Question about Bosch Washing Machines
My washing mashine bosh logixx 8 sensitive is writing F18. What is that?
4 Suggested Answers
SOURCE: bosh logixx 9
probably have something blocking the drainage pump.
  • TURN OFF AND REMOVE PLUG
  • Remove the small circular plate on the front of the washer (turn so the little hole is pointing downwards, then give it a good shove)
  • find the black hose and pull the stopper out: drain the washing water.
  • open the big petrol style cap behind the circular hole.
  • pull the cap out (I had to use pliers to unplug)
  • clear the rubbish you find here (careful could be sharp)
  • put it all back together
  • PRESTO
Posted on Sep 21, 2008
SOURCE: F42 is showing on my
An error code of "F42" means your oven has a defective or jammed lower latch, latch motor or latch switch, which is preventing the lower oven's latch from locking properly. If all of the electrical connections are in place on your oven's power board, you may have a faulty power board.
Posted on Apr 01, 2011
ZJLimited
  • 17970 Answers
SOURCE: Hi I have got bosh
Error F18 means that the filter is blocked.
Look around for a propeller shaped part, it should be able to spin freely. If not, remove the debris so that it is unblocked.
Hope this helps
to solve it.
Posted on May 11, 2011
Bosch washer sometimes don't rinse
Have you cleaned out the filter in the bottom and made sure the pump is not blocked?
Apr 22, 2014 | Bosch Washing Machines
F18 error code on Bosch Exxcel washer/dryer, and water pouring out the bottom - any ideas on how to fix? Filter is clean.
Sump hose has fallen off Unplug tilt machine back have a look underside to check also could be the soap dispenser hose Hole in it.This rubs away on side of machine 5yrs old.
Sep 13, 2017 | Bosch Logixx WFT 2806 Front Load...
This might help you with the pump its on a bosch Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 04, 2013 | Bosch Logixx WFT 2806 Front Load...
Bosch Logixx 8 - unblocking pump/removing front panels
Bosch Logixx 8 Washing Machine This video will show you how to change the pump washing machine
And don't forget to like us on facebook
Aug 30, 2012 | Washing Machines
Hi I have got bosh logixx 8 1400 express and it is showing F18 on the display with an very annoying boop noise. Could u please help me in sorting out this . thanks
Hope this helps
to solve it.
Apr 18, 2011 | Bosch Exxcel WFO 2264 Front Load Washer
Can I get a user manual for a Bosch Logixx 1400 washing machine?
Hi.
Below a user manual for Logixx 1400. There are different models corresponding to Logixx 1400, if the manual below does not apply, please ask a new question providing full model number as on service tag.
Bosch - Bosch Logixx Sensitive Automatic washing machine
Sep 24, 2010 | Washing Machines
Bosh Washing Machine F18 fault
I also had this problem - the machine was full of water and it flashed up F18. I had to drain the water out of the machine using the small pipe located next to the drain filter. There was loads of water to drain out. I used my oven roasting tray which was perfect for the job. Then I undid the screwcap filter. There was a lot of really black water that came out, along with about two pounds worth of coins and some hairgrips. Now my machine works perfectly !
Sep 01, 2008 | Bosch Logixx WFT 2806 Front Load...
Bosch logixx 10 washing mashine
just turn filter cap. outer door is just a hinged flap
Aug 05, 2008 | Bosch Logixx WFT 2806 Front Load...
Bosh logixx 9
  • PRESTO
May 19, 2008 | Bosch Logixx WFT 2806 Front Load...
Washing Machines Logo
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
