Question about GE Cooktops
G.E. Electric Cook Top PP975 will not power up, I shut breaker off for 1 minute+ as book said still no power?
3 Suggested Answers
  • 254 Answers
SOURCE: Jenn Air ElectrCook top One of the cook top heater is not working
well it can only be a few things on a cooktop... u either have a bad element or a bad switch.......usually on most to replace either u must lift top up and out and remove the screws all the way round to open unit up...hope this helps let me know how it goes
Posted on Feb 26, 2010
  • 5370 Answers
SOURCE: My electric jennair down draft
It can be short in control board.The weak components on the board gets shot.Actually as you mentioned that circuit breaker tripped.When the components gets weak and board cannot handle the flow of current, at that time it trips the breaker, so that components don't get shorted.But if still the circuit breakers is turned on, then in some cases the breaker trips again or in some cases the weak components on the main control board gets popped out and unit quits working.------- As per the problem mentioned the main control board has top be replaced. But still get the voltage checked at the board.This will help.----------
You can get required parts from online sites like: --- www.repairclinic.com or from searspartsdirect online site.
----------- This should help. Thanks.Helpmech.
Posted on Jun 30, 2011
. Burners will not work unless the down draft fan is turned on and then neither works at full capacity.I flipped the breaker off and on.
Call Jenn-Aire to have a technician troubleshoot your cook top on site. You will save time and aggravation whether your cook top is gas or electric, possibly wired improperly, etc,etc,etc.
Apr 02, 2015 | Jenn-Air Cooktops
Electric cook top only gets 120 instead of 240V
see the diagram and fix it. You have lost 1 phase open the outlet wall and measure the phase, go to the main panel breaker open the circuit, and repair the phase, if you are NOT shure call some electrician.
God bless you
Sep 24, 2012 | Jenn-Air 35 in. JEC8536A Electric Cooktop
My electrolux iduction cook top sends error across the whole bord when I put anythng on the inductoin burner
You may try and reset the induction cook top by disconnecting the power to the unit for up to 30 seconds. This will clear most false error codes. You can disconnect power by flipping the circuit breaker off and back on. If the error code does not clear, then the unit more than likely can be experiencing an issue with the EOC and user interface board. This is not a typical do it yourself job; please consult a professional or your manufacturer.
Sep 11, 2012 | Electrolux 36" Electric Hybrid Induction...
I had cooktop on low and it started making noise. The ceramic top pitted in two places. Is it still safe to use. I used a flat skillet.
Sounds like there might be a short. If you are adventurous, I would tell you to open the top and look for shorts, otherwise, you will have to replace it because of the fire hazard.
Mar 22, 2011 | General Electric 30 in. Profile PP975...
Was using 4 burners and they all stopped working- electric burn smell in kitchen. External house breaker is not tripped
When you used all elements the power supply wire have been
gone to the maximum current absorbed so to the maximum heat. When the cook top
is new it can withstand this heat but due to long time used now you have burned
out wires and probably to junction point. So now the power supply wire is
burned and is open circuit thus not any power to the heater. The wires have
just open circuit and they don't touch each other or the metal body of the cook
top that is why you don't have the circuit breaker fuse to trip off. So now you
need to disassemble the cook top and you will very easily find the burn point
which should be melded and burned black and replace all parts that they have
been burned with new one.
Here is the link where you find the parts layout, the wiring
diagram and also order any parts you might need.
Also just for safety, avoid to use all four heater at the
same time in the future.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5170741&diagram_id=28477270#d28477270
Dec 18, 2010 | Maytag MEC5430BDS Electric Cooktop
How to un lock my GE Profile Induction cook top?
Try turning off the breaker for at least 10 min and re apply power. If this doesn't work, then there's an internal problem.
If after 10 minutes the cooktop is STILL locked:
Push the touch pad that looks like a padlock for at least 5 seconds. The lock light should go out.
Nov 15, 2010 | GE Profile JP930 Electric Cooktop
Breaker in panel tripped and won't turn back on
You may have a short circuit to ground fault in the electric cook top. Divide and conquer. Unplug the cook top and try to reset the breaker. If the breaker resets, then you have a problem with the electric cook top. If it doesn’t, then the problem is at the electrical panel side. Either problem will require a qualified technician’s assistance. I hope this helps. Good luck.
Jul 16, 2010 | GE 30 in. Profile JP938 Electric Cooktop
Power requirement
If you are running new wire to the cook top. You need to run 10x4 wire. The 12x4 wire is not large enough for the 220v. Also the 20 amp breaker is not large enough to run the cook top. You need to use a duel 30 amp breaker.
Good Luck and please rate 4 thumbs up for the free answer.
Jul 09, 2010 | Jenn-Air JEC6288AAB Electric Cooktop
How do i replace my burner on my jenn air ceramic cook top . it has the down draft feature in the centre
1) turn off power at the breaker. 2) remove hold down screws 3) pop up cooktop out of counter top 4) remove knobs and downdraft grille 5) remove ceramic top (screws around outside and also in side grille opening) 6) unplug burners replace with new burner
Sep 17, 2009 | Jenn-Air JED8430 Electric Cooktop
All 4 burners stopped working - circuit breaker ok
How old is this cook top stove? Does it require replacement?
Jun 11, 2017 | GE 30 in. JP385 Electric Cooktop
Cooktops Logo
49 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Jim London
Jim London
Are you a GE Cooktop Expert? Answer questions, earn points and help others
