Question about Amana NTW4600YQ Top Load Washer
Lights breaking fill and lid lock - Amana NTW4600YQ Top Load Washer
WASHER ... COMES ON GREEN SENSING LIGHT STAYS ON START'S TO FILL CLICK'S OFF RED DOOR LIGHT LOCK LIGHT COMES ON STAY'S BLINKING
Thank you first person that has provided a model number sounds like you already changed the lid lock assembly if you did you know how to get the top up inside the front panel is a tech sheet it will tell you how to place the unit into diagnostic and read the lights for an error code recheck your connection at the control board a flashing lid lock would should give and F5E1 or F5E2 error code also check the alinement of the tab on the lid where it goes into the lock assembly should be a smooth transition
Jan 12, 2015 | Amana NTW4501XQ 3.4 cu. ft. Top Load...
Kenmore 21102010 lock light and fill light on does not fill just clicks
This sounds like a fill valve problem ,where solenoid is not working. Fill valve is on upper left or right side on rear of machine. These problems tend to occur with hard water. GOOD LUCK FRIEND.
Oct 16, 2014 | Kenmore Washing Machines
Changed lid lock switch and won't work
Is the plunger attached to the lid? It is the little prong that goes into the lid switch.
Apr 05, 2014 | Whirlpool WTW4800XQ Washer
Why wont my amana washer start at all?
My washer will notwork it will not let the lid lock are fill with water
Jan 20, 2013 | Amana NTW4501XQ Top Load Washer
Lid Locks- Fills for 2 seconds and stops
see this causes and fix it. God bless you
Door or Lid Latch Assembly If the washer lid won't lock the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer door won't lock the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Main Control Board If the washer door won't unlock the problem might be the main control board. This is not common. Normally the problem is with the lock mechanism.
Oct 11, 2012 | Maytag Bravos MTW6600T Top Load Washer
Mazda 6 sport sedan break lights not working after hid light conversion
Instructions Open the rear deck lid on the Mazda 6.Carefully remove the plastic finishing cover from the license plate light housing, using a small flat-head screwdriver to release the locking tabs. Pull the cover downward and off of the deck lid, exposing the license plate bulb.
Remove the old light bulb from the license plate bulb socket by hand. Wrap your new one in a paper towel and do not touch the bulb with your bare fingers. Insert the new bulb into the light socket. Install the finishing cover onto the light housing and push it upward until it clicks and locks into place.
Repeat Steps 2 and 3 to complete the LED light conversion on the opposite side of the deck lid. Test the new bulbs by turning on the headlights on the Mazda 6.
Mercedes Parts.
May 25, 2012 | 2004 Mazda 6
Fisher and Paykel, EcoSmart with lid lock. After initial fill, all wash lights go out, advances to rinse, then beeps continuously. Have to shut machine off and start over. Continues to wash, but leaks...
Fisher and Paykel, EcoSmart with lid lock. After initial fill, all wash lights go out, advances to rinse, then beeps continuously. Have to shut machine off and start over. Continues to wash, but leaks out of top panel under lid. Machine is level. Any Suggestions?
Jul 28, 2011 | Fisher and Paykel WA37T26G Top Load Washer
Maytag neptune TL (TOP LOAD) fav6800aww washer
was absolutely the corrosion in the left lid lock, had eaten right through the wire. this site was awesome....always check te left first, it has the sensor to tell the machine it is open.
Mar 29, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Amana NTW4600YQ Top Load Washer Logo
19 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Terry Schneider
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
