Question about Tefal Aquaspeed 170 Iron
How to dismantle a CALOR Pro Express Turbo GV8360 Steam Iron
snakehead
  • 1074 Answers
SOURCE: My Tefal Steam Generater Iron will not steam
check the little tube that regulates the water to the holes it needs to be changed.good luck.
Posted on Apr 18, 2007
SOURCE: Tefal Pro Express Steam Generator doesn't.
OK... so I have fixed my problem of NO STEAM, just lots of water coming out of the iron press plate itself... I had already cleaned the boiler, so I tried adding 1/4 tsp - 1/2 tsp bicarbonate soda to the water and flushing it through. From what came out of the iron press plate, I would say the problem was caused by a build up of goop (technical term) inside the iron. Once cleared, the iron is steaming away again. Please note, u will need to have an old towel handy if this is ur problem, 'cos until it starts getting better, there is a fair amount of water coming out of the iron press plate. Just add the bicarb to the water reserve and use the steam buttons to bring the bicarb through. Do not attempt to iron clothing with the bicarb in the water!!! Carolyn ;)
Posted on Sep 20, 2008
SOURCE: Tefal Pro Express - Constant Steam
Found this on another site and just tried it. Put 50/50 water and vinegar in the tank and leave it to go through on the constant steam. Give it about 5 minutes then try the button. Mine gave an extra spurt of steam at this point but still continued giving steam out all the time. I refilled with the water vinegar mix and just kept pressing the steam button and letting it go through. Eventually it fixed it and the constant steam stopped. Something to do with a piece of limescale blocking the solenoid but that's all Greek to me! Hope this helps. Kind regards.
Posted on Feb 04, 2009
ginko
  • 19396 Answers
SOURCE: Tefal Express 1750 has water dripping from it when using steam
That means that water is not heated properly and does not produce steam.
Try a complete descaling, often this happens because the water reservoir and heating element is covered with scale.
Posted on Feb 17, 2009
aguywithfeet
  • 20 Answers
SOURCE: Iron causing electrical fuse to trip
I would almost definitely say yes. Have a friend or family member bring their iron over and try it. I can think of no other reason why it would trip a breaker. Let me know what happens.
Posted on Apr 02, 2009
I have a Tefel Protect Turbo Anti-Calc Autoclean Pro Express Iron. When I press the steam button it just pours out water out of the metal plate?
NOT being an expert on Irons but I'd pretty much guess if water is pouring out where steam is suppose to come out, then the heater element that makes your steam is not working.
Jun 09, 2017 | Irons
I have a tefal pro express turbo GV8150 and there is constant team coming from iron without me touching the steam button. Can anyone help with a diagnosis and or possible fix?
constant steam means the control valve is not working
descaling may fix the problem
the other fix is a new iron as the cost to repair is generally more that a replacement price
Sep 30, 2016 | Tefal Irons
My Tefal pro iron sometimes makes noise and dont steam any more?
get rid of the calcium,and use distilled water for steam,not tap water
Jun 20, 2015 | Tefal Pro Express GV 8120 Iron
I have a Tefal Pro Express Turbo iron (purchased in 2005). In the past 2 days the steam is constantly on - the button does not appear to be stuck. I can't get the steam to stop... unless I take out...
Yes, if your electric cord was extremely hot to touch is not common. It's posing danger to your unit and to your entire electrical system that may cause fire. Please let a qualified electrician inspect and repair your unit. The unit thermal fuse may not functioning that automatically switch off or cut the electric power of your unit when it gets too hot. Thank you for asking.
Jun 14, 2011 | Tefal Pro Express GV 8120 Iron
2 yr old Tefal Pro Express Steam generator Iron Trips Fuses
hello does all the electric go off in your home if so theres a bad earth on the iron or the iron element is shorting out also make sure theres no water getting into the iron good luck
shaun
Mar 20, 2009 | Tefal UltraGlide plus 1656 Iron
Tefal Pro Express
  1. solenoid valve blocked
  2. swich for steam broken
  3. you forget it in turbo steam mode and you have steam all the time
ps see below on link turbo button
http://www.gostore.com.au/~ebay/krups/tefal/proexpressturbo/TefalProTurboAuction(3).jpg
Jun 22, 2008 | Tefal Ultraglide 1549 Iron
Tefal steam generater pro express turbo
Most of the time the electro mechanism release the steam still open and not able to returning in closing position.Try to cclick quite few time to excite the mechanism and some times work.Also can be the micro switch defective.
Good Luck
Jun 09, 2008 | Irons
Tefal Aquaspeed 170 Iron Logo
144 people viewed this question
Top Tefal Irons Experts
Henry  Thomas
Henry Thomas
Are you a Tefal Iron Expert? Answer questions, earn points and help others
