Question about Grohe Grohmix Thermostat Valve & Trim - 34436
How to replace Grohe wax cartridge 47111 - Grohe Grohmix Thermostat Valve & Trim - 34436
Could my grohe thermostatic shower be letting cold water into my system? Some other taps run cool but the shower is running OK temperature
If you have single handle facute one bad cartridge in the system may be acting like a mixing valve and allowing cold water to mix with hot not allowing water to get hot enough .
Mar 10, 2015 | Grohe Water Heaters
Just replaced Grohe wax cartrige 47 111 000, still have slow drip. HELP! thanks, James
besides the cartridge, the small brass screw/valve and its seat can cause this leak
Dec 10, 2011 | Grohe Grohmix Thermostat Valve & Trim -...
Install trim and adjust the thermostat on a Grohe shower faucet
Before you install the temperature control knob, adjust the valve body (47111) with a wrench to set the temperature to "100 degree or close to it". Now, place the limit ring to tdc (top dead center) and control knob with the red 100-degree align to it. Your problem may have been the valve's temperature setting is out range when you installing the temperature control knob.
Jun 28, 2010 | Grohe Grohmix Thermostat Valve & Trim -...
I have a grohe power shower wich only has cold water coming out. if i replace the thermo catridge will this solve the problem
It has been a while since I have worked on a Grohe, But if it has a built in scald gaurd or thermo cartridge, it may be sticking and need to be replaced.
May 02, 2010 | Grohe Integrated 1/2'' Shower Thermostatic...
We have a Grohmix shower valve and we are unable to adjust the water temperature. Any assistance would be appreciated.
Oct 20, 2009 | Grohe Grohmix Thermostat Valve & Trim -...
How do I remove grohe shower trim?
norm cover levers off go round cover at four points
Oct 14, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
Grohe bath faucet adjustments
grohe is a faucet all by itself ,,, I would recomend to have you call there repair dept. and explain this to them, you said you put in the new cartridge and thats about all there is to it, when you put on the handle make sure it is not over tightened, sometimes it pulls on the cartridge and makes it come on by itself good luck
Feb 21, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
GROHE FAUCET DRIPS FAUCETS IS A 34-434
yes this is definately the cartridge.You might not have to replace the cartridge.First take the cartidge out and see if their is any dirt causing the water to pass thru the spout.If thiers nothing obstructing the cartridge than you will need to get a new one.
Jan 25, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
Grohe Grohmix Thermostat Valve & Trim - 34436 Logo
537 people viewed this question
Top Grohe Water Heaters Experts
Paul Carew
Craig Butler
Craig Butler
ray gallant
Are you a Grohe Water Heater Expert? Answer questions, earn points and help others
