Question about Magellan Roadmate 2120T-LM GPS Vehicle Navigation System
2120t-lm has stop working . all i get is a pic with a computer and a gps showing an X and there is some kind of connection symbol in between is this fix able
2 Suggested Answers
emissionwiz
  • 80637 Answers
SOURCE: my magellan roadmate 3030 LM is stuck on usb conect to computer screen. will not do anything
You will need to send the unit in for repair. There is nothing you can do at home to repair this problem.
Posted on Aug 29, 2012
Change time that is on my gps
  1. Open the Main menu and tap Settings.
  2. In the Settings menu, tap Set clock.
  3. Select how the time should be displayed, then tap Next. ...
  4. Tap Yes to set the time manually or tap No to set your device to update the time automatically using GPS
Sep 28, 2016 | Magellan Roadmate 2120T-LM GPS Vehicle...
Content manager does not find software update the magellan's site says is needed?
Contact Magellan tech support to see if there is a compatible software you can use for your GPS.
May 11, 2014 | Magellan Roadmate 2120T-LM GPS Vehicle...
Loading a philippines map
Visit the website of Magellan for your country or their global site. Find the maps, pay for them and download to your computer. You will have access to the installation instructions. Usually you install some software by Magellan, you connect your device to your computer and the proprietary software will install them on the GPS.
Mar 17, 2014 | Magellan Roadmate 2120T-LM GPS Vehicle...
I can't get my email address out of the thing and I want to return it to the store
the factory reset should clear it. if it doesn't you'll have to open the unit and disconnect the "keep alive" battery (for memory retention) and that will def. do it no doubt. but the factory default/back to new button should clear all entered info.
Sep 01, 2012 | Magellan Roadmate 2120T-LM GPS Vehicle...
My magellan roadmate 3030 LM is stuck on usb conect to computer screen. will not do anything
Aug 29, 2012 | Magellan GPS
Magellan roadmate 2120T too slow after updates
Magellan support was actually pretty good helping me with the exact same issue. The problem (at least in my case) was that the map files were fragmented. I tried using the Windows defragmenter, but that made fragmentation even worse! The Magellan support engineer recommended I download UltraDefrag instead:
http://ultradefrag.sourceforge.net/en/index.html
Here's what I had to do to completely resolve my issue:
1. Download and install UltraDefrag
2. Connect my GPS to my PC
3. Move the MAP directory from my GPS drive (J:) to my hard disk
4. In UltraDefrag, make sure Action > Skip removable media is not selected
5. Run the optimizer (Ctrl-F7 or Action > Full optimization) after selecting the GPS drive (J: on my computer)
6. Copy the MAP files back to the J: drive AFTER optimization has completed
I double-checked the fragmentation after the files were copied and got 0%. After disconnecting the GPS from the PC, the unit rebooted and doing an address search no longer takes 15 seconds. POI searchs are also much faster than before.
Aug 06, 2012 | Magellan Roadmate 2120T-LM GPS Vehicle...
Computer symbol when charging my Garmin Nuvi 200
TRY SWITCHING GPS OFF WHILE CONNECTED. IF NOT DOWN LOAD NEW SOFTWARE AND WHEN FINISHED IT LEAVE CONECTED SHOULD SHOW CHARGING AND YOU WILL BE ABLE TO USE
Dec 18, 2009 | Navigon 2100 Portable GPS Receiver
I just received my Garmin for XMAS and it was working fine but now it just seemed to not charge. Then the little pic on the front shows the GPS connected to a computer desktop. HELP! Amber Fader
Does it turn on at all? Try to charge it on car adaper then, when it will turn on, try this.
The picture is displayed while it is charging through USB cable and you can't normally use GPS.
Turn the GPS on without the USB plugged in, then press the Battery symbol for about 10 seconds, until the test screen appears. Then plug in the USB.
Screen will tell you percentage of charge, and if it is charging.
***Make sure you press EXIT before unplugging the USB cable. Press EXIT, turn GPS off, then remove the cable is safest way
On the bottom you should see "USB type" if nothing is there, it may be the USB port on your computer. Try it again with a different port
Jun 12, 2009 | Garmin nuvi 255W GPS Receiver
Tomtom One 130 shows pic of Tomtom, flashing x, pie chart icon on left after using Tomtom Home.
TomTom Home must have corrupted the TomTom's operating system. That is what that symbol means. Contact TomTom support and tell them what model you have and they will walk you through getting the correct version installed.
Oct 14, 2008 | Tomtom ONE GPS Receiver
Magellan Roadmate 2120T-LM GPS Vehicle Navigation System Logo
24 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
