Question about Maytag PYG2300A Gas Dryer
How to get the front panel off of a Maytag model PYG2300AWW gas dryer.
  • 4 Answers
SOURCE: remove front panel of maytag MDG7400Aww gas dryer
You have to remove the front panel first to access the clip that holds the front of the top down. Instructions:
crosstip medium screwdriver
1/4 inch socket
5/15 inch socket
  1. UNPLUG DRYER
  2. TURN OFF GAS
  3. Disassemble by taking apart the FRONT of the dryer:
    a. Remove the door and opposite side door plugs (crosstip screws)
    b. Remove the front panel - this exposes sheet metal bolts (5/16 inch) some with crosstip on left and right of unit. Set panel aside (right side) WITHOUT unplugging wires
    c. Unscrew all the exposed bolts.
    d. Top bolts left and right secure the unpainted metal hooks which secures the top of dryer. Unscrew these bolts and wiggle the metal retainer hooks off. Lift top and support to create 6 inch gap in the front (top unit hinges in back and has electrical connections - do NOT disconnect wires)
    e. Release belt from pulley by reaching left and under drum (this is out of sight)
    f. gently lift out drum and belt and set aside
  4. This has exposed the interior.
Posted on Nov 01, 2008
  • 77 Answers
SOURCE: Dryer not heating as it should. Gets warm, but takes several cycles to dry clothes
Could be 2 things... either your heat source is out of repair or your vent is blocked. Since you say it only gets warm I'll assume the problem is with the gas coils inside the unit. These parts are replaceable
Posted on May 12, 2009
jumptrout51
  • 3361 Answers
SOURCE: How to replace heating element Maytag Performa
Your model number indicates a gas dryer. It does not have a heating element. It has a glowbar igniter,a flame sensor and a gas valve. Either the glowbar igniter is bad or the flame sensor or the gas valve coils or the thermal fuse.
Posted on Jun 22, 2009
woodchuck789
  • 4059 Answers
SOURCE: Maytag model pyg2300aww gas dryer- spring
There is a spring in this diagram. Part 6. It hooks to the idler. It's the only spring I can find on the diagrams. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=PYG2300AWW&productCategoryId=0151200&brandId=3048 &modelName=DRYER&diagramPageId=00006&componentDescription=MOTOR%20&%20DRIVE&documentId=M0512356&blt=06
Posted on Oct 29, 2009
marka19
  • 1430 Answers
SOURCE: how do i change the dryer drum belt on a maytag
Try this free video www.appliancehelponline.com/servicemanual.html
Posted on Feb 26, 2010
The screws won't stay in the hinges on my Maytag dryer door, model #PYG2300AWW. It's like the holes in the cabinet are too big for the screws. Is there something else missing that they should be...
Hi ddyreson...
You are missing a sheet metal clip.
It will clip on the sheet metal with the large hole in it, to convert it from a large hole to a hole that you need to fit the screw...
Look around where you disassembled the dryer, it is somewhere in the area or in the dryer...
You can get replacement metal clips at HomeDepot,Loews,Ace Hardware,etc.
Please take time to rate me
Sep 05, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Our dryer is turning but no heat what is the first to go on dryers model#pyg2300aww thanks
first,check and see if the ignitor glows,if not it probably is burned out,then if it glows,but wont start check the flame sensor eye for dirt so it cant sense the flame,if this isnt the problem,then check the gas valve coils on the gas valve,they get weak and cant keep the valve open to supply gas to the dryer
Mar 12, 2010 | Maytag PYG2300A Gas Dryer
Maytag gas dryer would run half cycle until it would shut down. now it struggles to start and then stops. pyg2300aww model.
Good day,
Every indication the motor is failing. Not uncommon.
Could be a bearing dragging badly, or idler assembly bearings, doing the same thing, but
A complete tear down of the dryer would need to be done to verify the problem.
Once again,figure the motor as the problem.
Thank you for using FixYa
Dec 25, 2009 | Maytag Dryers
Maytag performance pyg2300aww is making a screaching sound
HOW DO YOU CHANGE THE DRUM BELT ON MAYTAG DRYER MODEL PYG2300AWW
Nov 23, 2009 | Maytag PYG2300A Gas Dryer
How to replace heating element Maytag Performa gas dryer pyg2300aww?
Jun 22, 2009 | Maytag Dryers
May 12, 2009 | Maytag Dryers
Maytag gas dryer PYG2300AWW
If it acts that bad, I would try to find me a new dryer.
May 12, 2017 | Maytag Dryers
My maytag performa gas dryer model # pyg2300aww gets warm but takes four cycles to dry.
clean your dryer vent going from the back of the dryer to outside also run a lint brush down where you put the lint screen in if this does not help replace your coils
Dec 29, 2008 | Dryers
Open Questions:
Maytag PYG2300A Gas Dryer Logo
47 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
