Question about LG 4-door French Door Refrigerator Lmx28988st
MULLION MOUNTING CLIP ON TOP IS BROKEN ON MY LFX28978ST
The door spring came off of hamilton beach 31100
The door of the Hamilton Beach Model 03008 or similar toaster oven does not stay closed when the door return spring or the hook it connects to breaks. The repair is very simple and takes just a few minutes!
The door spring is about 1 inch long and connects to a small clip on the inside of the left side panel of the unit. To see the small clip and the door spring, you simply remove the left side panel of the toaster oven which is done by removing just one screw.
The mounting clip on the side panel for the door return spring is located about half way up the side panel near its front edge.
The other end of the spring (its bottom end) connects to a metal hook. If the spring is not connected on its bottom end then the wire hook is broken. This is a simple repair that only requires a few inches of metal wire.
The other end of the metal hook (its bottom end) is connected to the bottom of the door hinge where it inserts into a small hole in the left side mounting hinge of the door.
When the steel hook breaks on either end then the spring cannot function, so the door does not stay closed.
To fix this problem, you simply get a piece of steel wire that is about 1/16 inch thick and a few inches long.
Bend the wire to make a hook at one end that the spring will connect to.
Then insert the other end of the wire into the small hole on the left side mounting hinge of the door. Then bend the wire on the inside of the hole to make a U or hook so the wire stays mounted in the hole of the door hinge.
Then adjust the position of the bend on the other end of the metal wire so the spring will have good tension when it is attached to the hook and to the clip on the side panel.
To do this you make the U shaped bend on this end of the wire to be about 1/2 inch from the end of the open end of the spring when the top end of the spring is attached to the mounting clip on the side panel.
To attach the spring to the wire hook, first remove the spring from the mounting clip. Then hook the spring onto the hook (bend) you made at the top end of the wire, then just stretch the spring to connect it to the mounting clip. The door will now stay closed.
Nov 10, 2013 | Hamilton Beach 31197 120 Watts Toaster...
The mullion is broken in my Lg refrigerator
I have a related question. My lower spring broke and I have the replacement spring. How do I put it into both plastic fittings at the same time. One arm on the spring goes on mullion while the other arm goes into a fitting on the door. Please help!
Aug 15, 2012 | LG 4-door French Door Refrigerator...
Need to stabilize machine and have granite countertops
Ask a local granite fabrication shop to get you some dishwasher mounting clips. They look like a perforated disc of metal with a small nut brazed to one side. They come with a short screw that attaches through your dishwasher mounting tabs. Place your dishwasher where you want it relative to the cabinets and pick a hole in the mounting tabs that won't leave the clip protruding and attach the clip to the chosen hole. Use masking tape on the top of your dishwasher door, wipe the bottom of the granite and the top of the clip with acetone, then use a gel-type two part epoxy from your local hardware store to attach the clip to the granite. Use enough to make the epoxy push through the perforations in the clip as this is how the epoxy grips the clip. Push the clip to the bottom of the granite and close the dishwasher door, using a wood shim or two between the top of the door and the mounting tab/clip to push the clip tight to the granite. Pull the shims out once the epoxy has cured (check the instructions on the epoxy).
Feel free to contact me with any questions. Brandon Wiese - Brandon@StoneRepairman.com - http://.www.StoneRepairman.com
Nov 20, 2010 | Siemens 24 in. SL84A305UC Built-in...
Mounting my dishwasher to granite counter tops. Granite Grabbers last about a week before they loosen up
Oct 21, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
Just did a kitchen remodel, kept the Bosch dishwasher model SHU9955UC, contractor having problems will attaching dishwasher to granite. Any suggestions? Thanks!
Sep 24, 2010 | Bosch SHU9955UC Built-in Dishwasher
How to replace starter motor on golf mk 4
Before you start, disconnect the negative terminal of the battery. Unplug clip on plug from starter solenoid. Remove nut for battery cable on starter solenoid. Remove nuts on starter mounting bolts that hold the brackets for the wiring harness [top mounting bolt] and the power steering pipe [lower mounting bolt]. Lastly remove the starter mounting bolts and remove starter. Re-assemble in reverse order.
Jun 11, 2010 | 1998 Volkswagen Golf
What dose the crank sensor look like and where dose it go on a 99 dodge dokota
Please don't forget to rate!
  1. Remove the air cleaner assembly if necessary for access to the sensor.
  2. Disconnect the pigtail harness from the sensor.
  3. Remove the nut holding the sensor wire clip to the fuel rail mounting stud.
  4. Remove the sensor mounting hardware, then the sensor.
  5. Remove the clip from the sensor wire harness.
To install:
  1. Install the sensor flush against the opening.
  2. Install and tighten the bolts or nuts, as applicable.
  3. Install the electrical connector.
  4. Install the clip on the sensor wire harness.
  5. Install the clip over the fuel rail mounting stud. Install the clip mounting nut.
These 4 pictures are for the Automatic:
These are for a manual trans:
Mar 06, 2010 | 1999 Dodge Dakota
Shifter linkage to transmission: bushing and clip mount?
Broken grommet in shift linkage.
Hope this tip helps
R/
David
Mar 16, 2009 | 1986 Dodge Omni
LG 4-door French Door Refrigerator Lmx28988st Logo
76 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
