Question about Performance Teknique ICBM-726 Super High Frequency Tweeter (300 Watts) Car Speaker
How mount icbm-726 automobile tweeters - Performance Teknique ICBM-726 Super High Frequency Tweeter (300 Watts) Car Speaker
Sx910 ski rack
Barrecrafters (Sportrack) Universal Roof mounted Ski Rack
Model SX-910
Universal roof mounted ski rack
will work most automobiles.
Do you have a " most " automobile?
Dec 17, 2017 | Cars & Trucks
I have a BMWx-309 Nitro Tweeters. Where do i wire? Front speakers on cd player,door speaker?
Assuming you do not have factory tweeters then either is acceptable. Use whichever is easier to get to...door speakers if mounting tweeters on door or cd player if mounting on dash.
Aug 04, 2016 | Cars & Trucks
How do I adjust the belt ona Toro 726 snowblower
There should be a tension pulley between the main pulleys. Usually it is mounted on the side wall and can be adjusted with a nut and bolt.
Mar 16, 2016 | Toro Power Max 726 OE Snowblower - 37771
I need to know if the specifications for the Perfomance Teknique ICBM-5712DX RMS total wattage is for both coils or per coil. The RMS total wattage rating is 500 watt
The 500W RMS total wattage is for both coils combined. If you want to get REALLY specific, all of the industry-specific specifications are as follows.
  • 12" Dual 4 Ohm Peformance Subwoofer
  • Power Handling:
    • Peak: 1000 watts
    • RMS: 500 watts
  • Impedance: Dual 4 ohm
  • Reinforced aluminum curvilinear cone woofer
  • Oversized butyl rubber surround
  • 5 spoke Die-cast aluminum basket
  • 2" Flat ultra excursion spider
  • Industrial Chromed Hex bolt retained T-Yoke
  • DC resistance (Re): 3.2 ohms each coil
  • Frequency range: 20 Hz-1.1 kHz
  • Fs:30 Hz
  • QTS:.526
  • QES:.614
  • QMS:7.698
  • VAS:56L
  • SD:.0491M
  • SPL: 89.58 dB 1W/1m
  • Xmax:16mm
  • Mounting Depth: 160 MM
  • Mounting Hole Dia.:282 MM
  • Mar 01, 2011 | Performance Teknique ICBM-5712DX 12in Car...
    Hello again. Sorry to say my knowledge is lil... I want to replace stock deck. Here is the stuff i want to put in it. Could you take a look and give an opinion if maybe i cant get away without putting a...
    ok as for the deck just get the wiring harness for your car so you dont have to cut the old one out and that would eliminate the need for a wireing diagram with that done you should be able to hook all speakers you want to the stock spot so for a tweeter just hook it up with the door speaker there arnt any extra cords....you will only need a amp for a subwoofer unless you choose to put your mids and highs on one and if you didnt want to change your deck hook up the tweeters would be the same way hope this helped
    Mar 30, 2010 | Car Audio & Video
    How do you install dome tweeters?
    tweeters get installed almost like any other speaker. you pick a mounting spot, then mount them, or cut the hole for recessed tweeters, etc. run the wire to the closest speaker wire from your stereo, and just splice it in. you will however need some kind of crossover to prevent the low frequencies from being played through the tweeters. if you buy new tweets, they usually come with their own crossover, or there are a few different styles you can get.there are the passive crossovers, the ones that look like small boxes. there are also the inline filters. these are the ones that you splice into the positive speaker wire to filter out the low frequencies. and some aftermarket stereos come with some kind of filter or equalizer built in, depending on your model. what I would do is buy one of the inline filters for each tweeter. theyre inexpensive, and easy to install, and they work great. so basically, just mount the tweeter, run its wires to an existing speaker wire and splice it in, and install an inline filter on the positive wire for the tweeter. oh, one last thing. if your interior speakers are powered by an amplifier and not by the stereo, then just run the tweeter wire to the speaker outputs on the back of the stereo. too much power will definitely destroy any tweeter. good luck!
    Sep 08, 2009 | Car Audio & Video
    I need to know who is better for my cherokee sport 1999 ..!!!
    Hello leonardoe,
    The MB Quart's are component speakers and the PPI's are coaxials. In an "apples to oranges" comparison, the MB Quarts win. Most component systems in the same price range as a coaxial will have better sound imaging simply because you can mount the tweeters up high for better high frequency dispersion. Some also allow you to make adjustments to the crossover, which is built-in and fixed on the coaxial.
    But component systems are more difficult to install. If your vehicle doesn't already have the wiring for separate tweeters, you have to install it. Likewise, the mounting of separate tweeters adds to the installation complexity.
    Hope this helps.
    Jul 15, 2009 | PPI PC650C Coaxial Car Speaker
    Tweeter and door speakers to fit a Lexus EX 300 w/Levinson factory system
    I found that they can hold up to 6 1/2" speakers and 2" tweeters. I'm not sure the specific mounting depth but i can almost assure you there wont be any 6 1/2" speakers that require a whole lotta space
    Feb 22, 2008 | Cdt Audio Eurosport ES-100 Car Tweeter
    Performance Teknique ICBM-726 Super High Frequency Tweeter (300 Watts) Car Speaker Logo
    14 people viewed this question
    Top Performance Teknique Car Audio & Video Experts
    hoyzee1
    Jose Velazquez
    Jose Velazquez
    George Nalley
    Level 1 Expert
    Are you a Performance Teknique Car Audio and Video Expert? Answer questions, earn points and help others
