Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Got tv from friend want come on
I have a rca 52in hdtv when i push yhe power button it will light up and then go off and make a clicking noise and then the button will light up and try to come on agian
  • soileaui Apr 26, 2009
    The tv comes on then goes off. Just like the other customer, it will make a clicking sound.
  • jandjmayo May 03, 2009
    I have a 60 in rca bigscreen hd monitor...it will not come on when i push power button, either on remote or on front panel.it usually showes the grn led light and then goes off then comes on and then off again.
    help!!!!!!
Its over heating I have the same problem! the quickest fix is
to find away to get cold air blowing to back of TV. also move away
from any heat.
good luck
Posted on May 03, 2009
I have a 62" rca led hdtv.. when I push the power
How many times does the light flash each time? Also whats the full model number of your set?
May 30, 2011 | RCA Televison & Video
Hello, I have a 52in RCA projection tv, model D52W20BYX1. It used to work fine but now whenever i try to turn it on it the power button light turns on and the tv makes a short whistle sound, this happens...
Not sure why chat got closed/ disconnected.
There is big transistor TL010 attached with heat sink near flyback transformer, this is horizontal output transistor, check it and replace if found shorted.
Thanks.
Apr 08, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
D52w19 rca hdtv.will not tourn on. when u push the
Hi Friend,
Please folliow the below steps one by one
Step 1: Turn on the TV
Step 2: Hold the ON/OFF Button for 10 to 20 Secs
Step 3:Without taking the hand from the ON/OFF button unplug the power cable connected to the wall outlet from the TV
Step 4:Without taking the hand from the ON/OFF button put the power cable back to the outlet
Step 5:Now take the hand from the ON/OFF Button and try to turn it ON again and check
If still you are having the same problem then please check the resolution configured in the Screen,try to reduce the Colour and the brightness of the TV
Even after that you are facing the same issue please check with the Display Card in the TV,
If you have any Clarification please feel free to contact us
Regards,
Ayyasam
Apr 03, 2010 | RCA D52W19 52" Rear Projection Television
I have a RCA D52W19 52in Rear Projection HDTV and the light flick
Deflection board , its bottom board to the left has FBT flyback transfomer CK capacitors cp 150 2200uf 16v use 25v and two more cp114 cp120 220uf 35v if cp 150 is puffed up on top it is bad replace All 3 capacitors for parts call Mats Electronics 1-800-628-1118, also For Deflection replacement board Call Encompass Electronics Parts 1-800-638-3328
Nov 11, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have an RCA 52in Rear Projection TV. One day it
There is a sub-board in this set that powers the convergence circuit. Often a big Ic shorts, two diodes and finally the main fuse. not something you can fix yourself.
Nov 05, 2009 | RCA P52926 52" Rear Projection Television
My RCA HDTV D52W23 Will not Turn On!!
Trying installing a new power supply. This is the main problem with tv's with the issue. But if you just bought it I would try to get my money back from where I bought it from. Installing a power supply for a tv is not that hard at all.
Sep 03, 2009 | RCA D52W23 52" HDTV CRT TV
Power button to tv
i have a friend who has this tv and the same problem. i called a repair shop abd i was told it is the high voltage converter. $400 to pick up drop off and repair.
Feb 23, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA TV Will Not Power On - Powered Off Suddenly
I have the same problem. Just Monday it started, Green light blinks but nothing comes on. Any suggestions?
May 31, 2008 | RCA HD52W59 HDTV Projection Television
Is there a reset button for 52in rca hd ready rear projection tv?
Most likely there was one or more marginal connections on the main board and moving the set has completely opened those connections. If you can solder, try resoldering any connections on the boards that appear to be grainy or have rings. Update this with the results. That may resolve the problem. If not, we'll look further into the set for component failures.
Dan
May 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
204 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
