Question about Dryers
IT DOESNT HEAT
It dosent dry the clothes
  • 4 Answers
Gas Booster valve solenoid wire breaks because of constant heating and cooling. Can be fixed by reheating solenoid contacts with soldering iron.
Posted on Apr 24, 2009
The heat is there but it doesnt dry the clothes
You have one of 2 problems. Your clothes are getting put into the machine too wet because the washer isn't spinning them out all the way. Or you have a clogged vent causing the unit to take too long to dry properly because it can't remove the moisture properly. Check your vent outside to see how hard the dryer is blowing the air.
Nov 27, 2013 | Zanussi TC7114W Electric Dryer
My dryer DLE 2514W does not dry the clothes enought, we have to put it on for a second time to get them all dry. Seems to be alot of heat but doesnt dry the clothes
disconnect vent hose and run a load of clothes, if they are dry then the vent hose is restricted/clogged. if for some reason it is doing the same then take dryer apart and clean from lint screen back, I am almost certain that it is the vent tube.
Dec 23, 2010 | LG DLE2514 Electric Dryer
My gas dryer heats but doesnt heat correctly, takes along time to dry the clothes
Hello
When the dryer wont dry clothes or won't heat at all it means that the issue is with the Thermostat/Thermal fuse that needs replacement as it has gone bad. Please check the thermostat for continuity as no continuity between its two pins states bad fuse. Please get back to me if you have any other questions.
Kevin
Nov 10, 2010 | Dryers
Timed dry dosent seem to work as well. other settings woork but not as well as used too.
Are we talking about clothes not drying ? If we are you need to check your lint duct for a restriction not just the hose behind the unit but all the way to the outside vent.turn on unit go outside to vent should feel a good flow of warm air.Over time these ducts get restricted and it happens slowly then one day you relize its taking a lot longer to dry than it used to.. To dry clothes properly you need more than just heat ,you need good air circulation to remove the moisture otherwise all you end up with is warm moist clothing......Hope this helps Good Luck
Aug 08, 2010 | Whirlpool GEW9250 Electric Dryer
Dryer end cycly without cloths drying. Doesn't
IF DOESNT HEAT UP ANYTING CHECK THE THERMAL FUSE AND REPLACE IT IF NECESSARY!!!
IF IT DOES HEAT UP A LITTLE IS NOT THE FUSE!! IT COULD BE THE EXHAUST PIPE (DUCT) CHECK THAT IS NOT BLOCKED OR CLOGGED!!!!
Oct 05, 2009 | Kenmore Elite HE4 Electric Dryer
Dryer does not heat
check the heater and fuses.
Jun 28, 2009 | Roper RGX4634KQ Gas Dryer
Dryer is slow to dry clothes, takes 2-3 cycles of 45-50 mins.
Check to see if there is a built up of lint in the exhaust.
Keeping the correct temperature at all times inside the dryer ensures that the clothes will dry efficiently. If clothes are not drying then inspect the door seal for signs that it may be worn or damaged.
A blower wheel that is not firmly attached to the drive motor can slip and therefore not move air fast enough to properly dry clothes or even reduce airflow to the point where the high limit thermostat may trip and turn off the heat circuit. A loose blower wheel will usually make a rumbling noise as well. Inspect the blower wheel to make sure that it is tight to the motor shaft.
Apr 19, 2017 | Whirlpool Dryers
Dryers Logo
71 people viewed this question
Top Dryers Experts
