Martin as40w/hw40w/ms40w lp logs will not stay lit
2 Suggested Answers
  • 13 Answers
SOURCE: my universal lp forced air heater model 30 fsa wont stay lit
if its lit by a pilot your thermocouple is bad the purpose of the thermocouple it to keep the gas valve open
Posted on Feb 07, 2010
Manuel for model#As40W/HW40/ fireplace logs
DexCool...standard antifreeze for GM products.
Nov 30, 2017 | Heating & Cooling
Whirlpool WFG510S0AS2 range - stove burners work just fine, but both the oven and broiler does not stay lit. NOTE - this unit has been converted from natural gas to LP
when the lp conversion is done , it is normally just a jet size change that is done
however the air shroud has to also be adjusted to get a clean blue burn of the flame
The just jet change results in a slightly yellow flame which is incomplete burn of the gas and that creates carbon build up at the jet and burners causing partial blockage
I would suggest that you call in an accredited gas fitter to check the problem and if necessary , clean the jets and adjust the air shroud
Dec 30, 2015 | Whirlpool WFG510S0AS
Martin Gas Logs Model 18TCP Lost Flame including Pilot and will not relight. What could cause this?
if pilot is there when it is depressed in pilot mode then the thermocouple is bad.if no pilot gas check for inlet pressure to log set
Jan 03, 2011 | Desa International CCL3924PTA 24" LP Gas...
Piloit won't stay lit.
I would check to make sure thermocouple is in proper position in pilot flame. If so and pilot won't stay lit I would replace thermocouple. Thanks
Nov 12, 2010 | Bosch & Tankless LP Hot Water Heater
Burner will not stay lit
try to replace the regulator on the grill
Mar 20, 2010 | Ducane 30400042 (LP)
I have a set of propane gas logs. The pilot light
Check the connection of the thermocouple or replace it if connections are tight.Pilot safety valve may be badreplace gas control valve.
Oct 24, 2009 | Desa International CCL3924PTA 24" LP Gas...
My universal lp forced air heater model 30 fsa wont stay lit
Oct 24, 2009 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
The pilot light & will stay lit. untill the burner cycles on/off
MAKE SURE THE BURNER TUBE AND ORIFICES ARE CLEAN. MAKE SURE YOU HAVE THE PROPER LP PRESSURE.
Oct 05, 2009 | RTO Atwood Water Heater - 6 Gal LP
144 people viewed this question
k24674
jasbo
jasbo
