Question about Avid M-Audio BX8 D2
Jensen power a322hlx - Avid M-Audio BX8 D2
How can I get a manual for a Jensen multifunction player tuner wall mount stereo. AWM965
Here you go.
PDF]AWM965 - Jensen RV Direct
https://www.jensenrvdirect.com/.../awm965_owners_manual.pdf
Translate this page
Features. Features of the Jensen AWM965 mobile audio system include: ... Mounting the Radio. Route power ... Press the MUTE button (3) to silence the audio output in tuner, CD, DVD, USB or auxiliary input mode. ... your portable CD / MP3 / iPod or other media player) into the AUX A/V IN (AUX 2 IN) ... Manual Tuning.
manual for Jensen multifunction player tuner wall mount stereo AWM965...
Mar 23, 2017 | Jensen Car Audio & Video
Why does my Jensen TV keep looping?
try leaving off for about 15 minutes then turn back on may have a button battery for mrmory if so will need to remove for a couple minutes hand
Jun 28, 2014 | Jensen Televison & Video
Will there be interference if I hook a Jensen MDV6115 to a 120 volt tv?
Under no circumstances must you use a different voltage ! The power supply on these units are designed for 12v only.
However, if your question is simply referring to connecting the AV 'outputs' (i.e. yellow, red, white rca's) of your Jensen, to the AV 'inputs' of our TV, then that is fine. The AV outputs can be treated the same as any other video device.
Feb 07, 2013 | Jensen MDV6115
I have the jensen cd3720 cd player and it stop playin music and comes back on by it self what can it be that makes the radio do that
Are you losing complete power? Or do you have power, but losing sound only?
Loss of Power:
If you can access the wiring loom of your Jensen, check the RED ignition wire to ensure its secure - this wire is responsible for powering the unit ON (with key ON) and OFF (when key is OFF). A multimeter will be a useful tool to check for power when key is ON.
If the RED wire is fine, then there could be an issue with the power supply on the unit. Check the fuse on the Jensen unit - if ok, then there is a fault in the Jensen unit.
Power, but no sound:
The unit is faulty and will require service (or replacement).
Jan 07, 2013 | Jensen CD3720 CD Player
Jensen LCD JE1907DC keeps looping the Jensen intro logo.
I don't have a solution but do have the same problem.
I took it in a reputable shop and they told me the main board was gone and they could not get parts for it.
I just found out that Jensen is a Audiovox trademark.
May 18, 2009 | Jensen Televison & Video
I hook up my jensen and i'm not geting no power
check the fuzes on the radio and on the car.  You may have tapped into a wire that turns off with the key
Mar 11, 2009 | Jensen VM9510 Car DVD Player
400 watt jensen amp not hitting.
Not to be mean but jensens have never hit as far as i know
Jan 29, 2009 | Jensen LXA400 Car Audio Amplifier
New unit wont power on
Here is the manual:
http://mobile.jensen.com/jensen/docs/man/NVX200_DOC_OM.PDF
If that does not work send it in for warranty repair. Click the following link to setup the repair:
http://voxrightnow.custhelp.com/cgi-bin/voxrightnow.cfg/php/enduser/ask.php
Hope this helps!
Thanks
Mar 24, 2008 | GPS
Jensen uv8 wiring issues
The wires you posted need not go anywhere not unless you have a device that will attached to them.
antenna power - connects to the motor of a telescopic external car antenna. When you power on the unit, it will automatically raise the antenna;
amp power - connects to an add-on/external amplifier. This switches/triggers the amp to gon when the Jensen is powered up;
reverse - attaches to the reverse light of your vehicle. This will tell your unit that you are reversing and will activate a rear view camera.
As earlier stated, if you do not have any use of these devices then there is no need to connect the above described wires to anything. Connecting them to the ground would have a bad effect on the internal circuitry of the Jensen since they are meant to supply power and therefore are connected to the B+supply when the Jensen is powered except for the reverse which would sense a 12V from the vehicle's transmission. Connecting them to the constant B+12 would have no ill effect except that your Jensen would always be on.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
good luck and kind regards.
Nov 20, 2007 | Jensen VM9510 Car DVD Player
Avid M-Audio BX8 D2 Logo
32 people viewed this question
Top Avid Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Avid Audio Player and Recorder Expert? Answer questions, earn points and help others
