Question about Apple iPod MP3 Player
Battery wont take charge
At first only played with charger plugged in outlet then not charging at all
  • 342 Answers
I would recommend resetting the ipod. If you are unfamiliar with how to do that I have posted the know how below.......
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
I hope this helps. Let me know if you need further assistance with this issue. I'll be glad to assist in any way that I am able :)
Posted on Apr 24, 2009
On ultra jet 3 there is a 3 prong outlet below the seat on the right & has cord that goes to normal outlet is that how to charge it
Jet 3 Ultra www.pridemobility.com 33
VI. BATTERIES AND CHARGING
To charge the batteries using the off-board charger:
1. Position the front of your power chair next to a standard
electrical outlet.
2. Be certain the controller power is turned off and the
freewheel levers are in the engaged position. See III.
"Your Power Chair."
3. Plug the off-board charger into the off-board charger/
programming socket on the controller.
See figure 25.
4. Plug the off-board charger into the electrical outlet
You should use the charger supplied with the power chair. It is
the safest, most efficient tool to charge the batter-ies. We do not recommend using other types of
chargers (e.g., an automotive battery charger).
Sep 07, 2014 | Health & Beauty
Battery wont charge
As in the first part of the manual is explained, when you have inserted the battery correct and you then plug in the charger, the charger light should go on. When the light is out, the battery is charged. When the light blinks, your battery is fault.
When the light does not go on, when you plug it in a power outlet, the battery is not inserted correct, or the contacts are dirty.
If you want to clean the contacts, please only use a dry cloth. Never us a sharp tool. It would damage the contacts bend repair.
Even when you plug in the charger, with a fully loaded battery, the light should go on for only a few moments.
Make sure the power outlet works normally. and the power cable is not defect.
Dec 29, 2013 | Fuji FinePix F460 Digital Camera
Battery wont charge on my Mid m9100 android tablet pc
Are you sure the charger is working correctly? When you plug the charger into the tablet and into the wall, then leave it alone for half an hour, does the charger feel at all warm? Is there power to that outlet, or is it a switched outlet (like one used for a lamp)?
If the charger feels warm after half an hour, does the back of the tablet also feel warm? It may actually be charging.
If the charger is dead cold (same temperature as a table) and you're sure that it's plugged into a good outlet and correctly plugged into the tablet, then it's a good bet that the charger is dead & you need to find another.
Can you also charge that tablet with a USB cable connected to a PC? That'd be a good test. Try doing that - if that ALSO will not charge the tablet, then there may be a problem with the tablet itself.
Mar 02, 2013 | mid M9100 9" Dual Camera Android 4.0 ICSOS...
Phone wont charge so will not turn on
Have you tried more than one power outlet? It could be the power outlet you're trying to use isn't functioning. If it won't charge on a different outlet, the issue is either the charger you're using or the phone itself. Try wiggling the charger around while plugged in to the phone, see if that will charge it at all. You should also trying getting a different charger and see if that will work. If not, you may just need to replace the battery/phone.
Aug 14, 2011 | Ericsson Cell Phones
My sky caddie sg5 wont charge
If you follow these instructions which I think you know how to, it will recharge. If not the rechargeable battery needs to be replaced
To charge the battery, simply follow the steps below:
  1. Gently pull back the rubber cover to gain access to the mini-USB port located at the bottom of the SkyCaddie. Insert the mini-USB connector of the supplied wall charger into the mini-USB slot.
  2. Plug the wall charger into the AC wall outlet. While charging, the charging indicator in the upper left-hand side of the SkyCaddie will show red. The charging indicator will switch to green when fully charged. You may also notice the unit's screen turn on and off periodically.
The battery will charge, even with the SkyCaddie turned off. A full battery charge may take 4 hours. Once fully charged, expect 36 holes of continuous play.
Warning!Always connect the cable to the SkyCaddie first before connecting to AC power or PC USB.
Jul 16, 2011 | GPS
How do i charge my camera so that i can explore
You can charge the battery in two ways.
Use the supplied battery charger. Remove the battery from the camera, put it into the charger, and plug the charger into a power outlet.
Connect the camera via a USB cord to a powered USB outlet. Be aware that not all computer USB ports put out enough current to charge the battery. You might want to consider a cell phone charger that plugs into a power outlet.
Nov 28, 2010 | Vivitar ViviCam 8025 Digital Camera
My phone is fairly new ( a few months old) and for some reason the charger wont charge when I plug it in. I've tried unplugging it, putting it in different outlets, taking the battery in and out etc but...
i think your baterry is drained already..try to charge your battery in a universal charger, or a clip charger.then continue charging with your original chargermoz-screenshot.png7bf4754.jpeg
Apr 13, 2010 | Motorola Mobility W376 Cell Phone
Motorola razr v3 wont charge, the bettery is not that old the phone beeped to signal charge requred, plugged it in as usual but cant turn it back on.
If the charger is plugged in, the phone is hooked to it, and it still will not come on, I would think it's a charger or electrical outlet problem.  I think most phones will bypass the battery power if they are plugged into an outlet, so try another wall plug, and if that wasn't it, try a different charger.  If a different outlet and charger don't solve it, it may be time to take it to the store to be checked.
May 29, 2009 | Motorola Mobility RAZR V3
Portable dvd player will not play off outlet or car charger
There must be something wrong with the amount of power the power supply is providing. I would try and purchase another power supply, and see if it still happens. Another thing it could be is the port where you plug in the power cord, is the port loose or can you move it? If this is the case, it might not be receiving clean power.
Jan 23, 2009 | Protron PDV-288 7" LCD Portable DVD Player
My Mambo- Mano MP4-MP3 does no charge
it does not seems to charge / or turn ON either from the computer or when plugged to an electrical outlet to the wall. Red light is still ON after the whole night . What's wrong ?? Can you please HELP - CODY STELLER MINE IS A 4 GIGA BITE MP4 PLEASE HELP ONLY
Sep 01, 2008 | Kaser Corporation Mambo Mano Digital Media...
Apple iPod MP3 Player Logo
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
