Question about Refrigerators
Model #10662153110 Kenmore Refrigerator door handle broke
  • 50 Answers
SOURCE: Refrigerator getting hot!
There is a part of the condenser called the mullion loop that adds heat to keep moisture from building up and causing the door gaskets to stick. If it's too hot to the touch, first check your frige and freezer temps. You'll obviously know if the frige is too cold, but you may not know if the freezer is too cold. The freezer should be between 5-10 deg ABOVE zero. Any colder and the frige will have to work harder and would create more heat. Also check the condenser coils. If they are dirty it will prevent the frige from removing the heat properly. The condenser should be cleaned at least annually. Most friges have a condenser fan motor. Make sure the motor is running and the fan blades are clean. Most friges also have a cardboard type panel on the back at the bottom. That panel directs the air flow across the condenser and must be in place. If it's missing or damaged it will need replaced.
Posted on Jul 20, 2008
gr82fly
  • 3 Answers
SOURCE: Removing refrigerator door handles
You might try checking to see if the screw head is actually on the handle, but hidden by the handles cover. Look at the side and see if you notice a seam. This can be pried open and the screw head will be seen.
Posted on Feb 23, 2009
  • 15 Answers
SOURCE: door handle is loose on model#gsh22jftacc. how do you tighten?
If it's the same as the one we have (which is similar to the pic posted on yours) there's a plastic piece on the top and bottom of the handle that you have to pry up (gently) to get to them.
It looks like a line that runs horizontal across the handle, but it should come up with a little force (meaning it shouldn't require tools). You have to pry it from the side, not the top or bottom.
Posted on Mar 03, 2009
SOURCE: Door Handle
Yep, if the engineer had worked for me, I would have fired him/her. I have gone through 3 of them of the past 3-1/2 years until I got tired of it.
That said, it likely brakes at the same corner/corner. You will likely find a cavity inside each broken half. Using superglue and a small flat piece of metal (cut from a metal washer) sized/formed to fit inside cavities when the broken half are pieced together. Trial piecing the pieces together first before glueing them together.
If there are no cavities (solid), try creating one (you may be able to drill/carve out) in each broken half then follow the steps above.
Guaranty better than new and last a whale of a lot longr.
Good luck.
Posted on Jul 04, 2009
  • 11 Answers
SOURCE: On my Kenmore Elite #106.56683501 the refrigerator door is loose
Depending on the model, and the color, here's your fix.
Stainless with stainless handles- you'll need a hex key. The tiny hole is on the inside of the handle, close to the center. Turn the key until it's tightened.
Stainless with black handle/white/bisque/black- push the door handle up. Careful not to scratch the finish! once the handle pops, pull it straight off. Take a phillips head screw driver, tighten the top screw A LITTLE BIT and then attach again. Insert screws on the door into the holes on the handle, slide down. (will need to be a little tough with it.)
Posted on Sep 06, 2009
The support condiment of my door is broken.
That sounds like a Kenmore Canadian model number. Contact Sears parts in Canada and give them your model number and ask them about a part replacement I'm limited here in the US to answering your question the reason I have no documents on your model numbers
Nov 18, 2015 | Kenmore Refrigerators
Kenmore coldspot 106 door handle is loose
Gently slide the handle up until it releases. Then slightly turn the screw underneath it, and slide the handle back on. Do this until it fits properly.
Jul 28, 2013 | Refrigerators
Sep 03, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Sears Kemmore Mode; Refrigerator side by side model 106.9557621 How do remove door handle
The upper and lower trims have to come off for access to the handle screws. Some just slide up or down and some have screws on the top and bottom of the door. Carefully pry them off.
Eric
Jun 28, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Door handle is loose
If my memory serves me correctly, you should see two posts attached to the refrigerator door right now. The handle slips over these posts and if you look closely there is a little hole in the handle where you would insert a allen key wrench to tighten the little screw against the post protruding from the door itself. With the door handle in your hand, properly match up the correct allen wrench to fit the allen screw very snug. Realign the door handle on the protrucing posts and tighten. Once finished, you should have a tight fitting door handle again. Let us know if we can help further.....Eric
Feb 13, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
The door handle on the dryer broke,
yes you will need to open the door and remove the screws around the inside of the door and then the outer skin will pull off and you can access the door handle screws
Jan 31, 2009 | Kenmore 82822 Electric Dryer
Want to reverse door swing on Kenmore refrigerator model # 795
Actually, I have a Kenmore 795 model with the top door and bottom drawer freezer. I just tried this, based on "guru's" advice. Unfortuately, though the TOP hinge on this model is reversible, the bottom hinge is NOT. I got it all apart before I discovered this problem. Also you might want to note that the 7/16th wrench is too big for my bolts and the 3/8ths is too small. I had to use an adjustable wrench...maybe they are metric.
An allen wrench will get the handles off for you. You will find little ports for it if you look carefully.
Nov 27, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Door Handle Issue
I may need the entire model # off the sticker inside the fridge section to help.  Most side by sides have a slot that the handle fits into and just pull down hard to lock into place.  May need to take the handle all the way off and tighten the screws on the handle and on the door first.
Oct 27, 2007 | Kenmore 55603 Side by Side Refrigerator
Refrigerators Logo
51 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
