Technics su a900
I have a Technics stereo integrated amp SU-A900 connected up to a CD player and a turntable and a laptop. The current Drive light comes on after a few seconds of being turned on but it drops out every half hour or so. I took the top off and there is a fat cable that was trapped between the lid and the metal thing that gets hot - so I moved that, there doesnt seem to be any bad wiring or soldering so put it back together and it doesnt happen as much but it still cuts out - this isnt at high volume or anything - any help would be great as its such a nice amp otherwise!
    Problem Solver:
  • 9 Answers
I have the same TECHNICS SU A900 MKII as you are talking about and it always runs warm I think using 4R speakers instead of 8R speakers should solve the problem and actually I am thinking of switching to 4R as well.
Posted on Aug 26, 2016
5 Suggested Answers
SOURCE: Problems with the Operation circuit on Technics SU-A900 MKII aplifier.
Did your amp make a bang and then the problem started ?
Posted on Dec 15, 2007
megatronix
  • 57 Answers
SOURCE: Technics SU-V2 keeps cutting out
An amp will cut out if the output protection circuit kicks in. This circuit compares output power against the preset level. Each channel has it's own, independent protector. There are calculations that can be done, but for a novice the rule of thumb is to "never use a speaker with a power rating less than the amp AND a lower impedance than stated". Typically using a 4 ohm load on a 8 ohm system is inviting disaster. Even if the system does not become a smoke generator, you might notice that though "louder", the sound quality is deteriorated. Many "audiophiles" often hook up some combinations of speakers to have "surround" without really understanding that the collective impedance actually changes (generally lowers).
Posted on Jan 21, 2008
SOURCE: amp cuts out
The fan is ageing and putting noise on the protect line. Replace it or put a 100 uf cap across the fan at the plug. Beware polarity is marked wrong on p.c.b.
Posted on Feb 23, 2008
  • 130 Answers
SOURCE: Hello I have a Technics SU-V45A amp, it's about 18
See there is a problem with the volume conroller as it is 18 years old the controller has worn out replace the volume controller with a new one and you will be able to enjoy great sound again
Posted on Dec 05, 2010
Technics SL-L20
Hi, any turntable and amp are compatible. Modern amps however without dedicated phono inputs require the use of a preamp. Cheers john. Stylus City
Apr 29, 2014 | Technics Audio Players & Recorders
How do I hook up a stereo reciver to the technics su-g91
I assume you want to use the SU-G91 as a power amplifier to drive your speakers. If your receiver has connections for inserting an equalizer (may be labeled pre-amp output and power amp input), remove the jumpers between the pre-amp and the power amp, then run cables from the pre-amp to the SU-G91 inputs. You can have an equalizer between the receiver and the integrated amplifier.
If this is not available, use the recording output (for a tape recorder on older receivers). Note that the volume control on the receiver will be bypassed with this connection.
Sep 23, 2012 | Audio Players & Recorders
I have a technics su-g91 integrated amp. everything is disconected from it and the yellow over load light is on. What do I do?
hi...i have a electric guitar and i was wondering if i can conect it in my technics su-g91amp?
Nov 24, 2010 | Audio Players & Recorders
My technics su-a900 mk2 keeps blowing the internal fuse
Sorry but it sounds like a problem with the power supply unit.
Look for any 'burnt looking' resistors on the printed circuit board and that should give you a major clue!!
Nov 22, 2008 | Technics Audio Players & Recorders
Technics SU-G91 OVERLOAD PROBLEM
THe amp has detected a problem and shutdown to prevent further damage. This unit has 2 amp pacs inside and one or both have failed. If you can solder, you can fix this yourself. The main amp pac is an SVI3206 and can be purchased online for about $60.
Keep me posted.
Dan
Oct 17, 2008 | Audio Players & Recorders
Technics su-a808 amp & sh-ge70 graphic equaliser.
connect your media source(dvd-cd player)to equalizer in-connect equalizer out to amplifier line in-or aux in-connect amplifier out to your loudspeaker.
Jun 24, 2008 | Audio Players & Recorders
TECHNICS SU-V50
Hi max
I have done a followup with Technics Parts agents in the US, they will get back to me and then me to you shortly :) A vote as FixYa would help improve my ratings. Thanks
Graeme
Feb 06, 2008 | Technics SUV500 2-Channel Amplifier
Technics SH-AC300 Connection to Power Amp & Pre-Amp
Hi!
The problem is, that your SH-AC300 needs an amp with 5.1 input (but no decoder). For this purpose technics delivered SA-AX710.
So if you'd like to use your current equipment it would be impossible.
The only option is for you to buy 2 more Power Amps (SE-A900S), so that each of 3 amps would take care for one part of music. (one for FL, FR; one for RL, RR; and one for sub and center).
Another option is for you to buy SA-AX710. Then all the problems would be solved with it.
Jan 15, 2008 | Technics SA-DX950 Receiver
187 people viewed this question
 Grubhead
Grubhead
