Question about KitchenAid KERC507 Electric Kitchen Range
Range element does not work
One of the element (middle of the dual element)of the range does not work. The manual says to replace the fuse or to reset the circuit breaker. Question: where are the fuses or circuit breakers located on this model (KitchenAid KERC507) Thanks R?gent No?l
  • 1 more comment
  • regentn Sep 27, 2007
    This is not a solution but a sales pitch by "the dr", an offer for a solution as long as I'm willing to pay. I th tought that this site was a ligitimate site. I see that I was mistaken. Lost my valuable time even bothering.
    R?gent No?l
  • agdal Feb 26, 2008
    the dual element of the range does not work.
    Question:
    Thanks
  • volker05 Mar 10, 2009
    My one element doesn't work. All of the others do. The light says that the burner is on but the burner won't activate. Anyone have a soloution?
Model KERC500Y Standing in front of stove the Left front
burner won't heat.
Posted on Mar 24, 2009
  • 447 Answers
Very easy solution!!!chat with me online and ill step you through it save up to $65 (my in-home rate in florida is $75!!!!!!!)
Posted on Sep 27, 2007
SOURCE:
Top oven toast function not operating/element not burnt out but will not heat
The fuse on the oven may be burnt, this will not allow the oven to be hot, while other parts will be functioning. Check your owner's manual to see if your oven ignition system has a fuse. some are located under the cooktop, though locations vary. Replace it with the same size fuse if the fuse element is burnt.
Take care.
Aug 23, 2010 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
All four burners of my Amana ACS3350AS range stopped lighting today. The covers are in the correct position and no debris is blocking the electrodes, they simply stopped lighting. The power is on, gas...
hello,
what this indicate from your statement could be view from two ways ,that is the problem can check and solve from two way .
1 from the fuse or,
2.from the wire connections
what you are to do to solve this problem first of all put off all form of power supply connected to the range ,then carefully unscrew the screw use as key on the range with technician tools either screw driver or allenkey depending on the nature of screw use on the range then trace the wire down to the fuse at the back of the range
Locate the fuse. It should be near where the electrical cord comes into the range. The fuse is a small white bar with metal caps on either end. Carefully remove the fuse. Avoid touching the transformer or other parts inside the range.
Purchase a new fuse. Most range ovens use an 18 amp ceramic fuse. Consult your owner's manual to find out what kind of fuse is used, or take the old fuse into the store to find the exact match.
Replace the fuse. Put the cover back on and see if your range works. If it does, replace the screws. If it does not, try a different fuse. If the microwave still does not turn on, you may have to have it replaced of professionally repaired.
but for the wire connection carefully trace the wire down to the element it is silver in colour see if there is any form of loose wire connected to the element carefully replace the wire on the element then couple it back to is position with this the problem of the range will be solve .
thank you.
Aug 19, 2010 | Amana ACS3350AS Gas Kitchen Range
Oven wont heat
hello,
1) from the fuse or, (2) from the wire connections.
what you are to do to solve this problem first of all put off all form of power supply connected to the range ,then carefully unscrew the screw use as key on the range with technician tools either screw driver depending on the nature of screw use on the range then trace the wire down to the fuse at the back of the range
Replace the fuse.
but for the wire connection carefully trace the wire down to the element it is silver in color see if there is any form of loose wire connected to the element carefully replace the wire on the element then couple it back to is position with this the problem of the range will be solve .
thank you.
Aug 18, 2010 | DCS RDS-366 Stainless Steel Dual Fuel...
Can someone describe how the dual element, infinite replacement switch, part # as 8203538 works? What circuits are inside? KitchenAid Model # YKERC507HW2 is Canadian, but is there a possibility it is...
That switch controls the big burner and the middle or bridge burner. It works just like a single burner but it just does 2 functions: I have a video: HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 29, 2010 | KitchenAid KERC507 Electric Kitchen Range
Fisher Paykel electric oven doesn't heat in Bake mode
Electric Oven: Repairs and Maintenance Electricranges and ovens are generally easy to repair, because there's not muchto go wrong and there's not much you can do. Most repairs are actuallyreplacements, a matter of unplugging the old part and plugging in thenew. Most of the malfunctions that affect electric ranges involvefaulty heating elements.
Caution: Beforedoing any work on an electric range or oven, make sure it's unplugged,or turn off the power to the unit by removing one or more fuses ortripping one or more breakers at the main entrance panel or at aseparate panel. If the range is fused at a separate panel, this panelmay be located adjacent to the main panel or in a basement, crawlspace, or other location. If there is a grounding wire to the range,disconnect it. Make sure the power to the unit is off.
Servicing Fuses
Ifthe range or oven is receiving power but doesn't work, the unit mayhave its own fuse or circuit breaker assembly. This assembly is usuallylocated under the cooktop of the range. In some units, lift the top ofthe range to gain access to the fuse assembly; or lift the elements,remove the drip pans, and look on the sides of the cabinets. Inside theoven, look to the back to spot the fuse assembly.
Ifthe unit has this additional fuse or breaker system, components such asthe oven light, the range heating elements, the timer, and aself-cleaning feature may be separately fused.
If thesecomponents or features fail to work, don't overlook the possibilitythat the fuses have blown. To replace a blown fuse, unscrew the oldfuse and install a new one of the same type and electrical rating. Ifthe unit has circuit breakers, push the breaker or reset button, whichis usually located on the control panel.
Replacing Range Heating Elements
Whena range heating element burns out, it's easy to replace. But before youdisassemble the range to check or replace an element, make sure therange is receiving power. Here's what you can do:
Step 1:Check the power cord, the plug, and the outlet. Then look for blownfuses or tripped circuit breakers at the main entrance panel or at aseparate panel.
Step 2:Check the fusing system inside the range. If the circuit is broken,restore it. If the range is receiving power, go on to check the element.
Step 3:When the element is cool, remove it. In most ranges, each top heatingelement is connected to a terminal block in the side of the elementwell. To remove the terminal block, lift the element and remove themetal drip pan that rests below it. The element is held by tworetaining screws or is push-fit into the terminal block. To remove ascrew-type element, remove the screws holding the wires. To remove apush-type element, pull the element straight out of its connection.
©2006 Publications International, Ltd.
To remove a range heating element, remove the screws holding the terminal
wires, or pull the element straight out of its connection.Step 4:Test the element with a volt-ohm-milliammeter (VOM) set to the RX1scale. Disconnect one of the electrical leads to the element and clipone probe of the VOM to each element terminal. If the element isfunctioning properly, the meter will read between 40 and 125 ohms; ifthe meter reads extremely high, the element is faulty and should bereplaced.
To test a range element without using a VOM, remove aworking element from its terminal block and connect it to themalfunctioning element terminal. Don't let the test element overlap theedges of the element well; keep the element inside the well, even if itdoesn't fit perfectly. Turn on the power to the range. If the workingelement heats, the suspected element is bad and should be replaced. Ifthe working element doesn't heat, the terminal block wiring or theswitch that controls the element may be faulty. Call a professionalservice person.
Step 5:Replace a burned-out range element with a new one made specifically forthe range. Take the old element to the appliance-parts store; ifpossible, take the make and model information, too. This data willprobably be on a metal tag attached to the back service panel of therange. To install the new element, connect it the same way the old onewas connected.
Replacing Oven and Broiler Heating Elements
Electric oven and broiler elements are often even easier to test and replace than range elements. Here's how:
Step 1:If the oven element doesn't work, first check to see if the range isreceiving power. Don't overlook the fusing system inside the range.
Step 2: If the range is receiving power, set the timer on the range to the MANUAL position.
Step 3: If the element still doesn't heat, turn off the power to the range and test it with a VOM set to the RX1 scale.
Step 4:Remove the screws or plugs that connect the element to the power.Remove the retaining shield, which is usually held by two screws, andremove the element from the brackets that hold it in the oven. Theelement is usually held in these brackets by screws.
To remove an oven or broiler heating element, remove the screws or pull
the plugs that connect it. Remove a retaining shield and lift out the element.
Step 5:Clip the probes of the VOM to each element terminal. If the element isin working order, the meter will read from 15 to 30 ohms. If the meterreads higher than 30 ohms, the element is faulty and should bereplaced. If the element tests all right but doesn't work, the problemmay be at the terminals. Make sure the terminals are clean and tight atthe element connections.
Oven and broiler elements cannot betested without a VOM. If you don't have a VOM, take the element to aprofessional service person for testing. The problem is usually amalfunctioning element; however, you aren't risking much by replacingthe element without a professional test.
Step 6:Take the burned out element with you to the appliance-parts store tomake sure you get the right replacement part; if possible, take themake and model information, too.
To install the new element,place it in the same position as the old one. Connect it the same waythe old one was connected, using the same screws to hold it in place.Just about all the other components of an electric range or oven(including its door gasket, oven controls, and timer) are virtually thesame as the components used on gas ranges.
Most problems withgas and electric ovens or ranges are easier to fix than you think. Thekey is knowing how the various parts work and when to replace them.
Have a look at these websites to find parts and details :
http://www.appliancepartspros.com/appliance_range_oven.aspx
http://www.gallawa.com/microtech/dataselect.html
Mar 20, 2009 | Fisher and Paykel AeroTech Double - OD302M...
Replacing a radiant element on a maytag glass top range I'm having strange problems with the two right elements of my MER5770 The front larger dual element will only operate at high heat. When turning on...
If the burner is scorched or pitted, go ahead and replace it. New burners can cost anywhere from $10 to $40. Otherwise, check the burner's electrical connections to make sure there is solid contact. Jiggle the burner in its socket. If it is loose, then remove the burner—most just pull out of the electrical socket, although some are mounted with a screw. (Always unplug the range before removing a burner.) Slightly spread the two terminals apart for a tighter connection. If it still doesn't work, then replace the faulty burner with a functioning burner of the same size. If that burner works, then replace the bad burner with a new one. If it doesn't, then inspect the electrical socket for damage. If it's charred, replace the socket. To do so, remove the screws that secure the socket to the range and then unscrew the range wires. Attach the wire connections of the new socket to the range wires and reassemble the burner.
Aug 19, 2008 | Kitchen Ranges
Stoves 900DFa dual fuel cooker
check to see if one of the oven elements are burned into if you have an oven cord on it turn the breaker off and check the cord where it connects to the oven
Mar 15, 2008 | Stoves 900DFa Dual Fuel (Electric and Gas)...
Large Dual Element Is Not Working
Check the center ring. If it is open replace it.
Dec 21, 2007 | Maytag MER5765RAS Stainless Steel Electric...
KitchenAid KERC507 Electric Kitchen Range Logo
592 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Jay B
Level 1 Expert
Colin Stickland
Colin Stickland
ittco
Level 1 Expert
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
