Question about Waterway 1.5hp Hi Flo Above Ground Pool Pump # Ph1150 6
WATERWAY NOISY impeller - Waterway 1.5hp Hi Flo Above Ground Pool Pump # Ph1150 6
    Top Expert:
  • Waterway Master
  • 6,465 Answers
Loud motor check impeller for debris first then replace pump
Posted on May 01, 2016
2 Suggested Answers
Coastsider
  • 331 Answers
SOURCE: can i buy just the impeller for the 1 1/2 hp waterway 2 speed pum
Yes, you can obtain the impeller separately. Feel free to contact us, or look online for your specific impeller part number.
Posted on Apr 14, 2010
Install new wet end on waterway 4 hp
split wet end from motor take off cover to impeller unscrew impeller screw should be backwards thread hold back of motor with wrench after screw is out turn the impeller off should be regular threads use gloves or put a screw driver in hole to turn dont break the impeller then remove pump from backing plate then reverse to put back together dont forget seals
Jul 22, 2014 | Waterway Pool & Spa
High pitched sound coming from hi-flo 48 frame pump. why?
Sounds like the bearings are going out. There should be a series of bolts or screws connecting the motor and seal plate to the rest of the pump. If you separate these you can pull the motor back and get a better look a the impeller. Check and make sure there is no debris clogging the impeller or rubbing inside the diffuser/impeller area. This can also cause noise in the pump. You can try running it for a few seconds while it's open, and if it's still real noisy then it's the bearings. You can either replace the motor, or have it rebuilt. most local pool supply shops can check it and rebuild it for you. if they don't do that kind of work chances are they can refer you to a plce that does.
Sep 19, 2010 | Waterway Above Ground Hi Flo Pump
Can<t remove impeller for my waterway 56 pump
This can be very tricky at times. Quite often a sharp blow from a hammer on the wrench will work. Sometimes an impact wrench will work too. If that fails, then remove the fan cover from and try holding the motor shaft with channel locks, or vice grips. If it has a fan, you might have to remove it.
Jul 02, 2010 | Waterway Spa Pump Executive 56 Frame 4hp...
Can i buy just the impeller for the 1 1/2 hp waterway 2 speed pum
Apr 10, 2010 | Waterway 1.5 Hp 115 Volt 2 Speed Side...
When removing the impeller, how do you hold the shaft still?
Im guessing ...
On the motors I maintain, I remove the back cover. There is a start cap (usually black) on the left side held in place with a clamp. Use a phillips to loosen the clamp. DONT TOUCH ANYTHING that looks like a terminal, and be careful of the centrifical switch on the end of the shaft. Move the cap out of the way. The shaft has two flats that just happen to be 1/2 inch, Put an end wrench on the flats and you j
will have no trouble removing the impeller.
I hope this helps you
Oct 08, 2009 | Waterway Spa Pump Executive 56 Frame 4hp...
How do i remove impellor
The impeller in my 4 HP, 2-speed Waterway Executive High Performance 56 pool & spa pump has a brass coupling embedded in the back side. This coupling can be unscrewed from the motor shaft by keeping the shaft from rotating while turning the impeller in the reverse direction. Then the seal can be tapped out.
How do you remove the impeller from a Waterway Executive 48 spa pump
Take off the back of the motor, put a wrench on the shaft and turn the impeller by hand to loosen. It may be reverse threaded.
Oct 07, 2009 | Waterway 5 Hp 230 Volt 2 Speed Side...
Waterway 1.5hp Hi Flo Above Ground Pool Pump # Ph1150 6 Logo
Top Waterway Pool & Spa Experts
Jay Finke
Jay Finke
Mike Raino
Level 1 Expert
Ian Kime
Ian Kime
Are you a Waterway Pool and Spa Expert? Answer questions, earn points and help others
