Question about HP Compaq ProLiant DL580 G3 (364636HP1) Server
Fan speed is there any way you can set the fans to run at one fixed speed?
It's possible but not useable so I suggest you don't do any activity about this.
Posted on Sep 26, 2007
    Scholar:
  • 113 Answers
The fans keep the GPU's and CPU's at an "optimal temperature" that is why they start loud on "over RPM" and then quieten down and speed up again during heavy traffic or similar tasks. its possible just cut the ground wire to the fans. but i deeply deeply suggest you dont! ;) people like myself have desined the systems to operate with maximum GPU life and at an optimal count. good luck.
Posted on Sep 25, 2007
SOURCE:
My haier AC doesn't blow air. The green light does
Try to turn blower fan by hand to see if it turns freely, Place fan on highest speed try to spin by hand on highest speed , if it works you may need a new capacitor for fan motor if not try and jumper fan switch to see if it runs .
Oct 04, 2014 | Heating & Cooling
Casablanca fan intelli touch
there is a starter solenoid inside it works the speed setting. controls speed 1-2-3. 4 it bypasses it. in side the fan you will see a black box with c66 somthing that will need to be changed as that is the part that controls the speed.
Oct 17, 2013 | Dryers
IMac (mid 2007) fan speed running super fast after replacement of Hard Drive
The clue is in your first few lines. Put the sensor back where it came from.
Jun 09, 2012 | Apple 20" iMac Desktop
Need a fix for a loud processor fan!
Take a can of compressed-air, and give a "blow-job" to the cooling-fan, to remove all the dust, which is acting as "insulation", causing the computer to run "hotter", and causing the motherboard to spin the fan faster, to try to make the computer run "cooler".
Or, enter BIOS SETUP, and check the fan-speed settings.
If the fan-speed is set to "100% for 100% of the time",
try a lower setting (which will be quieter).
Oct 23, 2010 | Gateway 560GE PC Desktop
Kenmore over the stove microwave,model # 721.62629200,only low speed fan works on the keypad,no high speed fan.
The fan has a setting for high speed, low, and off. Fan only running at low speed.This indicates problem towards. 1) the fan motor. 2) The loose fan wiring. 3) The fan switch. IN the unit there is a motor for fan.If the motor gets weak or short. The fan will run but only at low speed.Because at high speed the motor will require more power to run.In this case motor needs to be checked and replaced. The other possibility is the fan wiring.There are two wires going from fan to motor and two going from motor to power board.If any of this wire is got loose or getting short then this will stop the fan to run in high speed.In this case the wires needs to be checked and reconnected properly. In the unit there is a switch internally.When you select the fan to high speed mode the switch goes up. when you select the fan to low speed mode the switch turns down.But if the switch is faulty or got worn out.Then it will not move properly up/down.In this case switch needs to be replaced.IN some brand models the High speed and low speed are directly controlled from front control panel.There is no switch in that models.In that case the control panel needs to be checked and replaced. Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Jun 10, 2010 | Kitchen Ranges
My hunter remote control ceiling fan doesn't go real fast. the highest speed is what a normal fan would do on medium. is there a fix?
if you have pull chain switches in addition to the remote control, your pull chain switch may be set to Medium, which would make the fan run on a maximum of medium speed.
May 16, 2010 | Hunter 52" Ceiling Fan With Light And...
Casablanca fan only runs at highest speed
When I turn on any of the fan speeds fan does not come on. When I remove the blades and turn on the ceiling fan on and give it a push the fan stays running. What could it be?
Aug 30, 2009 | Casablanca Fan Panama II 50" Ceiling
Fan Speed Too Slow
You need to pull the fan chain until it is set to the fast setting, then you use the remote to set the fan at the speed you desire.
May 26, 2009 | Dryers
Hampton Bay Ceiling Fan At Slow Speed
I recently replaced my hampton bay fan for the same reason (slow at all speeds) and discovered scorched and melted capacitors and wiring inside the fan. My suggestion is to stop using fan and replace immediately.
Aug 10, 2007 | Hampton Bay 52 In. White Redington...
HP Compaq ProLiant DL580 G3 (364636HP1) Server Logo
421 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
