 For the LPR Settings, queue name is lp. It is case sensitive! (LP lower-case). In most cases, check LPR Byte Counting Enabled. If you cannot print, then try unchecking this. Step 9 Select OK > Finish. Step 10 Continue with the Add Printer Wizard. Choose your printer from the list or click Have Disk and point to your printer driver disk.
Feb 16, 2006 | D-Link DI-704P Router
Open Questions:
See all TP-LINK ACCESSORY TL-PS310U SINGLE USB2.0PORT MFP Questions
TP-LINK ACCESSORY TL-PS310U SINGLE USB2.0PORT MFP PRINT AND STORAGE SERVER RTL - TL-PS310U T... (6935364031060) Print Server Logo
151 people viewed this question
Top TP-LINK Computers & Internet Experts
Martin Murray
Robert
Level 1 Expert
Are you a TP-LINK Computer and Internet Expert? Answer questions, earn points and help others
