Error sc 363 ricoh afico 2500 - Office Equipment & Supplies
SOURCE: ricoh copier aficio 401 error sc 419
How do i clear SC 548 error on aficio 1022 copier machine
Posted on Jul 09, 2008
  • 86 Answers
SOURCE: Need to change fax number programmed in Ricoh, afico 3025
Press the User tools/counter button;
Touch the Facsimile features icon on the touch panel;
select Gen. settings/Adjust tab;
touch Program fax information;
touch Own fax number;
touch For G3-1, then enter your fax number from the blue numeric
keypad then touch OK.
Touch Exit, then press User tools/counter button to go to Standby mode.
Posted on Jan 13, 2009
  • 990 Answers
SOURCE: error code sc 172 on ricoh aficio 2103
Hello sir; This error code is indicate video process error, may be can be reset, the procedure as follow;
press "clear mode", "107", then press and hold down "clear/stop" key for about 3 sec., until SP menu display, touch "copier sp" on screen, enter 581002 then press 1, then turn power off and back on. see what's happen. good luck !
Posted on Feb 24, 2009
  • 3 Answers
SOURCE: eror sc 500
remove all paper from the trays then turn machine off wait a few second then turn back on should reset then reload paper
Posted on Apr 11, 2010
  • 903 Answers
SOURCE: when my ricoh afico 1018
SC320 is a polygon mirror motor error. It could be caused by a poor connection or a faulty circuit board, but the most likely culprit is the polygon mirror motor itself. Replacing this motor (part #G0291961) is the most likely solution.
Hope that helps!
Posted on Sep 24, 2010
Richo afico 5002 code sc 878
1. Improper firmware update.
2. SD Card size greater than 2 GB used.
3. Multiple ROM data folders in SD Card.
4. Improper Java firmware update.
5. Power failure during firmware update.
6. Power line issues on the outlet.
Replacement of the Controller Board is necessary in case SC Code 878 occurs.
Apr 11, 2017 | Ricoh Aficio Office Equipment & Supplies
Erorr problem code sc 336
No such error code. There is a 363. That is for a bad yellow developer unit.
Sep 09, 2014 | Ricoh Aficio Mpc 3500 Color Copier
Ricoh Aficio MPC 2500 error SC 442
image transfer belt contact sensor is dirty clean it
Feb 17, 2014 | Ricoh Office Equipment & Supplies
Error code sc 791 ricoh aficio mp 2500
  • Description:Bridge unit error
    The machine recognizes the finisher, but does not the bridge unit.
  • Causes:Defective connector. Broken harness.
  • Remedy:1. Check the connections between the bridge unit and the machine. 2. Install a new bridge unit.
Dec 15, 2013 | Ricoh Office Equipment & Supplies
Imprimente ricoh afico 1224c sc670
SC 670 - Engine response error.
After powerig on the copier machine,a respons is not received from the engine .possible defect controller board or SBCU installed incorrectly.Try reset the code to turn ON/OFF the main power switch.
Mar 01, 2013 | Ricoh Aficio 3232c 3214c 1232c 1224c Oil...
Sc 305 1075 afico
SC305. Occurs after replacing charge corona unit.
trnsp.gifAnswer [Cause]
PCU-side quenching lamp has come loose from bracket.
[Action]
Return quenching lamp to correct position.
Aug 20, 2011 | Ricoh Aficio 1035 Copier
Eror sc 500
Apr 08, 2010 | Ricoh Aficio MP 2000 Black and White...
Im having an error sayig SC:542 so how can i solve this kid of problem?
This is a 'fuser" warm up error. You could have a blown out heater lamp, or fuse, but most often this is caused by a power fluctuation. The reset for this is done by simply entering the service mode, and turning the machine of/on with the main power (red button).
enter service mode as follows:
"Clear Modes"
" 1, 0, 7 "
then hold "Clear/Stop" for 2-3 seconds.
The display will change with "service mode" in the top corner.
Now turn power off/ on (red switch)
** Never go further into the service mode, as you can cause all kinds of difficulty.
If the code comes back, then you will have to get a technician on site to troubleshoot the fuser.
Please rate me :)
Apr 24, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Error sc 422
I HAVE THE LASER C522 AND I HAVE PROBLEM TELL ME REPLACE WASTE TONER
Feb 10, 2008 | Ricoh Aficio CL2000N Laser Printer
102 people viewed this question
k24674
jasbo
jasbo
