Hp laptop g60 243cl
I can't turn it on. After turn on the powder button, I hear clicks, but it just won't turn on. Not sure if the fan is running, and it gets really hot after a while. Should I start with replacing te hard drive? Thanks!
Vegggie Boy
  • 28 Answers
SOURCE: Laptop running hot - Fan cycling on and off every 10-20 seconds
My guess is that CPU fan, it there is one, is not working properly and your computer is heating up. Is it turning off, too, occasionally after a period of time? Suggest a new CPU fan.
Posted on Jun 14, 2008
  • 285 Answers
SOURCE: compaq c500 blank screen, can heard hard drive running
You should replace the power supply, and clan out dust, and tighten connectors
Posted on Mar 11, 2009
Morikvendi
  • 56 Answers
SOURCE: HP Pavillion dv9700 won't power up
Try removing the battery and using only power cord to turn the laptop on. If that fails, try turning it on without power cord, just on battery.
If none of those work, then most probable cause of your problem is motherboard. Hopefuly you are either under manufacturer warranty or you have extended warranty with your vendor where you've purchased the laptop.
If your laptop turns on on power cord, but without battery, then battery is the problem. Also, if laptop turns on when it's only on battery but it doesn't when you plug ac cord in it, then the adapter is the problem.
Posted on Jun 01, 2009
  • 10 Answers
SOURCE: HP ZE2000 blank screen on start up.
you need to change the lcd inverter card of your note book
Posted on Oct 21, 2009
  • 11 Answers
SOURCE: hp dv3 boot: no bios, blinking screen
First, remove the Battery Pack from the Notebook and reinsert it after an hour.
Also, press the F8 Key on the Keyboard while turning ON the Computer.
Next, please select "Last Known good Configuration" from the menu.
Ensure that the Booting Priority is set to HDD in the BIOS Settings and also turn OFF the Quick Boot feature. This should resolve the issue.
Posted on Mar 01, 2010
Why won't my HP laptop stay on? I have a 2nd HP laptop and both models happen to have the same lithium ion battery so I swapped the battery of the working HP to the non working one to see if it wa
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Jun 15, 2012 | HP Computers & Internet
Hp pavillion dv2000 laptop has no windows n turn off need help to fix some help please
Please explain what is the problem. What you are saying makes no sense. What happens when you hit the power button? Does it boot up? Do you hear fans running, hard drive spinning, see lights?
May 24, 2012 | HP Computers & Internet
My laptop Hp G60 won't turn on the charger light
Maybe you have disconnected the small cable which connects the power button to the motherboard. Or your charging unit at the back of your laptop is faulty, take the cover off and click the button without it on maybe a alternative. Only other solution would be have you had a powercut recently?
regards,
jon
Apr 21, 2012 | HP Computers & Internet
Laptop won't turn on
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.
Apr 06, 2012 | HP Computers & Internet
HP 620 laptop shut down and won't start
Mar 24, 2012 | HP Computers & Internet
Pc turning off
Be more specific. Turning off when? What happens when you try to turn it on? When you have the power cord plugged in do you see any lights? When you press the power button do you hear the fan running, hear the hard drive running, see anything on the lcd screen, hear the cd drive Click once, see the light on the cd drive drawer turn on for a second or two when it clicks, hear any beeps or blinking lights?
Mar 21, 2012 | IBM Lenovo ThinkPad X40 Notebook
My hp 4510 powered off while in use and won't power back up. Can you tell me the problem?
Please turn on your laptop back and please check your CPU fan, make sure your laptop CPU fan is running without failure. That fan maybe set to auto on/off but make it sure that fan will running when your laptop become hot. I also recommeded you to flash lastest Bios to your laptop. You can gte Bios software at manufacturer website and find " Download Driver / Software "
Thanks for visiting FixYa. We answer your question for FREE. Please feel free to click on "YES" button in return. Have a good time...!
Thanks
Jun 30, 2011 | HP Computers & Internet
Hp won't turn on. When hit power, hear fan, HD run, few secs it turn off, try to to anything from hp list what to to, won' work.
Motherboard is defective & needs to be replaced with a new one.
You can find a replacement motherboard by searching on e-bay.com with the motherboard's model number. This could be found under the RAM.
Sep 21, 2010 | HP Pavilion dv6000z Notebook
Hard drive or fan click?
Very unlikely that you are hearing any fan turn off and on since these are temperature controlled varable speed devices, not serviced by a relay that you can hear.
Some hard drives are audible even when working normally so that is not necessarily a sign of a dying drive.
Check your system settings to see if the drive is set to park and turn off too often.
I keep mine set at 30 minutes so it isn't cycling more than needed or running all the time.
Jun 10, 2008 | HP Pavilion dv9000z Notebook
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
