Question about Video Cameras
JVC MX56BK fan sound - Video Cameras
"Fan lock"
Use the below link to locate ur nearest service centers ...
its an hard ware cognitive factor u alone cant rectify it ..
http://maps.jvc.com/cAscList/index.asp
Dec 23, 2007 | JVC HD-56FN97 56" Television
My powered sub woofer system doesn't work.power indicator works and fan doesnt no sound
You will need to contact JVC online, customer support and the technical department to see if they can provide at least download on the circuit diagram. The powered sub from your description has a short, probably the main ic that is heatsinked.
Nov 26, 2011 | JVC Audio Players & Recorders
I have a JVC digital cinema system ]TH-A75R which will only switch on when "cold". That is : switch on, insert a DVD and it plays OK, but if switched off ( to standby or at the mains ), will...
The cooling fan should run at all times. Check for dust or any blockage to the fan. If clear then try spinning the fan with a piece of plastic or something to see if once the fan is rotating it continues to spin.
May 28, 2011 | JVC Silver DVD Digital Theater System -...
JVC TV WENT OFF. TURNED IT ON AND THE LAMP LIGHT STARTED BLINKING
If the Fan is clogged up with dirt set will not run fan must be working.
Dec 01, 2008 | JVC AV-30W776 30" TV
Power will shut down after few minutes when volume reaches 12
If you check at the back of your hi-fi, you'll see a projection at the top where the cooler fan is located. The most likely reason is that your fan is not working (as required). In this system, the fan is turned on automatically at high volumes >=10, because then, the amplifier starts to get a temperature rise and without proper cooling the system might fault.
Try check and see if at these high volumes the fan is running, if not, then that's what needs to be fixed. Alternatively you can try running an external fan to see if it will produce the desired cooling effect.
Nov 25, 2008 | JVC DX-T9 System
Sub woofer its on for 3 sec..
your cooling fan is not engaging and coming on like its suppose to. One, the fan is probably burned out, which sucks because its low voltage and the only thing on the board that is low voltage. Two, there is a thermostat type component that tells the fan to start which HAS burned out and doesnt start the fan accordingly. If you look at the back fan and turn everything on you will see the fan either doesnt start or starts right as the relay trips turning the sound components off. If it starts at all your fans good.The thermostat component will need to be replace and I cant recommend a source. Just trying to explain the problem so you can look for the right repair. Hope it helps. I have one of these and have found this is the problem, but cant find the solution.
Apr 28, 2008 | JVC TH-M505 System
Annoying projector noise
I went through a huge hassle about the fan noise on my JVC 52-inch, but they refused to do anything about it. Likewise, the retailer (BuyDig.com) refused to accept a return "once the box has been opened."
The noise is way out of line - we have to turn the sound up all the time to drown out the damned fan. We've tried repositioning the TV, propping it up off the table surface... nothing has helped. The next thing I may try is to build some ducting for it, but it's been this way from day one, and JVC is well aware of the problem.
I'll never buy another JVC product.
Oct 31, 2007 | JVC HD-52G786 52" Rear Projection HDTV
Video Cameras Logo
16 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
