Question about Homelite Consumer Products Tiller Attachment
Looking for a primer pump for Homelite htc12 tiller
I am trying to find a replacement primer pump (bubble) for my Homelite HTC-12 ut-22089 tiller. I have tried to find the part on Homelite.com but can't seem to find it on there. I would appreciate any help I can get. thanks.
  • Anonymous May 02, 2009
    I have the same problem
    Problem Solver:
  • 6 Answers
Hi, I live in cedar rapids, Iowa. I just bought a primer bulb for my htc-12 homelite tiller. You should be able to order as many as you need, but I don't have the part #. Find out what the part # is and call this # 1-319-393-0443. They have 2 sizes, the bigger one is for the chain saws, the small one is for the tiller.( they have both) Carefully pry the plastic band off the primer bulb, press the new bulb through the band, then go get a tube of permetex weather strip adhesive ( orange box, black adhesive). Don't buy any other brand!. Lay a thin bead around the base of the bottom of the ring, press into place and let dry for a couple of hours. This adhesive works on almost any thing, and is not affected by gas, oil, or anything.
Posted on Mar 31, 2010
  • Mike Westbrook
    Mike Westbrook May 18, 2012
    Arnold brand aftermarket part #490-239-0001 sold in most hardware stores contains three primer bulb sizes, one of which fits exactly. ( Do it Best #767989). I used acetone to clean the plastic retaining rings then applied cyanoacrylate glue (super glue) and held it together in a vise using stacks of 5/8" washers over both ends of the unit to serve as a press jig. It was dry in a few minutes.
Check wirh eReplacementparts .com they have had all the different parts i needed and their prices were half what the local guy wanted to order them for me
Posted on Sep 15, 2009
NEED PART # FOR PRIMER BULB ON HOMELITE BP30185
Thanks for providing the UT number.
When cross reference the carburetor part of up00651 it came as as Zama C1U-H36 which has a Zama 0057003 which is superceded to Zama 0057030
Mar 18, 2015 | Homelite Backpack Leaf Blower
How do the fuel lines rout on a homelite 45 including from tank, primer bubble to the carbeurator
Without the UT number from the saw won't be able to give more detail carburetor hookup. Here is a generalize fuel hook-up diagram.
Depending on the carburetor both of the fuel lines can be on one side only. The suction line connection for the primer is usually closest the the metering diaphragm.25331542-pzxv2dmyt02yqunciumgycfv-5-0.png
Dec 21, 2014 | Homelite Garden
Homelite htc 12 tiller.. motor runs ok but tines wont turn under load free wheeling they turn but under load no clutch?
Hi bh1149...
You have bad gears on the inside of the tiller gear box...
I had this same problem with mine.
You will have to take the gearbox apart in order to know what parts are bad.
Be sure to check the lube more often when you install the new gears/parts.
Go to the following website and order your parts.
Please take time to rate me
http://www.ereplacementparts.com/homelite-parts-c-18807.html
Sep 08, 2011 | Homelite Consumer Products Tiller...
Manual for Homelite model#ut60526
Not sure exactly what you need out of the manual, but if you are looking for schematics/parts list here is a .pdf document online that has the tiller broken down. Hope it helps.
http://www.ereplacementparts.com/images/homelite/UT-60526.pdf
Apr 23, 2010 | Homelite Consumer Products Tiller...
My homelite tiller stalls after 30-60 seconds of running. i changed plug and checked filter. gas is new
I'm assuming a 2-stroke engine. Does the fuel system have a primer button? Assuming that the answer is yes, the carburetor is not pumping fuel, but starting on the primer charge. Is the carburetor a Walbro brand? If so, got to: http://www.drystacked.com for a 12 page PDF on theory and repair of these carburetors. If the primer works, the main fuel line should be ok.
Sep 17, 2009 | Garden
Primer bulb is part of the fuel cap.
I have a Homelite Super 2 chainsaw that has a hole in the primer bulb on the fuel cap...will not prime. Where can
I find a replacement primer bulb fuel cap?
Jun 24, 2009 | Garden
Homelite htc-12 tiller starts but tines won't turn
No I don't need any help with this problem. I oiled it well and it broke free and works fine now
thank you
Feb 17, 2009 | Craftsman 8.50 Torque Rating Dual...
Homelite Consumer Products Tiller Attachment Logo
1,261 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
