Vestax mr300 its getting no power
Hello, I need assistance with my vestax pcv002 mixer. i need to replace the power cord since it has gone missing. Can i get just any generic DC15-A power adaptor or not? the proper vestax ones are much...
Provided the store which sells the universal type guarantees the voltage and current factor as available on the original Vestax, you can proceed to buy the type.
Also the product must be a good one to work without heating or have reduced life due to poor quality.
Mar 18, 2011 | Vestax Dc15a Power Supply
Where can i send my vci 100 to get repaired ? neil mk
You don't give your location so start here:http://www.vestax.com/v/ Try contacting the two distributors here:http://www.vestax.com/v/wtbuy/ .
Aug 25, 2010 | Vestax Vci 100 Midi Controller
My Power supply keeps blowing out
Sir,
You are suggested to buy power stabilzer because some the thing which blows the power supply is unbalance voltage. which Power stabilizer resolve . hope fully this would work.
Aug 30, 2009 | Vestax Pmc05pro-Sl 2-Channel DJ Mixer...
Vestax pmc07 pro powers up, but no output through amp or phones????
most likely one or some of the op-amps are blown. you are using the right ac adaptor too? sometimes when underpowered it will give a low output. also are you getting a read out on the vu meters? if so then most likely the op amps. if there is no read out on the vu meters, it could be the input stage. have you also tried your mic and aux in too?
my suggestion is, that if its under warranty get it fixed.
Aug 30, 2009 | Vestax Pmc07pro DJ Mixer System
I just got a vestax vci 300 but there's no bundled software... where can i download the software and drivers for it?
Where did you get the Vestax from? The bundled software with the Vestax should be serato scratch itch which a special version of serato built for the vestax. This can be downloaded here:
http://www.serato.com/downloads/itch
I havent downloaded the software myself but I should imagine you put in the serial number of your vestax in the software and off you go. I doubt you would have to pay for it if you own a vestax, but I maybe proven wrong.
Regards Rob
Nov 26, 2008 | Audio Players & Recorders
Vestax pmc-o5 pro 2
probably just a cold solder joint on the power plug inside the mixer. Check with a meter, then repair(resolder) if needed.
Nov 24, 2008 | Vestax Pmc07pro DJ Mixer System
14 people viewed this question
 Grubhead
Grubhead
