Question about Dell 924 All-in-One InkJet Printer
Dell 928 all in one inkjet printer error message 1102/1103 what does this mean
  • 59 Answers
SOURCE: Dell 810 All-In-One InkJet Incompatible Ink Cartridge error message
Well, first off ,it's dell's fault, not yours. Even Official Dell cartridges are temperamental at best. The cartridge error you are explaining is common with Dells. They even have what's called a marriage issue, meaning the cartridge will work in only one single printer. However, I'm not sure how to fix it. Sometimes, you can install a new one and the other cartridge you never touched gives you fits, and goofs up. I'd say get a new printer. Dell is increasingly getting more stingy with their ink, and truth be told, I don't think their quality (*lexmark makes dell, so stay away from them too) matches HP or canon. If you want the best cost per page, get a canon that has individual ink cartridges. They are easy to refill, and print a great picture. You pay more $$ up front, but you'll save a ton in the long run
Posted on Jan 07, 2008
Ajkill
  • 2035 Answers
SOURCE: Hardware Error 0502
  1. Switch off the printer using the power button.
  2. Disconnect the power cable from the back of the Lexmark X5150.
  3. Leave the power cable disconnected for 30 seconds.
  4. Reconnect the power cable and switch the printer on again.
  5. When the printer powers up, you will need to select the desired settings.
  6. If this does not resolve the problem
  7. You need to check the encoder strip on the printer. This is a clear strip running the length of the printer, above or behind the cartridge carrier.Its a transparent plastic strip ..Please be very careful with strip if its broken then printer will not work...
  2. Disconnect the power cable from the back of theprinter
  4. Slide the cartridge carrier to the middle of the printer by taking the top part of the belt and moving it gently to the right.
  5. Take out both cartridges.
  6. Place an index finger on the encoder strip on either side of the cartridge carrier.
  7. On the back of the cartridge carrier, there is a small slot that the encoder strip fits into. Slightly push the encoder strip down and then back up to get it into the slot.
  8. Lightly press the strip first to the rear and then forward, if necessary.
  9. Clean the encoder strip with a dry tissue. Also clean the contacts of the printer
  10. Try to make a copy..
Good luck....
Posted on Dec 04, 2008
  • 15 Answers
SOURCE: Dell Laser Printer M5200
There is a small flip lever that monitors the paper output. If this gets stuck it will give this message. This is on the left side where the paper exits the printer. You may also have a bad sensor but most of the time it just gets stuck.
Posted on Jul 05, 2009
  • 226 Answers
SOURCE: dell 926 all-in-one inkjet printer compatibility
no it is compatible with xp, 2000, and vista but not mac sorry most of the dells are not compatible with mac systems
Posted on Jul 21, 2009
tbreeze47
  • 3083 Answers
SOURCE: Hi.How can I resolve auto alignment error 1105 on
First of all, bookmark the following page- it will help with this and future error messages:
http://support.dell.com/support/topics/global.aspx/support/dsn/en/tree?treeid=324464
Next, go to this thread on the site and enter information and read about the possibilities for this error:
As you will see at the end of the thread, Dell ink cartridges are water based, and can start drying out after a period of time. Some have had success using a lint-free cloth and water or alcohol to loosen up the dried ink, so you might try that. Otherwise, new cartridges might be in order. If your cartridges are good, you will have to contact Dell Support or obtain a service manual for the printer, to further investigate the problem.
Also, I just read on this blog that the cartridges have a sensor on them that cannot be reset if the cartridge is refilled:
http://en.community.dell.com/support-forums/peripherals/f/3528/p/19339711/19724412.aspx
What will they think of next?
Good luck, hope this helps, and thanks for using FixYa.
Posted on Sep 11, 2010
Error fatal 928 how to fixe it
Error 928: Fuser Motor Lock Error An error was detected with Fuser Motor rotation by overload. If rebooting the machine does not improve the symptom, you need to check the Fuser Unit.
Sep 09, 2014 | Oki Data Americas, Inc. OKI C 711n -...
What is Cartridge Error 50C?
Error message 50C in the Dell A940 All-in-one means that the ink cartridge(s) are seated improperly.
Here are basic steps to try that should resolve the issue:
1. Reseat the Ink Cartridges.
2. Unplug the printer from the back, clean the contacts and the put back the connection.
3. Verify whether the Ink Cartridges are DELL Branded.
4. Try Cartridges Individually.
Jan 22, 2011 | Dell A940 All-In-One InkJet Printer
Error code 0502 hardware error on dell printer
i once fixed the hardware message by putting the tape back on the back of the cartridge...then fixed the perpetual paper jam message...
Feb 19, 2010 | Dell 922 All-In-One InkJet Printer
Says cartridge error 50C, see manual but i can't fix it
The error basically seems to mean that one or both of the cartridges is defective. It had me take out one cartridge and see if the error happens again.
I had both cartridges in and I got the error message2.gif. I took out the color cartridge and the error message went away. I put the color one back in and I got the error message again.
I replaced the cartridge and everything works fine.
Nov 09, 2009 | Dell A940 All-In-One InkJet Printer
'928 Fatal Error message' on OKI C5550MFP
928 - fuser motor lock error
take out fuser and check for paper stuck on roller
make sure roller can move
if roller is stuck or damaged, repalce fuser unit
Apr 11, 2009 | OKI C5550N Multifunction Printer - Color...
Jan 07, 2008 | Dell 810 All-In-One InkJet Printer
Printer hangs and prints slow
Dell replaced it for a 928 printer which is fine. Apparently the 810 won't work with vista
Oct 23, 2007 | Dell 810 All-In-One InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
214 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
