Kyocera km 4850w
Close front door message will not go away
sir fixalot
  • 146 Answers
SOURCE: Kyocera KM 3050 - error C3300
Error C3300 is a CCD Automatic Gain Control issue.
It could be poor contact in the connector terminals from the SHD PWB to the CCD PWB.
It is more likely a defective exposure lamp or inverter board that powers the lamp.
Try lifting up the Document feeder so you can see the optics frame through the platen glass and turning off and then on, the main power switch to see if the green exposure lamp illuminates.
A better, but more complicated way to check the lamp is to enter the service mode and run the exposure lamp test simulation. I will outline this procedure below. BE SURE NOT TO MESS WITH OTHER THINGS IN SERVICE MODE OR YOU COULD RENDER YOUR UNIT COMPLETELY UNUSABLE.
To Enter Service Mode:
Hit the "Status" button
Hit the following sequence on the numerical keypad:
1 0 8 7 1 0 8 7
You should be in service mode.
Use U601 by typing 6 0 1 and then "Start"
U601: Turning the exposure lamps on
Description: Turns the exposure lamp on.
Purpose: To check the exposure lamp.
Display:
CCD: Main Exposure Lamp
CID: Document Processor Exposure Lamp (inside the feeder)
Method
1. Press the start key.
2. Select the item.
3. Press the start key. The selected lamp lights.
4. To turn the exposure lamp off, press the stop key.
Completion
Press the stop key. The screen for selecting a maintenance item No. is displayed.
After checking the lamp(s) operation hit "reset" a few times to back out where you can type 0 0 1 "Start" to Exit Service Mode.
Posted on Jun 03, 2008
leroyal
  • 2120 Answers
SOURCE: Kyocera Mita km-1820
Unplug the power cord for 10 seconds.
Posted on Jan 15, 2009
SOURCE: kyocera km-2050 scanning function
The km 2050 was on network, but moved to home and directly into tower system via usb interface connector. Printer works, but can not get scanner to work? read instructions without a clue. can someone help with correct proceedure?
Posted on Mar 12, 2009
SOURCE: I need to reset ID Code on Kyocera Mita KM-5530
The solution is easy! Push the Default Setting/Counter button on the top right side of the keyboard. Press the the Managment icon on the diplay. Enter 6-4-8-2 on the keyboard and select the Managment icon in the OFF position. Close all windows on the display and you should be ready to go.
Posted on Jun 18, 2009
cbtmaya
  • 84 Answers
SOURCE: error code C-6 for kyocera km 1500
c6-400 code error is poor connection (power supply)
press start and clear/stop button
the code is inizialized
Posted on Aug 31, 2009
I replaced the power supply and the machine takes a message to close the left cover
This would indicate that you have either not connected the connector from the door sensor to the relevant board,the sensor has failed or the door is not making the sensor.
Jan 19, 2013 | Kyocera Mita KM-2050 Printer
Kyocera Mita KM-2530 error close front coveR
The front door switch or actuator is broken or the door may be warped .Have you tried putting pressure on the front cover? as this may help to indicate if the switch is faulty.
Sep 10, 2012 | Kyocera Mita KM-2530 Laser Printer
I have a machine model number kma 4035. i am getting the error message as close the left cover1, please give me a solution
check the bottom small cover the ane under the main big one
its possible the micro switch that activates the door is faulty or got pusher inside the copier
or the pin on the door that pushes the switch is brocken off
Nov 21, 2010 | Kyocera Mita KM-4035 Printer
DISCULPE REQUIERO SABER EL ERROR A 400 DE MI COPIADORA KYOCERA MITA KM 1505, todo opera casi normal pero me bloquea con ese error a 400
bonjour ,j'ai une photocopieuse kyocera km 1505 et me marque le message erreur A400 ,y a t 'il quelqu'un qui pourrait me dire quesque c'est ce message là je vous remercie d'avance
May 02, 2010 | Kyocera KM-1505 Copier
Jun 17, 2009 | Kyocera Mita KM-4035 Printer
C-6400
1. turn off the machine and open the front door, after that turn on again.
2. when the machin turn on, tape the number 10871087.
3. in maintenence mode tape the number 163 end "start" button.
4. go to execute end press the "start" again.
5. close the front door and press the "clear" button
6. tape the number 1 end then the "star" button
7. the machine is pixed
May 19, 2009 | Kyocera Mita KM-2050 Printer
I have a Kyocera FS-2000D printer that will not print
first turn off your pritner power.
check open the front door pull your ink cartridge then clean dust and blur from it then check there is not any paper jam then refix ink cartridge.then turn on the power.
Mar 21, 2009 | Kyocera FS-2000D Laser Printer
OP error
OP stands for open door. Either the front door is open or a side door is open.
Hope this helps.
Jan 26, 2008 | Kyocera KM-1505 Copier
k24674
