SOURCE: micro sd memory card not recognized
Make sure your usb mode is msc plugin your sansa and go to my computer click on Sansa folder and you should see your removable disk this is your expansion card
SOURCE: I HAVE BOUGHT A SANDISK 4GB MICRO SD HC CARD
What phone? Check user manual of phone to see if the music has to be in a certain folder on the card. Try reformating the card.
SOURCE: i cant format my memory card for my cell phone
If you look at the manual for your phone. there is a utility in your phone that can format your memory card.
SOURCE: How do i recover my forgotten password of micro sd
You can recover the password, the best way is to download a file manager to your phone. I recommend Best Fileman
In the file manager you'll find under- C:\System\mmcstore -the file you're looking for, you have to rename the file- mmcstore.txt -then send it to another mobile or your PC via bluetooth open it on the other phone and your password will be revealed.
Rename the file- mmcstore.txt -to just- mmcstore -there might be another file named- mmcstore.txt -to view your password rename one or the other- mmcstore1.txt -one is for your phone PIN number the other your MMC card.
good luck
SOURCE: I have a Sandisk 4Gb micro sd card and it only
Turn off the write protection by sliding the key on the side.Most pen drives have these keys.If you dont have such keys , it may also be due to some virus .Please scan your pendrive totally and Even then if it is not working then your pendrive is corrupt
