1999 Neptune washer stopped in middle of cycle
My washer just stopped and is full of clothes and water. You can here the motor running, but the dial won't continue - it just stays in the same spot. The inside wash tub doesn't move. It probably ran for about 10 minutes - just enough time to fill up with water and now it is not moving, but you can hear the motor running. Any suggestions?
  • mterhorst Apr 24, 2009
    thanks for the quick response redbear! That definitely sounds like that could be possible. I will have my husband take a look at that tomorrow and maybe try to find the manual. I wonder to try to get to that belt, would you have to take off the back of the washer? It is a front load machine. Thanks!:)
    President:
  • 957 Answers
Sounds like the belt from the ele. motor to the wash drum broke. This can happen from over loading the washer or just wear and tear (lots of loads). Did you save the owners manual? It will give you a break down of the machine and contacts to get parts.
Posted on Apr 24, 2009
I want to place wet clothes in the washer and just spin them without washing them
sounds like you have a door lock problem, maybe the wax motor is not working properly of the spin switch is bad. You may have a problem with the motor controller also. Kind of hard to tell you how to trouble shoot on internet, unless you just want to replace parts till it works, call for service.
Apr 29, 2012 | Maytag Neptune MAH5500B Front Load Washer
Hello I have a Maytag Washer Model A512 The machine goes through a regular cycle OK - However, it DOES drains the water out during the rinse cycle, but does NOT drain the water out during the spin...
The timer will always advance to the next program if the machine does not fully drain. There is ALWAYS a spin when draining the water out, there is only one pump and one motor. The waterlogged laundry maybe telling the timer that there is still water in the tub. Put the machine on "Spin" and cheat the lid switch into thinking that the lid is closed. Use a clothes peg or wide ended screwdriver and see if there really is a spin....
Apr 07, 2017 | Maytag Neptune MAH5500B Front Load Washer
I have Maytag Neptune front loader washer. When
Hi.
Error LR means Locked Rotor.
Either the motor is faulty, there is a wiring problem, or the control assembly is faulty.
Try tripping the circuit breaker to reset the machine, if code comes back a technician must have a look at the motor.
Jun 13, 2010 | Maytag Neptune MAH5500B Front Load Washer
Spin cycle
it sounds like there is either an obstruction in the pump, or the load is getting off balance during the spin cycle. two things to try, fill the washer with no cloths in it, when it starts to agitate, stop the cycle and put it in drain/spin cycle. the water should be out in under a minute. its hard to see because the door locks, but you can hear a difference in the pump when its out, or after 60 seconds, press cancel and open the lid to check. if the waters out in that time, the pumps ok. then run it through the spin diagnostic with a load of cloths. make sure the cloths are wet, and a normal load you wash. this will check to see if the load is getting off balance, and shutting down during the spin cycle. let me know if you still have the problem. good luck, shane
Aug 23, 2009 | Maytag Neptune Washer
Maytag Neptune Washer Problem
replace the door latch wax motor and check the drain pump for obstructions.
Jun 25, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune washer MAH3000AWW seems to backfill after cycle
It could be a leaking water valve. The MAH3000 has two flavors, the earlier model had (2) extra wax motors in the soap dispenser for the bleach and softener controls and the newer ones have the bleach and softener valves integrated into the water valve assembly.
Contact me via the www.neptunehelp.com site and let me know which serial number you have and I can detemrine which water valve you will need.
See www.neptunehelpsong.com for a funny new song dedicated to Maytag Neptune owners explaining the door latch wax motor issue.
Feb 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer runs when timer dial turned though ON button not pushed
Problem solved by ourselves! It was NOT in the circuit board (brain) of the machine. It was NOT in the door locking assembly as others would lead us to believe. It WAS the on/off switch on the control panel--part number 22002560 - a $22.00 problem fix.
Jan 05, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune washer
LR == locked rotor, which translates to a bad motor and motor control board( usually depending on age sold a 1 set. Neptune repair kit. retails for about $200 part number 12002039
Oct 26, 2008 | Maytag Neptune MAH5500B Front Load Washer
only 2 or 3 real problems with this machine, bad machine controller( behind console) although lights on are sign that its good,
Either the pump is clogged and not draining water so it will never spin let alone spin full speed with water in tub, i also doubt that because it seems that s there just water within the clothes and not a tank full of water,
which leaves the last Major issue with machine and that's the motor controller, not telling the motor to spin.. could also be a bad motor but i really doubt that all....
This is a funny machine because depending on when it was made (serail number denotes its age) im looking up the model and your manual states that you have a 3rd yr to 10 yr part warr on the motor, Well on earlier models you cant replace the motor itself it comes as part of a kit, "NEPTUNE REPAIR KIT" which also includes the motor control board. reason i mention that is I"m able to get a motor controller covered by warr(as an authorized maytag technician) if the model will take the neptune repair kit, sure youll need to pay service and labor but the a part would be covered.
Mar 20, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
54 people viewed this question
Top Washing Machines Experts
