Question about Dirt Devil 2&1 Vac & Pressure Washer
Dirt devil pressure relief valve not working - Dirt Devil 2&1 Vac & Pressure Washer
Agent Don
  • 310 Answers
SOURCE: Instruction Manual needed for Dirt Devil upright model 088305
http://geeksquad.fixya.com/ThreadView.aspx?prdid=89362&thid=642772
Instruction Manual needed for Dirt Devil upright...
Posted by Innahouse on Jun 03, 2008
Describe your problem I need an instruction manual for a Dirt Devil upright model 088305.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Dirt Devil Model #M088300 Upright Vacuum. The best idea is to contact the Royal Customer Service Dept and give them the model 3 and serial 3 of the unit you are requesting the owner’s manual for, I will give you the website address and phone # listed below:
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://royalvacuums.com/ Customer Service 1-800-321-1134
Hours are: 8:00 AM to 7:00 PM (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 11, 2008
SOURCE: Dynamite Dirt Devil Hose
I figured out how last night.
Take a screw driver and unscrew the screw on the top of hose and take the hose out and take a pen or something long enough with grip to get all of the junk out.
The circulation still isn't as strong though.
Posted on Dec 12, 2008
SOURCE: dirt devil vibe 088915v
Are you talking about the beater bar? If so, you probably have a broken belt
Posted on Jan 16, 2009
  • 294 Answers
SOURCE: Dirt Devil Vision bagless not working
Check the dirt cup filter. remove the dirt cup and check for proper suction. if you have good suction, check your belt
Posted on Jan 24, 2009
  • 2976 Answers
SOURCE: No Wind Coming Out of Dirt Devil
The suction hole will never have wind coming out of it, it is for suction. To switch from floor to hose, turn the control knob labeled floor / hose.
Posted on May 02, 2009
No ending to JCB 8045 (2007 model) hydraulic system problems. I have changed valves and pump but still it stops working because the pump does not relief pressure and the engine dies. Any idea what is the...
The problem will be in the relief valve area of the pump. Check settings . Check that the relief valve hose is not blocking from internal failure. Check that the relief valve piston is not jammed from foreign bodies from unfiltered oil (dirt-rust etc)
Aug 07, 2013 | Garden
Is the reed valve part of the pressure switch
relief valve should only open in a over pressure condition. If it is opening prior to reaching pressure ....replace it.
May 21, 2012 | Air Tools & Compressors
Unable to locate what I think is the pressure relief valve located under the on/off box. looks like a small needle valve but leaks air constantly. any ideas?
If it leaks constantly until the tank is empty or very low, the problem is most likely a leaking check valve. The pressure relief valves mission is to empty the pressure line between the chech valve and the sylingers to facilitate unloaded restart of the motor. The check valve is usually mounted directly on the tank an connected to the large copper tube from the sylinders as well as the relief valve through a smaller and thinner tube (often nylon). Empty the tank, unplug the power and open the unscrew the cap of the check valve and retreive the spring and the valve disk and inspect for damages, foreign objects or replace if needed. Refit it and test run the compressor. If your problem is that the relief valve leaks only while compressor is running and just after it stops, the problem is likely to be the relief valve itself. This is usually an integrated and rather delicate part of the pressostat (pressure, on off switch box) and you may need to replace it as a unit unless you can clean it by pressurized air or gently dismantle it for inspection and cleaning or removing foreign objects or dirt.
Feb 16, 2011 | Craftsman 3 gal. Air Compressor, 1 hp,...
Pressure releif valve leaking
Hot water pressure relief valves serve two functions. The first is to remove high-pressure water from the hot water tank. The second function is to act as a high temperature valve to remove water that exceeds a predetermined point for the valve. Both of these relief settings are preset at the valve factory. Many pressure relief valves will come with a metal tag that identifies these release points. If you're attempting to remove the hot water heater pressure relief valve, pay careful attention to ensure that you replace with the correct valve.
Your hot water heater has a pressure relief valve safety mechanism. When pressure inside the water tank exceeds certain limitations, the valve opens up to allow the pressure to be released. A faulty pressure relief valve will not release excess pressure, which could cause extensive damage to your home. You should test the hot water heater pressure relief valve once every six months to ensure proper operation. If the pressure relief valve fails the test, replace the valve with a new one immediately
Locate the pressure relief valve on your hot water heater. The pressure relief valve has a lever handle on top with a drain pipe attached to it. The pressure relief valve is most often on the side of the water tank toward the top. Newer models of hot water heaters have the pressure relief valve on top of the water tank.
  • Inspect the area around the pressure relief valve for signs of leaking water. If there is leaking water near the relief valve connection, replace the relief valve. If no leaking is evident, proceed with testing the pressure valve.
  • 3
    Examine the area below the pressure relief valve drain pipe. Most water heater closets either have a drain in the floor below the pipe or the pipe is inserted into another pipe to direct the water out of the home. If the end of your drain pipe is not in another pipe or there is no drain in the floor, place a bucket under the drain pipe to catch water when you test the pressure relief valve.
  • 4
    Pull the lever handle on the top of the pressure relief valve up with your fingers. A working lever will lift up without difficulty.You should begin to hear water going through the drain pipe. Slowly release the lever to shut off the pressure relief valve. The pressure relief valve is good. If you did not hear water running through the drain pipe, lower the lever on the pressure relief valve and replace the valve. If the lever is difficult to raise, do not force the lever. Replace the pressure relief valve.
  • Now with all that said if you have a closed loop water supply system and you have a pressure vessal/expantion tank it may have gone bad and is making the TP valve leak. you can call your water provider to see if you have closed loop system.
    Feb 04, 2011 | Whirlpool Water Heaters
    The red pressure relief button on my GE Smartwater GXWH35F whole house Water filer system is leaking water, any suggestions? Oring, what do you lubricate the Oring with?
    Don't lubricate this O ring. Your trouble is not there.
    There is probably a small piece of dirt in the bleed valve (you are calling this a pressure relief though its purpose is to let the air out not provide relief from excess pressure). Press it several times to try to wash the dirt out.
    If this doesn't work, you might have to work on the valve from the inside.
    Jan 15, 2010 | General Electric GE SmartWater Household...
    My relief valve is leaking pretty bad. why is it dripping constantly?
    Before disassembling your valve try activating it a couple of times. Sometimes, especially if its dirt or sediment, it will clear the valve.
    Sep 28, 2009 | Water Heaters
    My compressor shuts off by itself after running a few moments. My pressure relief valve, that I used to be able to pull and release air from the tank, no longer exhausts. It only gives a click and a puff...
    SOUNDS LIKE THERE COULD BE DIRT OR RUST IN THE RELIEF VALVE REMOVE AND CHECK FOR OBSTRUCTIONS RELIEVE ALL PRESSURE BEFORE DOING THIS. SHOULD BE A DRAIN **** ON THE VERY BOTTOM OF THE TANK
    Aug 16, 2009 | Campbell Hausfeld Air Tools & Compressors
    I need a new manual for dirt devil easy steamer deluxe
    CLICK HERE for the owners manual in PDF format.
    Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
    Jul 19, 2009 | Dirt Devil Easy Steamer Upright Wet/Dry...
    Dirt Devil 2&1 Vac & Pressure Washer Logo
    24 people viewed this question
    Top Dirt Devil Garden Experts
    Dennis Key
    Dennis Key
    roeb
    john h
    Are you a Dirt Devil Garden Expert? Answer questions, earn points and help others
