Motorola MT - 777 transceiver
How to reset factory settings
Motorola factory reset
Apps > Settings > Backup & reset . Factory data reset
To Perform a Reset
  1. Open the Applications Tray. (arrow pointing up located in the middle at the bottom of the display screen)
  2. Touch Settings
  3. Touch Privacy
  4. Touch Factory data reset
  5. Touch Reset Phone
  6. Touch Erase Everything
For older phones: Master Reset or Master Clear
Mark
Motorola Support
Jun 29, 2014 | Motorola Cell Phones
I have accidenetly full reset motorola mt 777 and it now show no prog so whats the solution
You will need the Motorola programming software and hardware to reprogram it.
Mar 10, 2014 | Agilent Computers & Internet
MT-777
You must buy Motorola software from Motorola. Get a cable from them also. You also must have an FCC License to legally operate these radios. Your best best is to go through a dealer. The FCC License is quite hard to do without a dealer guiding you. It is easy to be ripped off and you must go through a coordinator. If not USA, still go through a dealer. The software and cable issue does not go away, ever.
Jan 10, 2014 | Motorola Radio Communications
How do i factory reset my motorola xprt mb612?
If you can boot the phone go into the settings app, click privacy or backup/restore and then click factory data reset. If you can't try to go into recovery mode.
http://streetech.com/how-to-hard-reset-motorola-xprt-and-restore-to-original-factory-setting/
Oct 23, 2012 | Motorola Mobility Xprt Mb612 sprint...
Need help... is there a way to reset the switch login password?
You can reset it to factory defaults in which case it will have the factory default login.
Reset — Press and hold the Reset Button for less than ten seconds to
reboot the switch. Press and hold the Reset Button for more than ten
seconds to reset the switch’s settings to the factory defaults.
Mar 14, 2010 | Linksys Cisco SLM224G Managed Ethernet...
How to reset the Password n 3510-24T Nortel switch
Hi Try the following - it should go back to factory default settings
There can be times when you need to factory reset a switch. This process can be accomplished through the CLI but if you've lost the switch password you'll need to follow a special process. This process should work for any of the Ethernet Switches (450, 460, 470) and the Ethernet Routing Switches 2500 Series, 4500 Series, 5500 (5510, 5520, 5530) Series. There is a different process to recover lost passwords on the Ethernet Routing Switch 1600 and 8600. Please note that by factory resetting the switch you will loose all configuration settings. It will be as if it just arrived from the "factory".
Follow these steps:
1. Connect to the console port of the switch (9600,8,N,1)
2. Reboot the switch.
3. When the first line of the diagnostics tests is displayed, press CTRL-C. The system then displays a menu.
4. Select option "i" to factory default the switch.
5. Select option "a" to run the agent code.
Upon boot up, the switch will be in a factory default configuration
Jan 06, 2010 | Nortel Ethernet Routing Switch 3510-24T...
Need help reset my verizon 700wx internet
You can reset factory default, why don't you try to create another account with the same settings as the the original 777 (without the other numbers).
Start
settings
connection tab
connections
Add a new modem connection (here you enter the same set up as the default 777)
You probably have to contact Verizon to get a password
Hope this helps...
Oct 25, 2008 | Palm Treo 700wx Smartphone
Computers & Internet Logo
354 people viewed this question
David Payne
David Payne
