Question about Sony Bravia KDL-40S4100 40 in. LCD TV
Lost the screws for KDL-42EX440 - Sony Bravia KDL-40S4100 40 in. LCD TV
Why is the picture so dark and how do I make it brighter?
Back-light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Aug 05, 2014 | Sony KDL-42EX440 - 42" LED-backlit LCD TV
My Sony KDL-42EX440 will not turn on
Have you tried to do a "reset" ALL modern electronic items often get "locked up" and unplugging them from the wall will often get them going again. Unplug for at LEAST 30 seconds--then try again. If this does not help--the SMPS board may have failed on you. A good repair shop may be able to repair the board instead of replace it.
May 06, 2014 | Sony Bravia 36 40 42 46 50 52 55 LCD...
Hi - we lost the screws to fix our sony bravia kdl-32v4000 to the table top stand in a move - can you tell me where I can get the 3 screws needed - thanks
I am guessing the screw size is M6/16mm , based on Sony official page for your TV:
http://www.sony.co.uk/product/tv-80-32-lcd/kdl-32v4000/technical-specifications#tab
Lowes or Home Depot or Ace Hardware (I prefer the latter for more knowledgeable employees). If no hardware stores nearby, try Sears or Best Buy (you may need to ask more than one person, don't give up too easily). If visiting a hardware store, you may have to look in the 'roofing' screw bins or nearby to find the right size.
You might also look for TV mounting kits that have that size screw, but you'd probably pay much more than finding the screws alone at a hardware store.
Dec 02, 2013 | Sony Bravia KDL-32V4000 32 in. LCD TV
How do i remove the table top stand from my sony bravio model KDL-52V4100
Need replacement screws for my sony 52v4100..I lost the screws for the table top
Jan 28, 2012 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
I have lost the three (3) screws that connect my flat screen tv to it's stand. How can I replace them? WHo can I order from? SONY KDL26S2010
There are 4 screws in Sony KDL-26S2010 that connect stand neck with tv and part number of screws is 258060201 .. SCREW, +PSW M4X12 available in partstore.com for $1.25 each
Jun 30, 2011 | Sony KDL-26S2010 26 in. LCD Television
Sony Bravia KDL-V40XBR1. Lost the main screw to the base. The one that secures to the bottom of the base into the tv. What size is it so I can replace it!
Required screws part number is as follows:
258064001.... SCREW +BVTP2 4X16
Available in PartStore.com for $5 each
Hope these info will help you.
Thanks.
Nov 26, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
We lost the screws in our move to connect our Sony Bravia KDL-46W4100 TV to the base. Can you tell me what 4 screws I need to buy to connect the TV to the base? Also lost the power cord, what cord do I...
You need 4 screws to fix base stand with tv, part number is as follows:
258060801... SCREW, +PSW M5X16
Available in PartStore.com for $5 each, click that link to view screw image and price info.
AC cord part number is as follows:
183514311... Cord AC
Available in PartStore.com for $13
Hope this will help you.
Thanks.
Nov 15, 2010 | Sony BRAVIA KDL-46W4100 46 in. LCD HDTV
Lost the screws that attached to the TV stand for KDL-40S4100. What type are they and where can I get replacement?
Required screw part number is as follows as per service manual of Sony KDL-40S4100 model..
7-682-973-49 SCREW, +PSW 5X16
and it is available in Part Store, click the link and I think TV needs 4 screws or so.
Thanks.
Sep 15, 2009 | Sony Bravia KDL-40S4100 40 in. LCD TV
Sony Bravia KDL-40S4100 40 in. LCD TV Logo
37 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
