Question about Amana D950EP Dehumidifier
D950EP dehumidifier manual - Amana D950EP Dehumidifier
Red Lite is flashing, unit will not turn on
if the red light is flashing this means theres a fault , most common fault on these are water catch bucket is full or not seated back correctly
Aug 24, 2015 | Amana D950EP Dehumidifier
I have a LAD704DUL frigidaire dehumidifier that will not shut off after being shut off, and not until the plug is pulled. Is this worth getting fixed
Dear Peter Nicolle,
according to the user manual the dehumidifier will not stop running for the following 5 reasons:
  • Windows or doors near dehumidifier are open to outdoors.
  • Area to be dehumidified is too large.
  • Air movement through dehumidifier is blocked.
  • Dehumidifier has been installed or restarted recently.
  • Dehumidifier is in the CONTINUOUS mode.
You can find more information on the user manual on page 9 under the category DEHUMIDIFIER RUNS TOO MUCH.
http://manuals.frigidaire.com/prodinfo_pdf/Edison/2020266a0220en.pdf
Nov 30, 2014 | Frigidaire 70-Pint 2-Speed Dehumidifier...
Winix wdh851 service manual
The owner's manual is here: http://www.sylvane.com/media/documents/products/winix-wdh851-dehumidifier-owners-manual.pdf
but that's probably not what you want. You might try posting your specific issue that you need the service manual for. For instance a fan that won't start is a common problem for dehumidifiers and a cheap fix. If that is your issue read this: http://www.fixya.com/support/t3588983-lg_lhd65ebl_serial_603taac20984
The article is for an LG dehumidifier but the thermistor mentioned is common to most brands.
Jul 13, 2014 | Winix 50 Pint Dehumidifier WDH851
Need owners manual
need owners manual for amana d950ep dehumidifier 50 pint cap with electronic controls with led service cant figure out what the settings should be
Apr 04, 2013 | Amana D950EP Dehumidifier
Need an Operation Manual for Delonghi DN125 Dehumidifier
Unfortunately, Delongi doesn't list an Owner's/Operational Manual for your model dehumidifier. However, you can contact their Customer Support Dept at 800-322-3848. They can email you an Owners Manual. Be sure you have the correct model number for your unit, before calling.
Jun 01, 2011 | DeLonghi DN 125 Dehumidifier
I just purchased a second-hand LG 45 pint dehumidifier. I need an owner's manual, free if possible........ Thanks
Jenifay, take good care of your dehumidifier and do all the routine maintenance that is recommended in the Owners Manual. As this model has been discontinued.
The following link will take you to LG's Knowledge Base. On the right of the page, you will see Dehumidifier Manual English. Click on that, and you can download and print the manual for a 45 pint LHD4SEL Dehumidifier.
Since I was able to get you a free manual, would you be kind enough to rate my response to you?
Thanks.
Apr 27, 2011 | LG Dehumidifiers
If my dehumidifier seems to be working fine( fan comes on and all buttons work) and its not picking up water anymore could there be some other reason that its not filling up? We did also fix a few leeks in...
There can be many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Aug 23, 2010 | Frigidaire FDL50R1 Dehumidifier
FDL25P1 25-Pint Portable Dehumidifier Dehumidifier: The dehumidifier is running but is not pulling any...
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
heatman101
May 18, 2010 | Frigidaire FDL25P1 Dehumidifier
Amana D950EP Dehumidifier Logo
64 people viewed this question
Top Amana Dehumidifiers Experts
jasbo
jasbo
Gil Shultz
Are you an Amana Dehumidifier Expert? Answer questions, earn points and help others
