Question about Pool & Spa
Usq1152 parts diagram
Stationary connection wiring diagram 230v 1.5hp pool pump USQ 1152
KMusselmann
  • 247 Answers
SOURCE: got a waterway 1.5 hp 1 speed 115/230v, wired 115 need 230
Is there a coverplate where the wires come out of the pump? If so, remove the plate and there should be a wiring diagram inside.
Good Luck
Kurt
Posted on Mar 18, 2009
john224
  • 1378 Answers
SOURCE: Need to get diagram to wire gould century 1.5 h.p.
Email me at john@arrowmotor.net and I'll reply with the .PDF from AOSmith. You need to move a couple of wires but as they say, a picture is worth me typing a thousand words.
Posted on Aug 27, 2009
MOTORWIZJ
  • 1340 Answers
SOURCE: I have a Hayward 1 HP pool pump. I have to
hi ...the two yellow go on one side of the cap and the red /white go on the other.. like two on the negative side of a battery and one on the pos .. your pool pump repair guy longwood fl
Posted on Apr 07, 2010
john224
  • 1378 Answers
SOURCE: Low/High Switch wiring for Hayward Superpump
I do not read anywhere that you have a 230V DPDT switch which you will need in order to select the high or low speed. You will have 6 terminalas on the switch. Line connections usually go to the middle set. Put put sides of one pole to the common terminal and put one of the other posts to the hi and the other to the low terminal. I prefer to use am on-off-on switch so the switch in the middle turns off the pump. Flip it one way for hi and the other for low. If you post your stock number from the two-speed motor I could give you a more accurate diagram if you need it. Generally, 1 is common, 2 hi and 3/4 low.
Posted on Apr 26, 2010
  • 8404 Answers
SOURCE: pentaire 011486 wiring diagram
My friend, my experience with the two speed pump in low speed is less than spectacular. There is so little filter action with the lower speed as to render the process useless. If you are trying to save $, better to run the pump a little longer then turn it off. My experience is in a commercial application. I run three such pumps in that system ... the additional expense of the two speed motors was a waste of capitol. In addition, as a commercial facility, we could not meet the required water turn over rate in our pools. Of course yours is a smaller body of water and you are probably not in a commercial facility. We get a LOT of cleaning (through filtration) at night, after the customers go home.
I suppose you could run your system with a intelematic switch ... I have not seen a 'three way' switch in this line ... having said that ... to my way of thinking ... you would wire directly through the selector switch on the back of the motor to each of two intelematic's; one on the high side and the other on the low side. I would allow at least 30 minutes between the two cycles to prevent impeller damage.
Thanks for your interest in FixYa.com
Posted on Aug 02, 2010
How do I wire up a A.O. Smith 3/4hp PB4 Booster Pump for 230V operation?
Here's some more info diagrams for you http://www.electricmotorwarehouse.com/aosmith/AO_CONNECT.PDF L1 is one hot wire L2 is the other hot wire. L1 can not be connected to a L2 wire and L2 can not be connected to a L1. Ground only to ground.
May 27, 2014 | AO Smith 1.5 hp Swimming Pool - Jet / Well...
I have a AO smith ST1152 and red black and green wires. How do I wire it
Verify the voltage to the pump. These days motors and pumps largely are set to run on 230v out of the box (for in ground pools). If your supply voltage is 115v, the motor will run at half speed. This would cause poor suction. If this is the case, do this:
On the side of the motor there is a diagram on how to convert the wiring from 230v to 115v so it will run on the correct voltage. Most of the time, that's the issue. Flip the breaker off before working on it.
Nov 30, 2013 | AO Smith Pool Pump Motor Hayward Swimming...
Pool pump wiring diagram
usually wired for 220 volt from factory 1st hot to L1 2nd hot to L2 green to ground or case
Jun 14, 2013 | Sta Rite Pool & Spa
I need wiring diagram for Gould Century Pump motor 1081 Part # 8-142776-20 1HP 230v/120v
www.bestbuypoolsupply.com/media/motormanual.pdf
This manual has the wiring diagrams both hi and lo voltage for
part # 8- 142776 -20 gould century 1081m 1 hp , pool pump motor 230/115 volts.... plus several similar motors
May 25, 2012 | Plumbing
My motor is wired for 230v and I need it to be 115v
It should be. Look closely at the motor nameplate and you should see a small diagram telling how to connect the motor for 115v or 230v. Most newer pumps have a small selector of some sorts. Either a plug that pulls off a couple post the include an idicator arrow for where to set the plug for either voltage, or a dial you turn to show it. Either way, you should be able to set the motor for 115 rather easily.
Jun 14, 2009 | Pentair Whisperflo 3/4 Hp 115/230v
Got a waterway 1.5 hp 1 speed 115/230v, wired 115 need 230
Good Luck
Kurt
Mar 18, 2009 | Waterway Champion 1 1/2 Hp 230v Energy...
Pool & Spa Logo
79 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
