Question about Scotsman Ice Machine - 290lb Self-Contained Air-Cooled Cuber - SCE275A-1H
Low ice output - Scotsman Ice Machine - 290lb Self-Contained Air-Cooled Cuber - SCE275A-1H
    Novelist:
  • 187 Answers
Low ice production has multiple causes. First check condensing coil to see if they are dirty and not passing air. This is the most probable cause for low ice production. Next, measure freeze cycle time and harvest time. Freeze time is typically 20 to 30 minutes and harvest time is normally 1.5 to 3 minutes. If freeze time is long (> 35 minutes), first check water valve shuts after reservoir is full. If it does not shut off the water solenoid operated valve needs replaced. Second, find the harvest solenoid operated valve which branches off the compressor discharge and port high temperature gas into evaporator during harvest and see that evaporator side of harvest valve cools down to surrounding temperature in a few minutes 8 - 10 after freeze cycle starts and harvest time stops. If it does not cool off the valve is leaking by its seat and will require a technician to replace. Lastly, if long freeze cycle could be due to low refrigerant and will require and tech to charge properly. Ice machine are critically charged and a tech will know how to charge the right amount. Again, it is possible the metering device is not passing enough refrigerant and a technician can determine this by checking the superheat and subcool. Low subcooling <3 and a high superheat >20 typically indicate an txv (metering devise) needs replaced and will require a tech to replace.
Posted on Sep 30, 2014
My taylor 152 only makes about 5 ice creams then won't produce any more for about 6 minutes ... why ??
The Taylor 152 is at the low end of output when it comes to commercial soft serve equipment. It is rated for 102 3.5oz. servings per hour, but only 4 3.5oz rapid servings before it needs time to recover.
Possible remedies:
When you need to serve several cones in a row, you can pull the feed tube in the top. That will help the product fill the cylinder a little faster.
You could always consider a used Taylor machine that has the ability to keep up with your demand. Soft Serve Parts Taylor Machines
Apr 07, 2017 | Taylor Ice Cream Makers
Where is the low pressure control and why cant the timer be bad on the ice o matic ice machine
Low pressure switch is usually in the control box which has a cap tube that connects to the low side of the system the timer can be bad but all a timer does is add a few mins to the end of your cycle but if you not making any ice you may have another issue
Apr 04, 2014 | Ice-O-Matic ICEU220HA Undercounter Ice...
Our Antari Ice low lying fog machine is warming up (light goes green), however when you press the controller to produce the fog, nothing comes out. The fan is working, but no fog coming out. Any urgent...
check the fluid pump's output. you may have have a clogged or kinked supply hose to the pump or in the copper tubing from the pump to the heater. Also, check the power to the pump. if it's not the pump, then you have to consider a clogged heater block. This is common if the machine is not cleaned before storage. That's about all that can go wrong on a fog machine other than the switches on the controller. Good luck!
Oct 17, 2013 | Antari Ice Low Lying Fog Machine +
I have a problem with refrigerator G.E. NEW, model GSMF3REXAFWW, SERIAL AT407090, is the water solenoi(tube for output is FROZEN) NOISE in the motor, and No output ice. Can you indicate what is goin...
It may be the fan in the back of the freezer. If this goes out the cold air can no longer circulate upwards. One symptom of this is the water line freezes.
Sep 03, 2011 | Heating & Cooling
I have 1998 mitsubishi montero sport my a/c not working. However compressor is working fine but still a/c not working. Please advice
How do you know compressor is working?
Is clutch engaging and output (small pipe) getting hot?
Then could be low freon, moisture causing ice plug, bad control valve, etc.
Jun 05, 2010 | Cars & Trucks
No lights on the circit board What is the output voltage for the transformer tamura 3A0172-01 26D285H I have 2.9 1300 series Thanks Bill
The output on the transformer is 12 vac make sure the Bin control is closed the toggle in the Ice position and also check wash valve handle is closed (micro switch behind handle)
Dec 07, 2009 | Hoshizaki Freezer Commercial Ice Machines...
HEAT PUMP PROBLEMS
Defrost cycle is to allow frosy or ice to melt down and not restrict the output air. The thermostat is set too low and in high humidity ice forms quickly restricting the air flow. tur up the thermostat and let the room cool gradually.
May 26, 2009 | Heating & Cooling
Ice maker output very low volume
Hi!!! check your filling tube line going into the icemaker its a white tube that gives water to the icemaker.It might be plugg of ice..get a hai dryer and aim it for 30 minutes good luck..
Jan 05, 2009 | Kenmore 52632 / 52634 / 52639 Side by Side...
Ice maker jamming up...
I had a similar problem. I cured mine when I increased the water pressure to the ice maker. I had been using the output of my reverse osmosis unit to provide water and the pressure was too low. I added air to the bladder of the water storage tank to the max allowed by the RO manufacturer. I rarely have a problem any more.
Hope this helps,
Glenn
Nov 09, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Heat Pump Not Performing up to par...
This sounds like a small freon leak. If you have a low pressure cut out switch, it should cut the compressor off before it gets too low. If you have a lot of ice on the outside coil, then maybe the defrost board or the sensor has went bad. But because you said it is running continuously, I think its low on freon. Unless you own a set of gauges for this equipment, call a pro.
Dec 28, 2007 | Heating & Cooling
Scotsman Ice Machine - 290lb Self-Contained Air-Cooled Cuber - SCE275A-1H Logo
103 people viewed this question
Top Scotsman Refrigerators Experts
t-stat
Level 1 Expert
John Tripp
John Tripp
john h
Are you a Scotsman Refrigerator Expert? Answer questions, earn points and help others
