Question about HP PSC 1510 All-In-One InkJet Printer
Scrunches up paper, wanta different pper
It says paper mismatch, but some times it wiill take paper and scrunch it up.
  • Thomas F. Schneider May 11, 2010
    because it is the wrong paper?
This is a possible solution as I had the same problem on a PSC 1510. You will need to rest the printer on its fron edge after closing the paper tray. With the bottom of the printer facing you you should see a small removable panel on the left hand side - it has one Torx screw in the upper left corner. Undo that screw and the panel can be removed - be careful not to dislodge the felt ink pad. Once the panel has been removed you will see a black plastic lever which pivots in a socket with one long arm extending to the right and a shorter arm extending down. Remove this arm and then reinstall it making sure that the small peg on the shorter arm sits in the long vertical slot of the black plastic slide inside the printer. Once you have done this the long arm should be close to horizontal. Replace the removable panel - making sure the felt ink pad is in place - and the problem should be solved.
I hope this helps.
chasmith
Posted on Apr 30, 2009
Paper gets jammed in roller
try to clean the rollers with alcoholic liqued
Nov 19, 2013 | Lexmark S415 - multifunction fax / copier...
LEXMARK x 2650 -- PAPER WILL NOT FEED INTO PRINTER CORRECTLY- WILL STOP AND SCRUNCH UP ON THE LEFT SIDE OF PRINTER FEEDER
Look very carefully inside where it scrunches up. you'll probably see another small piece of paper from a previous jam... remove it
Jan 23, 2011 | Lexmark Office Equipment & Supplies
My canon printer scrunches the paper on the right side
you may have a bad or off set roller you can try to callibrate it but more than likely it needs internal repair! good luck!
Dec 18, 2009 | Canon PIXMA MX310 All-In-One Printer
While printing, paper jams. the sheet pulls through initially, but then while printing, the paper scrunches up and the cartridge jams.
It is likely that there is a small piece of torn paper inside that is causing the paper to bunch up. Try a can of compressed air to clean out the interior and trace through the route the paper takes. Look for anything the paper could get stuck on.
Good Luck!
Nov 03, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Doesn't feed the paper in evenly and so it scrunches up to the right and goes crooked, and then jams.
mine did that and I had to clean the feeder wheels to get it to grab the paper.. I use rubbing alcohol to get the grime off...
Jul 17, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Paper jammed part way
try to unplug your printer and restart your computer..
May 13, 2009 | Lexmark X3550 All-In-One Printer
Paper Jams
Clean the rollers properly with IPA (Iso Propyl Alcohol) Industrial grade. Dot use solvents.
S. Mohan
Jan 14, 2009 | Ricoh IS 450DE VRS Flatbed Scanner
Hp photosmart 2610 all-in-one
sound like the feed rollers need cleaning.
Oct 16, 2008 | HP Photosmart 2610 All-In-One InkJet...
Paper Jam at exit
This happened with an old HP Laserjet 1100A of mine.
I had apparently dropped a screw in the paper-out slot and it was jamming the paper on just one spot.
As you know, the entire sheet is connected, so It is most likely a similar situation in which a previous jam has left a small wad of paper under one of the rollers, and this is preventing the paper from exiting the slot.
Best bet, print something and see where the paper is scrunching up. This is most likely the roller that has the paper stuck under it. Remove the toner block and blast some compressed air into the spot the jam is most likely originating and see if anything else flys out.
Also, if that does not work, you might try manually rotating the rollers backwards, which will often eject the lodged paper chunk.
Note- Please be careful inside the printer! Do not touch the bright green drum, or anything that dosen't look like it is rubber and rolls paper around!
It is very easy to mess things up in there ;)
Sep 28, 2008 | Samsung CLP 300 Laser Printer
Lexmark X5150 paper feed problem
the rollers may be dirty or there is a small piece of paper stuck down in one of the tracks or channels..
Mar 03, 2008 | Lexmark X5150 All-In-One InkJet Printer
HP PSC 1510 All-In-One InkJet Printer Logo
59 people viewed this question
Seeker5211
Seeker5211
