Question about BenQ PB2220 Multimedia Projector
Bought this projector Last year used less than 25hrs.does not work
My projector did not glow.Replaced Bulb still does not work What cud be wrong?No proper Benq Engineer available in Delhi! Heeeeelp. Thanks
2 Suggested Answers
Mine needed a "fan module" replaced. The part number is 60.J8613.011.
Cost was $60, plus $100 for labour.
Posted on Apr 10, 2009
  • 3 Answers
SOURCE: BenQ PB8220 DLP projector - lamp button continues to flash after bulb replacement
After 2 years I finnaly solved the problem. There was a flaw in the lamp´s temperature circuit. A technician disassambled my BENQ PB8253 unit and fixed the problem. Charged me US$ 75.00. I´m in Brazil.
Hope this can help.
Posted on Sep 14, 2009
0 characters
1 Points
Sony vpl-px30 clicking noise on power-up, lamp will not come on
I had the Problem, I replaced the bulb and it fixed the problem.
a year ago I was not able to find this bulb under 450.00, I bought it last month from amazon for $73.00 and free shipping.
Jun 17, 2012 | Sony VPL PX30 Multimedia Projector
Picture way too dark to watch comfortably. Have already adjust all settings to maximize brightness. Bulb was replaced late last year and says 1,000 hours have been used but projector has not prompted me...
Unfortunately dim image is normally due to a defective lamp assembly. I'd recommend removing the lamp and inspecting its condition. You'll notice black corrosion build up or a bubble is starting to form around the filament of the bulb if it is what's causing the dim image.
Aug 06, 2011 | Mitsubishi HC1600 Projector
Just replaced bulb in projector and now have error lights
Try unplugging it for a period of time. And while you have it unplugged get a can of air and clean it out. When they are used for long periods of time and over time dust builds up and cause issues with all projectors. The require to be cleaned. I do mine about every month or so. More or less depends on use. Mine gets used everyday.
Feb 05, 2010 | InFocus LP 850 Multimedia Projector
Projector went silent on me...
the colorwheel is bad and needs replacing.
Apr 28, 2009 | Multimedia Projectors
Toshiba Projector TDP-S20U. Horizontal Bar.
it can be also due to faulty ballast or the colour wheel due to which the horizontal bar is showing up.also if the buklb is giving less light /glow that means its weak should be the cause of this the voltage of the bulb should be checked  how to replace the colour wheel with diagram and procedure
how to replace the lamp in 5 minutes with diagram and procedure
how to replace the ballast with diagram and procedure
Mar 06, 2009 | Toshiba TDP-S20U Multimedia Projector
Projector keeps turning off
When i turn the projector on it only comes on four about a minute until the temp lights go amber and it turns off, the fan is working but the air coming out is a little warm. what if anything is making my projector overheat, or is it not heating at all?
Aug 07, 2008 | Dell 2300MP Multimedia Projector
Can you tell me why the optoma HD72I lamp will turn off after just a few minutes of running, the lamp is still fine
I have the same problem. I got a new bulb and it worked for about 1000 hours, then the new bulb started having the same problem. So, I was about to buy another bulb, and I figured why not try the original bulb. IT WORKED! For a couple weeks... Then it started doing it again. Obviously there was nothing wrong with the original bulb, and there is nothing wrong with the new bulb, but I have 2 bulbs that do it now. So, is there any way to just tell the projector run the bulb till it actually dies and not turn it off because it thinks it is about to die.
Aug 01, 2008 | Optoma HD72 Multimedia Projector
Infocus IN72 powers up but no image, replaced the bulb but still no image...
Hi there
This is most probably a Ballast ( lamp's powersupply ) problem.
Make 100% sure that this unit is out of warranty because InFocus Projectors come out standard with a 2 year warranty.
Apr 09, 2008 | InFocus IN72 Multimedia Projector
IN76 Pojector Just Turned Off, Will Not Turn Back On
same thing on my in76. a color wheel had to be replaced. projector is less than a year old an all parts and labour was covered.
Dec 30, 2007 | InFocus Play Big IN76 Multimedia Projector
Projector turns off
Please give some more details, Also tell that ur lamp glows or not after fans the lamp unit and see the condition of inner tube, if that is abnormal then you have to replace lamp again. if it is tuning of and on repeatingly then there is some problem with DMD module.
+91 9814903739
Nov 27, 2007 | Sharp XR-10X Multimedia Projector
BenQ PB2220 Multimedia Projector Logo
Top BenQ Multimedia Projectors Experts
Electro Med Services...
Are you a BenQ Multimedia Projector Expert? Answer questions, earn points and help others
