Question about Sewing Machines
Crown point sewing machine
How do I thread the crown point 3100 sewing machine please
SOURCE: Kenmore Sewing Machine model # c877.15
I have an old Kenmore and here are the directions from my manual: 1. Draw thread from spool through bobbin winder tension discs. 2. Wind thread around an empty bobbin several times. 3. Place bobbin onto bobbin winder shaft with thread coming from rear of bobbin. Push bobbin winder latch against bobbin until it clicks. 4. Release clutch by turning clutch knob toward you. Start machine.
Posted on Aug 09, 2007
SOURCE: BOBBIN THREAD
omyGod!! Thank you sooo much!!! I changed the tension on the top of the machine, like you said and now, it is working beautifully, God bless You!!!
sandylou
Posted on Dec 08, 2007
SOURCE: threading a sewing machine
What do you mean you are unable to pull the bobbin thread through, elaboration would help solve the problem...
I suspect I'm having the same problem with you if it's anything to do with the top thread looping around in the bobbin holder.
Damn machine!
Posted on Feb 26, 2008
SOURCE: Shark Euro-Pro Sewing Machine
I had the same problem with my Shark Euro Pro 7133. My problem was in threading the upper thread. The manual does not quite explain so I had to figure this out the hard way.
In threading the upper thread . the thread first goes down from the spool througt a groove. When it comes up it must catch a silver lever that moves up and down before moving it down againPlease let me know whether this helps.
Posted on Jul 26, 2008
Michaelle
  • 65 Answers
SOURCE: need help to thread our sewing machine.
you really must get a manual for this machine.
You can find manuals online for a small price.
At one time some sites had them for free, but I haven't been able to find many recently. sewusa.com has some older ones for free. but not many. you could try the kenmore site as well, if not I'd try to search on dogpile.com (sewing machine manuals)
Just so you know, your manual is the MOST important tool for any sewing machine, and its worth a couple of bucks to get it.
Posted on Jan 24, 2009
Where are the oiling points and what would make the threads constantly break
Depends on your make & model machine. Newer computerized machines require little or no oiling. Consult your owner's manual AND use only good quality sewing machine oil.
Thread breakage:
#1--Avoid bargain bin variety and old thread!
Sewing Machine Problem 1 Thread Breakage
Sewing Machine Thread Keeps Breaking
Why Is My Thread Breaking How to Avoid Thread Breakage at Your Sewing...
Apr 07, 2017 | Sewing Machines
Manual for dial sew machine how to thread would be helpful to know how to set tension too
Search for:
Make Model threading
or
Make Model manual
Usually, the top tension factory setting is the midway point between high & low numbers. However, every machine differs and changes over time. But that is a good starting point.
Understanding Thread Tension Threads
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Mar 17, 2017 | Sewing Machines
The needle will not pick up the thread from the bobbin on my Babylock Crown Jewel
Make sure you are using a brand new needle. A bent/damaged needle frequently will not connect with the bobbin thread.
If it still does not pick up the thread, the machine most likely has a needle/hook timing issue. There are multiple web sites and videos available that discuss sewing machine timing, or you can take it for service.
Sep 15, 2016 | Sewing Machines
Why the thread cracked with when i sticked with the machine
Thread breakage could occur for several reasons.
First, try a brand new needle.
Second, use only good quality thread--NOT old thread or bargain bin varieties.
Third, when threading the upper thread, be sure to ALWAYS RAISE the presser foot throughout the threading process.
Verify that the thread path is correct (consult the owner's manual). Incorrect threading will usually break the thread.
Check that the upper thread tension is set at the midway point between the high & low numbers.
Why Does My Top Thread Keep Breaking Sewing Machine
NMSU Checklist of Common Machine Troubles
Why Does My Thread Keep Breaking While Sew
Aug 27, 2016 | Brother ES2000 Computerized Sewing Machine
How to thread a crown point sewing machine?
What Model?
Link to YouTube videos might be of some help:
Google
Mar 17, 2015 | Sewing Machines
Manual for crown sewwing machine 3100 need to no how to work it
If you need a manual for your machine contact
a1sewingmachine.com. They carry most manuals.
Aug 23, 2010 | Sewing Machines
I am unable to get the machine to work. The thread breaks all the
When you re thread, make sure you take out your straight needle threads. completely then re thread the entire machine again. If this does not work. Thread your machine turn all tensions to 0 and pull your threads through at the needle point. slowly.
Nov 23, 2008 | White Sewing Speedylock 1600 Mechanical...
Brother bobbin tread will not pick up
when i sew the thread keeps cutting help
Jul 29, 2008 | Brother XL-3500
When threading the bobbin the manual says to thread the bobbin through point a and then to thread it through point b until you hear a click - there is no waqy to thread the bobbin through point b - trying...
Hi
Thanks for using FixYa. While threading the top part you’ll need to pull the thread back and forth in the top thread guide and check the tail in front is not curly. If still the issue persists, then it means that the machine has a bad thread sensor on it and needs to be replaced. In this case you can return the machine and get a new one instead to take the gain of the warrantee.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Jun 02, 2008 | Singer CE-200 Quantum Futura Computerized...
BOBBIN THREAD
sandylou
Dec 08, 2007 | Sewing Machines
Sewing Machines Logo
46 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
